Question about HP OfficeJet 7310 All-In-One InkJet Printer
Incorrect Cartridge - One or both print cartridges are not intended for use on this printer
My Officejet 7310 suffered a phone line surge which blew the main board.  HP has stopped selling the part, so I (in the UK) had to buy one from the US.
It is effectively the same board (e.g. voltages are sorted out in the power supply).  The printer powers up fine, goes through all of its start-up checks and then stalls with "Incorrect Cartridge - One or both print cartridges are not intended for use on this printer".
The cartridges are HP, first use, in date and were in use on the same printer prior to the failure.  They have been tested on another printer and have worked fine.  I have also tested brand new HP first use cartridges on my printer and had the same failure.
I have done everything that HP can suggest - several times.  Cleaning, partial, semi-full AND full resets and the '10 tap' test, which prints fine, but reports that the cartridges are wrong.
The only thing I can think of is that HP has put in regional (US) firmware that is effectively stopping me using entirely legitimate and valid cartridges.  HP have been less than helpful on investigating and correcting this theory.  They have merely left me hangin' on their telephone queues for minutes at a time, listening to music and costing me $50 to get the same advice and solutions.  Even though I say "I've already done that more than once", they simply suggest that I try it again.  They got rather twitchy when I mentioned firmware.
a) is there something else that is wrong? b) if I am right, how do I change the firmware to say that it's now in the UK and not in the US? c) if I am right and HP is simply playing 'dumb', is it contravening any 'anti-trust' laws (or anything else)?
  • Arvide Sep 07, 2008
    Thanks - I will put on my pit-bull teeth and bite them hard!!
  • 1,031 Answers
BE PERSISTANT. DO NOT TAKE NO FOR AN ANSWER. HP IS WELL AWARE OF THIS PROBLEM AND WILL REPLACE YOUR PRINTER IF YOU are persistence. they will give you extentended warranty and Eventually, you WILL be sent a new replacement printer!!
Posted on Sep 07, 2008
When I print on my 7310 I get blank pages
replace ink cartridge and run cartridge allignment prior printing document.
Jan 16, 2011 | HP OfficeJet 7310 All-In-One InkJet...
How do I reset a re-filled HP97 tri-color printer cartridge for an HP 7310 all-in-one printer. I have re-filled the cartridge at walgreens, re-installed the re-filled cartridge, but the diagnostic still...
if it continues to show "empty cartridge" that means. the printer is not accepting the refilled cartridges..
You will have to try with a new genuine HP ink cartridge.
Oct 13, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Cartridge error: cartridge on the right is not
Black cartridge is incorrect or electrical failed.Replace black cartridge.
Nov 03, 2009 | HP Officejet 6310 All-In-One InkJet...
I changed my color cartridge #97 on my HP officejet 7310
Remove the color cartridge. Make sure the contacts in the print carriage are clean. Chek to ensure the contacts on the cartridge are clean. Reinsert cartridge.
Mar 20, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Hp officejet 7310 won't print in black
You people are stupid! After the first person detailed the problem, why do you reiterate by saying "me too, me too"? People come here looking for answers, not more of the same. Here's a suggestion. If you don't have a solution, don't say anything!!!
Mar 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Trouble installing new print cartridge
Make sure the power is on, and the shield drops, so you can access the black cover.
Sep 17, 2008 | HP OfficeJet 7310 All-In-One InkJet...
7310 Cartidge Change Issue
You can download the drivers and utility software for the Officejet 7310 from HP's site here or you can run a cleaning cycle from the front panel - select setup and cycle through the choices.
It sounds like you have a defective cartridge, most common with remanufactured cartridges. If it is an HP original you can check the two year warranty as shown here. If the HP oriinal cartrdige is defective and still in its warranty period you can return it to your dealer or contact HP for a replacement. If the cartrdige is a store brand or some other remanufactured cartridge contact your delaer for a replacement.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 16, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Printing is crooked on the page...otherwise prints beautifully
Sounds like the print head / ink cartridge is not seated all the way. Open the door and check it. It also may be the wrong print head / ink cartridge. If you replaced the print head / ink cartridge recently, you may have the wrong one for your device. If it is a off brand or refilled print head / ink cartridge it may be damaged or incorrectly identified.
Jun 11, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Print Cartridge Fails to align HP 7310
I was having the alignment problem with the black cartridge. After changing the cartridge, try turning the printer off then back on after 5 minutes. It worked for me.
Jun 10, 2008 | HP Officejet 7310 All-In-One Printer
Ask about HP cartridge for HP AIO 7310
Your problem is language and diffrent countries my friend. USA has there cartridges and other countries has theres. The data from the cartridge is language specific. So your American printer can not understand your Denmark cartridge. Also I am guessing there is a diffrence in the size of the cartridges. Therefore rendering your Denmark cartridges useless for your American Hewitt Packard printer.
Aug 19, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
181 people viewed this question
Ben Johnson
