Powered Subwoofer - S-DV99SW not powering up changed fuse in plug checked all wiring and still no power?
  • bce5412 Sep 19, 2008
    Yes I have this problem does anyone have any ideas please?
  • 4 Answers
SOURCE: powered subwoofer hum
The input filter capacitor of ur sub may be damaged,the possibility is upto 99%.u can identify the capacitor easily as it will be the the larger capacitor in that board and is located near the power supply entrance.the component costs within a dollar
Posted on Mar 30, 2007
SOURCE: Th-R1 no pwoer to subwoofer - transformer u/s?
my power goes to the subwoofer and the little green light comes on for just a second and the you hear a click sound and the subwoofer power goes out. I have the JVC DVD Digital Cinema System TH-C90. Can you please help???
Posted on Nov 13, 2008
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
SOURCE: connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Posted on Jan 07, 2009
    jhinsincity
    • 616 Answers
    SOURCE: No sound from the subwoofer
    Fuse is probably blown
    Posted on Apr 13, 2010
    Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
    I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
    If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
    Jan 05, 2016 | Audio Players & Recorders
    Bose Acoustimass Subwoofer not working; front/center are working
    Ok, have you tryed to unplug all of the wires from the sub, including the power wire from the wall. Install of the speaker wires to the sub, and plug back in the sub. Also what are the numbers on the speakers and the sub.
    Jun 10, 2007 | Onkyo TX-SV525 Receiver
    Paradigm pdr80 no sound
    If it is a powered sub, the sub power supply may have failed. There might be an open fuse.
    Dec 25, 2013 | Paradigm PDR 12 Speaker
    Why won't my powered subwoofer turn on? It's not
    Have you check if the plug is good on it?
    Dec 03, 2012 | Audio Players & Recorders
    My subwoofer and speakers wont draw power when i plug it in, could it be the fuse or something else?
    The Altec Lansing A425 doesn't appear to have a fuse. Check for a circuit breaker on any surge protectors it might be plugged in to and make sure they haven't been tripped. Confirm that the power cord is firmly plugged in. Additionally, you could check the wall transformer with a multimeter to make sure it is providing the correct voltage needed by the speakers. Check the back of the subwoofer for a hidden power switch. If everything is plugged in and turned on, but you still don't have power, you will either need to open the device up and troubleshoot it or replace it.
    May 13, 2010 | Dell Powered Subwoofer Set A425 Computer...
    Subwoofer pre-out wires
    Sorry for the stupid question but is your subwoofer a powered sub? The subwoofer out is just a preamped signal that drives a powered subwoofer. Let me know then we can go from there.
    Jan 28, 2010 | Audio Players & Recorders
    Powered subwoofer keeps blowing its fuse
    The amp is blown. You need to get it in for service. No telling exactlly what is wrong untill it is opened. 215-736-8055
    Jan 15, 2010 | Onkyo Bass Reflex Powered Subwoofer...
    Infinity Interlude IL120s Powered Subwoofer (home) will not power
    Some of these Infinity Amps have an Internal Glass Fuse. Open the Case and Check for this Fuse. Please Rate My Response! Thanks!
    Feb 03, 2009 | Infinity 7540A Car Audio Amplifier
    JBL TLX PS10 Subwoofer - Does not work
    If you have checked the fuses which it sounds like you have, your amp may be out. Take that RCA and plug it into the other speaker. If thar she blows, treat as warranty and call the factory. If this is helpful, please post as such.
    Jan 17, 2009 | JBL TLX PS10 Speaker
    Jamo Sub300. No power. No lights
    Well it would void the warrantee, but you can take the back panel off and the power supply will only have two leads (3 if grounded) in from the plug, and out to the crossover. It sounds as if you are correct that the power supply is bad.
    Charles
    Jan 05, 2009 | Jamo SUB300BA SUB 300 Powered Subwoofer...
    Televison & Video Logo
    88 people viewed this question
    Top Televison & Video Experts
