Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Pl privide me audio driver for presario C785TU
Software driver of audio C785Tu Hi, i have no any problem i have required adiuo driver setup please send this setup it's my request, thank you.
  • 175 Answers
I assume you have Windows Vista: http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&product=3739733&lang=en
You are given the option to view directions on how to install drivers.
Posted on Sep 07, 2008
How can I send designs from my PC to my Toyota 830 embroidery machine when my Pantograms software/hardware is no longer working?
Some of the Pantograms software programs require a USB dongle connected to the computer. However, the driver for this dongle has to be installed before you install the software or connect the dongle. I suspect you may not have installed the driver or the dongle is missing.
Assuming that the dongle is connected:
Close your embroidery software program and all of the Pantograms software, including the Network C software, on your computer and remove the USB device. Put the software install CD into your machine's optical drive. (If your new machine doesn't have an optical drive, get a USB optical drive or copy the files from the CD to a 1GB+ USB flash drive at another computer with an optical drive.) If Windows XP starts the autorun routine for the CD, click Exit. Then double-left click on My Computer to launch File Explorer. Go to the CD drive (or USB drive if you used the work-around) and double-click on it. Open the Rainbow Drivers folder and then open the XP folder. Double click on the program: setup.exe . Choose Complete install as the program executes. Then close File Explorer when the install is done. Now insert the USB dongle and follow the on-screen message about New Hardware found to install the Rainbow driver from C: .
If you do not see the New Hardware found message, try putting the dongle into a different USB port. (Make sure to avoid USB hubs - they can add to USB device issues.) If the dongle doesn't work at any port, you may need to use a different method. There is a flash reader available for connecting a USB flash drive to the Toyota 830 here: http://www.plrelectronics.com/lab/usb_reader.php . (Scroll down to the Toyota machine section. This isn't cheap but it is cheaper than some of the newer embroidery software packages.)
I hope this helps.
Oct 26, 2014 | Sewing Machines
BLADES DON'T MEET ON OVERLOCKER
hi there
please see link to download user manual for JUKI MO-644D
http://www.juki.pl/support/HSM/Manuals/MO-654DE_manual_UK.pdf
and you must made upper and lower knife very close to cut material correctly.
regards
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Nov 22, 2013 | Juki MO-644D Mechanical Sewing Machine
Singer 250 can not run 86 on 64 platform
There is an update to give an x64 driver for the Singer CE-250 that will let you run on an x64. With the sewing machine not connected to the computer, install the software that came with the machine. Click OK at all of the "cannot run x86 build on a 64-bit OS" messages. When it is done, install the software from http://futura-support.com/products/ce-250/software . (The second one is for XP, Vista, and Win7 versions.) Accept the unverified driver (install anyway). After this completes, then connect the sewing machine to the USB port on the computer.
Similar patches exist for the CE-200.
I hope this helps. Please add a comment with the version number of your software. I know with Husqvarna Viking's 3D Embroidery, there are versions that can be upgraded to work with x64 and versions that are not patchable.
Mar 25, 2013 | Singer CE-200 Quantum Futura Computerized...
I need a singer sewing machine 7105 manual
i am also looking for manual for singer 7105.
if anyone has it, please send it to : olkawka@o2.pl
thx
Jan 19, 2012 | Singer Sewing Machines
Puller for Juki DLL 8700-7
hi there
please we need more explain for what puller you need ?
if you mean rear puller you can use RACING PULLER for lockstitch machine model PL - P2 .
if need more help please email me at aabozid@hotmail.com
BEST REGARDS
ASHRAF ABOZID
CAIRO - EGYPT
Jan 22, 2011 | Juki DDL-8700
Singer Futura 250 under XP - embroidery unit won't move
HI,
The machine has to be leveled. What I mean is that the embroidery part has to be level so the conector can send the information to the machine. Turn on the machine, open the software at the computer and try to pull the embroidery arm a little up (very carefully) if the hoop moves and the machine beeps it means that the computer is comunicating with the machine. Try to put something under the machine to level it.
Jun 08, 2009 | Singer Sewing Machines
How to thread a brother ls2125 sewing machine
Their is a diagram in your manual. if you don't have one here is a link. http://gotoes.org/sales/BrotherSewingMachineManuals/ViewInfo.pl?Brother=1&Sewing_Machine_Model=LS_2125
You will start from right to left then work down.
Oct 16, 2008 | Brother LS-2125 Mechanical Sewing Machine
Dongle issue
The Designer SE software does not use a dongle. If you are attempting a "Smart Update" on the Designer SE and it asks if you use a dongle, just say no and the update on the machine will run.
If you have 3D or 4D software, it uses the dongle and it will be USB. Download the latest driver for your software from the Husqvarna Viking website. The link is through the homepage at Husqvarnaviking.com/us . Click links on the left side of the screen for 4D Software, Help & Updates, and Other Useful Software at the bottom of the page. This will have the latest 3D driver. 4D will require the latest update to the software and a firmware upgrade to the dongle. Run Smart Update on the software and then get the firmware update that is directly below the 3D HASP driver on the Other Useful Software page.
Nov 09, 2007 | Husqvarna Designer I
Can't load software for futura
Hi Sunbob, please begin by downloading and installing the latest software and updates that corresponds with your equipment by clicking on the URL below. Well, let's be as proactive as possible, so, let me rephrase. Download and install the appropriate software/updates that corresponds with the Operating System of your Computer first. After successfully installing the computer Updates, restart your computer to ensure that the newly installed drivers can confirm their stability. After restarting your computer, then begin to acquire the neccessary updates for your Machine. Please update your post with any developments so I can stay informed of the status of your issue.....good luck my friend.
Jul 08, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
32 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
