Question about AcerScan 320U Flatbed Scanner
Hardware Problem After 9 months away I came back to a scanner that seems locked but isn't. The bar will only go an inch or so when scanner is turned on. Anything I can do? Light is working and I updated the driver for XP.
    Novelist:
  • 196 Answers
I got a similar problem with my Umax 4000U some years ago. The scanner failed to initialise after power up. The led was blinking. The supplier told me he only 'greased' the shaft to solve the problem. I got the same problem again after a year. To me it looked like the transport motor doesn't have enough power. Opening the case and pushing the 'scan wagon' from its power off position helped sometimes. Hope this helps a little.
Posted on Jan 22, 2006
1986 460ci sat 6 months, now seems to be locked up.
If you can't turn the crankshaft with a socket and breaker bar (or large ratchet wrench- 1/2 inch drive) on the crankshaft pulley bolt, then it probably is froze up- will have to be dismantled to see what is wrong. Don 't depend on the starter to see if it turns over-use a socket on the crank bolt to check if the crankshaft is still free turning.
Oct 23, 2016 | Cars & Trucks
AOC monitor 2436vh does not fill the screen using the HDMI connector. There is a 1 inch black border around the window. Controls to stretch the display are locked out (not accessible) when using that...
The "Best Solution" fixes a problem that is unrelated to the original poster. anononline19's solution is to fix the entire OSD being locked (displays OSD Locked when the menu button is pressed).
Original poster's problem can be fixed by changing your graphics card's "overscan" settings.
Overscan on ATI cards:
http://nigelt.wordpress.com/2009/09/21/overscan-options-in-catalyst-9-9-on-windows-7/
Overscan on nVidia cards is currently not supported.
Oct 16, 2010 | AOC Computers & Internet
Sharp al 1000, the scanner is on and goes right and left all time
The simple fix is to clean the reference strip under the glass. There is a white strip under the left edge of the glass that the scanner reflects off of in order to set up the scanner bulb intensity. When this strip gets dirty the the machine just keeps trying. I would remove the cover on the left side glass area with the 4 screws. On the bottom side you will see the white strip. Clean this with glass cleaner. While your in there I would go ahead and remove the large glass. Turn off the main power and pull out the scanner bar and clean 3 mirrors. One is the "slot" in the main scanner bar and then the 2 in the assembly to the left that trails the main scanner bar. Once cleaned put it all back together and this scanner bar "referencing" issue wil go away. If it does not (which is rare) then there is a problem with the scanner/ccd unit and the machine is really not worth repairing at this point.
Good Luck and Thank You for using Fixya.
We are having a contest this month based on positive testimonials. If my solution is helpful to you, please take a moment to leave a short testimonial.
Thanks!
Oct 05, 2010 | Office Equipment & Supplies
The light on the scanner is flashing intermittently hence it will not operate
When the light bar flashes or blinks, the built-in diagnostics are reporting the hardware is not functioning as expected; it does not necessarily mean the scanner is defective. Before contacting HP for service, perform the following:
  1. Turn off the computer.
  2. Disconnect the power cord and USB or parallel cable from the back of the scanner.
  3. Unlock the transport lock several times to ensure it is not restricting the movement of the carriage. Make sure it is fully open before proceeding to Step 4.
  4. Wait 60 seconds before connecting USB or parallel cable and the power cord to the scanner.
  5. Turn on the computer and rescan to test.
If the light bar flashing is accompanied by a 2117 error, also try the troubleshooting steps included in document: Bps03134 - Scanner not Responding 2093, Unidentified Program Error.
taken from hp support website
Jul 21, 2010 | HP ScanJet 5370C Flatbed Scanner
Schlage deadbolt will not unlock even with the use of a key?
it sounds as though the linkage that pulls the deadbolt back has disengaged... if you undo the screws from the inside of the door and remove the manual knob there will be 2 more screws holding the key lock to the door. A thin flat bar is attached to the key lock that goes through the deadbolt and into the manual knob. This bar turns with the key, sliding the bolt on its track to lock and unlock the door. Once the lock is apart check the key in the lock to see if the bar turns when the key does. then see if there is anything that may be obstructing the deadbolt from sliding. The locks are pretty indestructible so if there is a problem it may have been from the install... perhaps the door is to wide for the lock to engage properly and the lock worked loose in the 6 months that it worked.
Jun 21, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Scanner bar seems jammed, printer shows busy, all docs cancelled
Open the printer and pull paper. It might come in pieces then shut down printer to reboot it and that should make the symbol go away and youshould be able to start over. At least when I had a problem thats what fixed it. Hope it helps
Jan 17, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Makes grinding noises, refuses to scan; WinXP
take a look on the underside of the scanner. there may be a switch that goes from lock to unlock. try to move it to lock and back into unlock. this lock is usually used to lock the bar from moving during shipping. if this got moved back to lock or bumped while you had it turned over, the scanner will not allow the bar to move.. try this first.
Aug 16, 2007 | HP ScanJet 6200C Flatbed Scanner
Visioneer scanner light barely moves HELP!
first u need to install proper drivers for ur . If installed then this may cause due to scanner hardware problem. This can be repaired . Go to ur scanner Provider for reparing. Thank you.
Aug 14, 2007 | Visioneer OneTouch 7100 Flatbed Scanner
AcerScan 320U Flatbed Scanner Logo
52 people viewed this question
Top Acer Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Marvin
Marvin
polytek
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
