Question about Ariston Technologies AWD121WH
Error messages on my Ariston AVXD109
Hi, this is an Australian model, I keep getting the H2O error, have checked all pipes in/out, water is on, sufficient pressure, etc.
Anyone got any other ideas?
Cheers
  • Amanda Jenkinson
    Amanda Jenkinson Jun 29, 2015
    Did you get any answers ...we're having exactly the same issue. Engineer suggesting new valve
    Master:
  • Ariston Tech... Master
  • 489 Answers
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Posted on Oct 11, 2015
  • Dado Oct 11, 2015
    Where there is a LCD display all codes will be preceded with an F or F0
    Except fault code H20 that someone with a sense of humour at Indesit came up with, it means that the washing machine or washer dryer isn't filling so check the usual suspects for incoming water.
    displayed).
    • The hose is bent.
    Dado
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
  • 713 Answers
SOURCE: hi sir we have ARISTON washer and dryer model :
unplug it for a few min. plug back in.
Posted on Mar 01, 2011
INDICATING h2O CONTINEOUSLY draining water
h2o is the chemical symbol for water. But if the water keeps running and does not stop, even when the machine is full it could be the machine has a defect level indicator, or the water lock does not work. When the lock even don't closes what you remove the power the lock is defect.
Mar 24, 2015 | Ariston Technologies Washing Machines
Why when I put the washing in 30 min wash the manching is flushing h2o
H2O means the applionce isnt getting enugh water but it sounds to me like youre waste hose is to far down your stand pipe it should be in no more than 4 inches and also make sure you are connected to the cold feed not the hot.
May 30, 2014 | Ariston Technologies AW125NA 13 lbs. Load...
What is the meaning of H20 which display on ARISTON wasing machine
May 24, 2014 | Washing Machines
Ariston codesH20
H2O means the applionce isnt getting enough water check the waste hose is not pushed to far down the upstanding ( should be in no more than 4" )
Mar 11, 2014 | Ovens
Ariston ARF 105 H2O error!
I had this issue also and it was because I started the machine and had not turned on the water to it. However, it cleared when I unplugged the power cord, waited about ten seconds, then plugged it back in. I guess they need a "reboot" once in awhile, like a computer - at least mine did. Hope this works for you, too.
Nov 05, 2013 | Ariston Technologies Washing Machines
Ariston Dishwasher LD87, error code AL03
for code al03 ,today i resolve the problem it was a pomp like everywhere in sites riding. we open a popm and there have a black lastic and it was inside of the pipe ,so we take it litl bit out and dishwasher work perfect !! it is easy ! dont be afraid to fix it alone .Just be carefull with a lot of water will come out from the pipes. and sore has to be away from electicity)good luck !
Apr 11, 2009 | Ariston Technologies Dishwashers
After about 10 mins error code H2O is displayed.
the h2o message means the machine isn't getting enough water. check pressure and water intake pipe.
Mar 15, 2009 | Washing Machines
Ariston Margherita ald 1 40 Error code H2O
H2O is the symbol for WATER and probably indicates a WATER related fault on your machine. A pressure switch is the normal way the machines 'sense' when the level is sufficient. Overfilling suggests a faulty switch, which will need to be replaced by a technician. Also, ensure that the machine drains as it should, if not, the pump filter may be blocked.
Jan 03, 2018 | Ariston Technologies Washing Machines
Ariston Technologies AWD121WH Logo
373 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
