Hi, I Have a Warfedale pro BX1780sd unit, last night during a performance the mains fuse (8Amp) on the back of the pannel blown. I looked in saide today and found that both the 15 Amp fuses inside the unit had also blown. Just for information I am using Bose speakers with a Bose active EQ unit between the "monitor out" and "power amp in" Is it worth me just getting some more fuses, or is it likely to be more involved? many thanks Dave
  • Grinwolf Sep 10, 2008
    I'll have a look, thanks for the advice
    Problem Solver:
  • 25 Answers
Check shorted rectifier diode in main power supply,check shorted power transistors,if it is power IC amplifier unsold it put fuse if doesn't blown up the problem is solve.
Posted on Sep 07, 2008
What size glass fuse do i need to relace one in my warfedale 5000 amp
more than likely its a 30 amp fuse but if you look at the old fuse it should tell you the fuse size
Sep 19, 2014 | Audio Players & Recorders
Hi I have a str-dh520 reciever that has a 8 amp 125 volt fuse that blew and I could only find a 8amp 250 volt fuse and when I installed it it blew right away. What do I do now? Dose it have to be a 125...
No! the fuse you replaced was fine, the power transformer may be shorted, or the audio ouput semiconductors are shorted, check the speaker wires for shorts, if okay! I recommend a pro with a estimate.
Mar 19, 2012 | Sony Audio Players & Recorders
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
Had a thunderstorm last night. The Fisher Paykel washer won't come on at all, even after unplugging as in the manual. Is there a fuse that could have blown ?
Hi Bruce.Just read your posting.Yes your machine has a control fuse in the main control module.I need to know the model number of the machine to guide you in how to replace it if it is blown.The model number is on a sticker that is located at the back of the machine up top.Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
May 21, 2011 | Fisher and Paykel Washing Machines
POWER SURGE LAST NIGHT. SYSTEM NOW DEAD. IS A RESET POSSIBLE/
Hi:
You may have to at this point open the main unit and check your line fuse for blown condition. If found blown replace fuse with same voltage rating and ampereage rating.
Jan 27, 2011 | Panasonic SC-BT100 Theater System
Hi, My Bernina Artista 180 sewing machine stopped working last night - during a storm - and I would like to check the fuse before taking it in to be serviced. We have exposed the Mother board but can...
There are two fuses on the 'L'-print power-supply module - this is in a separate compartment on the back panel, secured by a single long screw. These are both glass fuses and you MUST use the correct type if one has blown. Unfortunately, I have had a couple of this family of machines that have been subjected to mains glitches during local storms and it has taken-out the secondary power-supply on the main processor board 'S'-Print, which requires a very expensive replacement of the whole board. Symptoms of this type of damage range from intermittent 're-booting' of the machine, to complete failure, usually identified by the backlight on the display still being on without any displayed data, but the sewing light is off.
Sep 17, 2010 | Bernina Artista 180
Sanyo DP5747 Plasma TV no power
Found 1 of the 2 ac supply ( 8amp) fuses blown on the main pwr. supply. Replaced fuse and good so far. Looked over the ps for damaged components, none found. Checked current with ampmeter with tv on, showing 3amps. Cheers
Jan 03, 2010 | Sanyo Televison & Video
Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
May 27, 2009 | Sony STR-DE635 Receiver
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
Tv dead after storm
you could open it and look to see if the fuse is blown
Sep 22, 2007 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
164 people viewed this question
 Grubhead
Grubhead
