Question about Philips DVDR3575H/37
Dvdr3570H unlock region codes
Hi, I upgraded the DVDR3570H to version 3.06 and have now lost my region free settings. is there an unlock code or is ther a way of resetting the software back to what it was
  • wrightstuff Jan 11, 2009
    only just bought the recorder, kept freezing when using the menus, upgraded to 3.06 which has fixed the problems, and now i need to make it region 0.
    anyone got the unlock code yet?
  • f_visscher May 11, 2010
    It is impossible to press the hard disk button with highlighting the signal light on the front panel.
    I have continued the process but it did not worked our at all!
I have just tryed and it works with one difference as follows:-
1. Turn on the player from the front panel (without a disc inserted)
2. Press" DISK " on remote and ensure Hard Disk is highlighted
3. Press PLAY
4. Enter 159 121 212 005 255
5. Press PLAY
6. Turn the player off
Posted on Feb 20, 2009
    Problem Solver:
  • 17 Answers
2. Press HDD List on remote and ensure Hard Disk is highlighted
3. Press PLAY
5. Press PLAY
Posted on Feb 19, 2009
I bought some DVDs at amazon.com, but I live outside the region code area witch the DVDs are supposed to work. I live in code area 4. I need someone to find a code to region 1. I have a Phillips home...
This player is relatively easy to change to region free. Please complete all of the steps below to unlock your DVD player.
Please note: Unlocking any DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Unlock sequence for the Philips DVP 3020:
1. Switch on your TV and DVD player;
2. Make sure the TV is set to the correct input for the DVD player;
3. Remove any disc from the DVD player and close the disc tray;
4. Press the "SETUP" button on the DVD player remote control;
5. Use the LEFT/RIGHT arrow keys to highlight "PREFERENCE";
6. Enter 1 3 8 9 3 1 using the numerical keys on the Philips DVD remote control;
A pop-up menu will appear on the TV screen.
7. Use the UP/DOWN arrow key and choose "0" for all regions;
That's it. You should now be able to watch DVDs from all regions on your player. It is also a good idea to switch the player to standby and then switch it back on before trying any discs.
This is a verified unlock sequence for the Philips DVP 3020. If it doesn't work the first time, switch the power off and start again at step 1. If it still doesn't work, it is likely that you have updated your Firmware to a new version and this unlock sequence does not work with your firmware version
If you need further assistance, please reply to me from within this page and let me know which firmware version you have installed in your DVD player.
Regards,
BElectric.
Jan 28, 2011 | Philips Televison & Video
L need a multi region code for a panasonic dmr-ez47v.
Panasonic DMRs cannot be unlocked for muliti region simply by entering a code form the normal remote or front panle controls.
Panasonic machines require a special remote control in order to make them multi region. Panasonic dealers will unlock your machine for you but will charge you - this is expensive.
Alternatively, if you search eBay you will find devices that will unlock your machine that can be purchased or "rented", for considerably less than a dealer will charge.
Nov 07, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Unlock code for dvd drive for a Compaq Presario V2000
You can only change the region code 4 times and then it locks onto that region. There are firmware upgrades for various model DVDs on the Internet that makes the DVD drive region free, but if you make a mistake in upgrading the firmware or installing the wrong firmware version then the DVD drive is turned into a piece of junk.
The best way to solve your problem is to install software that defeats the region code so you can play DVDs from any region.
I use a region free program fronm DVD Idle, it is not very expensive and there are other similar programs on the Internet. Use Google to search for them.
Have a look at www.dvdidle.com
Jul 18, 2009 | HP Compaq Presario V2000 Notebook
DVDR3570h is stuck in standby, cannot turn on
I had this problem, it was solved by reformatting the hard-drive.
NOTE: if you do this, all settings and all that is saved on the harddrive is lost. But seeing that you can't start it anyway, that is acceptable, right? :)
Anyway, here's how you do it, according to Philips support:
  1. Pull out the power cord from the socket.
  2. Press and hold PREV and STOP (i.e. left and down) on the front panel.
  3. Plug the power cord into the socket again.
  4. Wait until the front panel says "FMT KEY" to let go of the buttons. Wait for it to finish formatting, upon which you will get "-- --" on the panel.
Restart the box and you should now end up at a screen asking you to set the language for the box, as if being started for the first time ever.
Also of note: if you want to restore the firmware to factory settings, Philips support told me to pull the cord, press and hold the STANDBY button, and plug it back in again. For the looping problem though, I didn't need that.
Mar 15, 2009 | Philips DVDR3576H DVD Recorder
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Phililps DVDR5570H only plays zone 4.Is there an unlock code for multizone playback?
Try this:
Models supported:
DVDR3570H
DVDR3575H
DVDR3577H
DVDR3590H
DVDR3595H
DVDR3597H
DVDR5520H
DVDR5570H
  1. Power on the recorder
  2. Wait for player to initialise.
  3. Press [HOME] on the remote control.
  4. Press [PLAY / PAUSE]
  5. Key in 1 5 9 1 2 1 2 1 2 0 0 5 2 5 5 – The numbers will appear in the display of the recorder.
  6. Press [PLAY / PAUSE]
If the recorder goes into browser mode during the procedure, then it will need to be re-started from the beginning.
If at any point the recorder is reset to factory settings, then the procedure will need to be carried out again.
Jul 27, 2008 | Televison & Video
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Philips DVDR3570H HDD DVD player Recorder - done basic set up last night but the start up search for analogue channels returned 0 - speant 2 hours re arranging plugs & it still wouldn't locate them? do...
The DVDR3570H will only find analogue channels if you have a TV aerial connected to it.
If you only have a satellite or cable box, then you can still use the recorder, but you will have to use the AV inputs on the recorder. In this case you will only be able to record the satellite or cable channel you are watching.
May 01, 2008 | Televison & Video
Philips DVDR3570H/05 constantly looping on startup
Apr 09, 2008 | Televison & Video
Philips DVDR3570H for multiregional playing
Hi Dominic,
here is good news for you.
THE philips DVDR3570H CAN BE MADE MULTIREGIONAL .FIRST OF ALL ON THE SET. NEXT REMOVE ANY DISK ON TRAY. OFF THE UNIT AND ON AGAIN.NOW CAREFULLY DO THE FOLLOWING. PRESS HOME,THEN PRESS PLAY/PAUSE. TYPE THE NUMBER 159121212005255 AND PRESS PLAY/PAUSE. OFF THE UNIT AND ON. NOW THE UNIT IS MULTIREGIONAL. i AM A 100% SATISFIED CUSTOMER. THANKS TO PHILIPS.
DR SAJEEV BHASKAR.
Feb 16, 2008 | Televison & Video
Philips DVDR3575H/37 Logo
1,549 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
