Question about Honeywell Programmable Thermostat Heater
No hot water honeywell st6400c
I have a honeywell st6400c when HW is switched on I have no HW lights work but cant hear system kicking in and boiler won't start but if I put heating on boiler kicks in and i get HW and heating? Checked wires as I had a similar problem before with a wire that came loose but no luck...any suggetions
HW valve was stuck in the open posiion and the micro-switch was not working so thats why boiler and pump were not starting. Bled system to below the level of the valve to be changed, and replaced valve with a drayton ( easy quick change of valve head if needed no screws )
Posted on Sep 17, 2008
Failure of my Honeywell CM61ng wireless thermostat. Replacement advice
Probably not. There are replacement models available.
The T6661B programmable room thermostat is also known as CM61.
CM61 1 day wireless programmable thermostat is replaced by CM921.
CM61 1 day wired programmable thermostat is replaced by CM901.
Oct 21, 2017 | Heating & Cooling
Came home after a weekend away and central heating not working. Programmer not turning heating on (honeywell st6400c) but the boiler (a sentima ht 60l) looks like it has a fault. The mains light us on but...
Possible cause of lockout: boiler low water level. If you have a combination temperature/pressure gauge, it should read approximately 12 psi when the boiler is cold. When it runs, it will be approximately 22 psi. If the pressure is low feel the inlet water supply piping. Open the manual feeder valve. The cold water coming in will verify that there is no obstruction to the water flow. You may have "dirt" in the line. You may have a defective water pressure valve or check valve. Another thought. Make sure your AIR SEPARATOR is functional. Remove the cap and depress the valve. You should see water. If air comes out, continue to"bleed" the AIR SEPARATOR. You may haven't to replace the A/S.
Jan 28, 2013 | Heating & Cooling
ST6400C programmer, heating switched off. Switch hot water on only, tank full of hot water but pump runs and radiators get hot. Wall stat is set at zero. When programmer is touched and the flap dropped to...
Have had a lot of these programmers with this fault.Integral fault with electronics.Programmer will need to be replace as unrepairable.You should be able to find a straight replacement version from your heating supplier.
May 11, 2011 | Honeywell Programmable Thermostat Heater
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
User manual for Honeywell ST6400C
Honeywell ST6400C
Times set on thermostat does not turn on or off the heating or hot water at the set times, but any time of the day
Sep 17, 2009 | Honeywell Electronic Programmable...
The timer my missus had,broke down (st6100c)
Hi do you have the make and model of central heating boiler
Aug 11, 2009 | Honeywell Programmable Thermostat Heater
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
Honeywell ST6400C - hot water not working
some digital thermostats do no not work with zone valves is this a new thermostat that you had installed
May 08, 2009 | Honeywell Programmable Thermostat Heater
Cant turn heating off
do you have a separate or built in programmer? if itis separate ISOLATE MAINS undo the screws on the bottom of programmr and checkthat ther are no loose wires ( make a note of where they go for future ref. ). If wires OK check that the valves are working switchoff HW and Heating switch one on at a time and check that each valve is opening and closing and that the boiler and pump fires up ( it could b the micro-switch in the valve is broke! )
Sep 06, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
772 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
