Question about Nokia 6030 Cellular Phone
Radio without headset
Good morning .i want to know that can we use radio without headset.
if yes then tell me how.?
  • 53 Answers
I thing no, because headset are the anten of you radio. And it is protected by producer with chip on your headset, that you never use radio without headset.
Posted on Sep 07, 2008
Active headset
Your headset is operating in VOX mode. This sometimes will happen if the headset is plugged into the radio when the radio is still turned on. Try unplugging the headset, turn on the radio, then talk using the PTT on the radio. Shut the radio back off. Then insert your headset plug, being certain it is seated (click) into place. Then turn the radio back on and see if it works without VOX. If you are still having problems, press the PTT on the radio one more time and see if it shuts it off.
Mar 12, 2014 | Motorola HMN9021A Dual...
Headset transmits automaticly
I want to on fm without Head phone...i need code.
If you mean Nokia 2310, I don't think it's possible to play radio without headset connected to the handset. I don't believe, nokia has ever developed such a model and moreover it's impossible to play radio on nokia phones via bluetooth. If you mean other model, do let me know. Or is there any other application installed on your phone to run the radio? But in fact the handset needs the headset to run radio, so that i'll act as an antenna. Somebody uses the cut-out jack of the headset to play radio. You can try a trick, play the radio, put on the speaker (loudspeaker), then remove the headset, if it's working you are lucky. But even with Nokia N95, it's not working.
If you are sure that you are asked a code to access the radio without headset, let me know with more details.
Thanks.
Good luck.
Thanks for using FixYa.
Aug 18, 2010 | Nokia 2310 Cellular Phone
Wireing in car stereo accord 2006
good morning and welcome to fixya.
are you installing the factory radio or an aftermarket radio? you can purchase a wire harness for this vehicle that will plug into the factory chassis harness without cutting the harness connector. if your connector is missing the wires in the aftermarket harness are color coded the same as the wires on the factory side. check best buy or crutchfield.com those guys at crutchfield are really great. good luck and let me know if i can help anymore. thank you
please don't forget to rate this solution
Mar 13, 2009 | 2006 Honda Accord
Radio nokia
All know that Radio can be used only with ANTENNA......
In Mobile, that antenna feature is integrated with the enhancement,i.e, headset compatible with 5200 ......
So connect the headset before turning on the radio....
Hope this helps......
Oct 03, 2008 | Nokia 5200 Cellular Phone
Not transmitting or receiving when plugged in
The head set is stuck in Transmit. try shutting off the radio and then plug in the headset then turn on the radio. some radios can since the presence of accessories but the accessories must be connected before powering on the radio.
Jul 21, 2008 | Midland AVPH1 Motorcycle Headsets 2-Way...
I recently purchaced 2 Midland CB radios and headsets to go on two motorcycles. When I use them I get excessive feedback. It appears that the metal motorcycle handlebars interfere with the rubber antenna....
The problem is with the headsets, not the motorcycle. If the headsets are generic they may not have the proper mic connections. How do the radios work without the headsets?
Jul 11, 2008 | Midland 75-822 40-Channels Handheld CB...
Radio code
You are combining two different things together.
Firstly you cannot play the Radio without headset and for just playing the radio you need not any Radio Code. Hopefully you need radio code to play Visual Radio. In that case you can play it even without knowing the code. Go to Station Menu in your GPRS connected N70 and then select the Country and the nearest location for getting a list of all FM stations alongwith Visual Radio information, if available.
Alternatively you can get more information about the Visual ID at www.visualradio.com
Feb 02, 2008 | Nokia N70 Cellular Phone
Radio without using headset
as far as i know there is no cheat beacause the headset is acting as the antenna of the radio and i think that there is no device right now for motorolla to access the radio without the headset
Dec 17, 2007 | Motorola Mobility L6 Cellular Phone
Nokia 6030 Cellular Phone Logo
81 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
