Question about Marantz PMD201 Desktop Cassette Voice Recorder
Marantz PMD201 I am using the factory 4.5v plug in for power. Im getting a low battery light. The unit is unable to record from the mic, line & cond. mic?? What could it be, i have check the board and it looks clean.
    Novelist:
    Scholar:
  • 128 Answers
If you are getting a low battery light (that may be the cause of you problem), you should check that the AC outlet settings are right. If the settings are correct, you should take out the AC adapter and try it with batteries (do not forget to disconect the AC from the power and from the recorder!!!). hope this will help. Daniel
Posted on Feb 02, 2006
Need owners manual
You may download a copy of the manual here.
Jan 09, 2012 | Marantz PMD201 Desktop Cassette Voice...
I plug my rode ntg-2 into the computer and record using audacity and the recording is extremely low in volume.
This mic needs phantom power to operate. Best bet, go and buy a USB mic pre, such as a M-Audio product.
This mic, I believe also runs on a battery, when phantom power is not available...so check the battery.
Or, simply, your record levels are set too low.
May 20, 2010 | Rode NTG-2 Professional Microphone
How to connect Marantz PMD201 to computer to convert tapes
You have an analog tape recorder, so you need an interface which will allow you to plug it into your computer. This kind of interface is sometimes referred to as a USB Audio Interface. I use a Tapco Link.USB, and it works well, but there are many out there to choose from - you can use something pretty simple, nothing fancy needed.
The interface will plug into your computer via USB cable, and then you will use RCA cables to plug the PMD201 into the interface. When you play the audio on the tape machine, you should be able to select the "USB interface" on your computer as your "input device" and record on the computer. Watch on the computer recording software for input levels (meters that show sound is coming in), and set them to appropriate levels, not too low, not too high (if there is a red zone, you want to flirt with it only on the highest levels) ... don't hit "zero" if your computer shows zero as the peak level for input.
Final Cut Pro is far to complicated for what you are talking about doing. Many computers come with software already installed that will make simple audio recordings like this.
Please feel free to visit my website, rexark.com, for more information on audio and recording, as well as audio presentation and PA systems.
Good Luck!
Mar 04, 2010 | Marantz PMD201 Desktop Cassette Voice...
Need to know how to use mic with dp-01
First you'll need to know if your mic is dynamic or requires phantom power. The DP-01 does not provide phantom power, but the DP-01FX and the DP01-FX/CD units have the option of turning on phantom power for their two XRL mic jacks. The DP-01 simply has 1/4" jacks for mics. Typically if your mic comes with a 1/4" plug it will be dynamic, but that isn't always true.
Plug it into the mic/line jack in the front of the unit and turn up the input volume knob. Then depending on which of the two inputs you used you'll have to press the Assign button (A or B) and then the rec button over one of the tracks and turn up the track fader. You'll also need to insure that the master fader is turned up and you should then be able to see the meters moving when speaking into the mic and hear the output in your headphones.
To record simply press the rec button on the assigned track again (it will light steady) to arm the track for recording and press the play and record together.
Hope this helps.
bd.
Jan 08, 2009 | Tascam DP01 All-In-One Recording Package...
Stock of Marantz PMD201 Desktop Cassette Voice Recorder
Have you tried here, here or here?
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 22, 2008 | Marantz PMD201 Desktop Cassette Voice...
Stock availability of TCM 5000 ev
This model was discontinued about 3 years ago with no replacement. The closest model to this is the Marantz PMD201.
Nov 15, 2008 | Sony Pressman TCM-5000EV Desktop Cassette...
I have just purchased a new marantz PMD670. When I record using the internal mic it records a 'humming' noise. Using the external mic magnifies the 'noise'
Hi wangkatja
There is little that the user can do to introduce hum to a pro recorder like this, so it will not be something you are doing. Does the unit still do this when you are recording from batteries. If not, this would point to the power supply having poor regulation. If the gear is brand new, I suggest returning it to the supplier and get them to sort it out for you. Marantz service is generally pretty good.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jul 15, 2008 | Marantz Audio Players & Recorders
Marantz PMD201
Check the outlet voltage and set the AC adaptorfor that voltage fter words, insert the AC adaptor's output plug into the 4.5 V DC jack in the recorder. see attache image
Feb 02, 2006 | Marantz PMD201 Desktop Cassette Voice...
Marantz PMD201 Desktop Cassette Voice Recorder Logo
174 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
