I have a z640 lexmark printer, which side does the black ink cartridge go? the left or the right?
  • 19,396 Answers
Black cartridge usually goes to the right.
Check here for instructions
Black cartridge is the one on a darker green color.
Posted on Sep 07, 2008
Lexmark Z640
Are you using original cartridges?
Mar 09, 2008 | Lexmark Z640 InkJet Printer
Thru cartridge out need to know what are the ink numbers for black/color
The compatible cartridges for a Lexmark Z640 printer are: #16 & #17 for black/mono and #26 & #27 for color. Thank you for choosing Lexmark.
Aug 09, 2010 | Lexmark Z640 InkJet Printer
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    Right or left side for black ink cartridge
    The black cartridge goes on the right.
    I hope this helps.
    Jun 15, 2010 | Lexmark JetPrinter X1185 All-In-One InkJet
    Where do you insert the ink cartridges on lexmark x4650
    These are the instructions for X2500 Printer
    1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
    2.Open the top portion of the printer to reveal the ink cartridges.
    3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
    4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
    6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
    7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
    8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
    Oct 25, 2009 | Lexmark X2500 All-In-One Printer
    Refill lexmark z640 cartridge
    You still can use the refill that in the kit as they all based on the same method, let you know. Please see that grant me your approvals by rating my service and I hope that I can serve you again the future.
    Sep 26, 2009 | Lexmark Z640 InkJet Printer
    I have a print lexmark z640 after refill of ink ,olways said does not have innk
    # Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
    # Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
    # Continue doing this until it looks clean.
    # Then dab the cartridge on the towel to make sure the ink is flowing.
    # Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
    1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
    2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
    # Reinstall the cartridges, making sure you snap them correctly into the printer.
    Jan 29, 2009 | Lexmark Z640 InkJet Printer
    Lexmark z640 has stopped printing - goes through the motions but no ink on page
    Some third party cartridges will not work with your printer as they are remanufactured from used cartridges.
    It is more expensive to buy genuine Lexmark ink, but atleast you know it will work.
    You may try reinstalling the driver before buying new ink.
    I hope this helps.
    Good Luck.
    Oct 18, 2008 | Lexmark Z640 InkJet Printer
    Televison & Video Logo
    Top Televison & Video Experts
