Question about Frigidaire Refrigerators
We have water accunulating at the bottom of our fridigaire RL6003B fridge
    President:
  • 1,462 Answers
Is there a gulley towards the bottom of the back wall with a drain hole in it?
if so, this drain is blocked. push something flexible down the drain till water flows away freely
Posted on Sep 07, 2008
Water leaks at bottom of fridge
The same thing happened to me then I noticed ice had formed at the bottom of our fridge. It was covering a drain hole so water was leaking out the front of fridge instead of going to the drain pan or wherever the hole goes. After I chipped out the ice and cleared the hole with warm water the leak stopped. I also fixed another leak coming from bottom of fridge caused by a loose brass connection on water line going to the door.
May 25, 2014 | Hotpoint HSS25GFP Side by Side...
Frozen water on bottom of whirlpool model evl181nxtq01
I assume that the water is on the bottom of the fridge compartment? It could be that the drain trough has blocked and every time the fridge does an auto defrost, water runs out onto the floor of the fridge rather than down the drain. Once the defrost finishes, the water will stay on the floor of the fridge. Cold air falls to the bottom so its possible to get a sheet of ice in the bottom of the fridge. Locate the drain trough in the back wall of the fridge. See if you can visually locate any blockages or carefully dribble warm water down the drain to clear it.
Oct 19, 2013 | Whirlpool Freezers
No water to the ice maker
filter cracked because it froze . changing the filter is not enough change the housing . as the lines are frozen and wll brake . mm
Apr 18, 2010 | Frigidaire FRS26H5AS Side by Side...
Water build up at bottom of Kenmore Compact Fridge
Problem on your Refrigerator bypass plastic water sypply pipe.May be it was block dust,so you can clean it then water thorough the tank.
Mar 15, 2010 | Kenmore 4.9 cu. ft. Compact Refrigerator
There is water accunulating at the bottom of my
sounds to me like a clog in the defrost drain line
Feb 18, 2010 | Whirlpool Refrigerators
For a couple of days now, my Frigidaire RL6003B small fridge ,the compressor keeps running all day and night and does not switch off. I have felt the compressor and it very hot. The fridge seems to be...
it is possable that a thermostat or sensor is faulty or perhaps the compressor is low on gas you will probably have to call service engineer
Sep 27, 2009 | Refrigerators
Milk and other items keep freezing in my side by side fridigaire
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 22, 2009 | Frigidaire FRS23H5AS Side by Side...
I have an upright freezer and replaced the rubber gasket around the door. It is not sealing correctly and ice is building up and also, water is leaking from the bottom of the door. It is a Fridigaire...
ice on top of freezer door they came out with a fix but does not work two vent holes on bottom of door seal mthem off with silicone moisture getting in if that don't work you need to take liner off and spray foam the liner cavities
Jun 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a frigidaire RL6003B - it is running all the time and the thermostat appears not to be working. Is this likely - the cost of a replacement thermostat compared with a new fridge is a good part of the...
If the temps. seem normal, it is probably low on refrigerant. If it is freezing the milk and wilting the salad, then the thermostat has died.
If in the US, you might check with Johnstone Supply to see if they stock the thermostat used in your fridge; they are basically wholesale but have never asked for a business license and their prices range from 20-50% of dealer costs and the thermostats are only made by a few companies, they are not proprietary.
Jul 19, 2008 | Frigidaire Refrigerators
Refrigerators Logo
189 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
