Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Problem my pentium 4 motherboard first has a problem with the cpu fan spining slowly then i replace, now 3 capacitors near the processor are fat & board blow my power supply. i replace capacitors with new ones with same value and new power supply but my motherboard can't switch on even the cpu fan can't spin. Please assist. Thank you in advance my email is "fanxtung@yahoo.com
  • 53 Answers
My be something wrong with your ATX. It can depend on transistors too. If you have tester you can check all ATX pins.
Posted on Sep 07, 2008
Which fan/heatsinks can be used on an MS-7174 Ver 1 motherboard? It seems there needs to be clearance for some capacitors to fit beneath it.
Heatsinks are dependent on the type of processor that you have, I recommend that you call Microcenter or fry electronic
Apr 22, 2015 | MSI Computers & Internet
My hcl pc config:core 2 duo 2.2ghz mobo-gigabyte ga945gcx s2 512mb memory started rebooting itself gradually it begun to give no display despite that the front panel led and fans turn on. i checked my pc...
Really?
Old Intel Pentium 4 processor, that uses a LGA 775 processor socket, worked, but the Intel Core2 Duo 2.2GHz didn't?
This would suggest a bad CPU.
(Central Processing Unit. Another term used is Microprocessor, or simply Processor, for short)
If you hadn't stated using an old Pentium 4 for a test, I would have stated the problem is the Power Supply, or Electrolytic Capacitors on the motherboard.
Capacitors on the motherboard are used as Filters, or Voltage Regulators.
The one's used as voltage regulators, are in the motherboard voltage regulator circuit,
http://www.hardwaresecrets.com/article/616
Part of what the motherboard voltage regulator circuit does, is to regulate voltage for the Processor.
The Processor MUST have a steady, 'clean', supply of voltage, and it MUST be within the tolerance range for the Processor.
Let's look at an Intel Core2 Duo 2.2Ghz processor;
The Intel Core2 Duo E4500,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#.22Allendale.22.2C_.22Conroe.22_.2865_nm.29
The voltage tolerance range is 0.85 Volts to 1.5 Volts. (DC)
Now let's look at an older Intel Pentium 4 processor, that uses an LGA 775 processor socket, and is rated at a maximum frequency rate of 2.66GHz, (Model 505),
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29
Voltage range is 1.25 to 1.388 Volts. (DC)
IF, the Electrolytic Capacitors were failing in the motherboard voltage regulator circuit, that regulates voltage to the Processor; you would think the voltage regulator circuit would support the Core2 Duo, before it would support the older Pentium 4.
However you may want to closely inspect the Electrolytic Capacitors surrounding the processor socket.
These are NOT the only capacitors in the circuit, that regulate voltage for the Processor.
If you read the article from Hardwaresecrets, you will see how to find all of them.
This is what happens, when Electrolytic Capacitors in the motherboard voltage regulator circuit, (For the Processor), go bad,
http://www.youtube.com/watch?v=KN6_-8fYHo0
(Starts at 0:04)
Due to an Electrolytic Capacitor has a chemical composition inside, (Electrolytic Paste), it can break down over time, and still work in a weakened state.
Eventually it fails.
To explain;
The Electrolytic Capacitors used on the GigaByte GA-945GCMX-S2 motherboard, are Radial Aluminum Electrolytic Capacitors.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128058
Radial meaning both leads come out of the bottom.
Aluminum designates what the case is made of, and the metal strips inside.
Example of a basic Radial Aluminum Electrolytic Capacitor,
http://en.wikipedia.org/wiki/File:Capacitors_electrolytic.jpg
The bottom example with a blue plastic sleeve, is the Radial design.
The top example is an Axial design. The leads come out of both ends.
In the example above there is a blue plastic sleeve, over an aluminum case. The case resembles a 'Coke-Cola- can with the top, and bottom removed.
The top is a thin flat round disk. It has a shape etched partway into it.
The shape is usually an X, or a lK.
The bottom is called a Bung. It is a synthetic rubber flat round disk.
The leads coming from the metal strips inside, poke through it.
Inside the case are 3 strips.
A) One is a thin, aluminum 'foil'. It is the Conducting Strip, and the Positive lead is connected to it.
B) One is a thin, aluminum 'foil', and has a non-conducting medium applied to it. It is the Non-Conducting Strip, and has the Negative lead connected to it.
C) The last strip is a paper-like substance, and is soaked with Electrolytic Paste.
The paper-like strip is laid in-between the two metal strips, and all three strips are rolled up tightly.
When the capacitor starts to fail, the Electrolytic Paste inside starts to develop a gas. Hydrogen gas.
The gas expands, and pushes against the seals of the case.
(Top disk, and synthetic rubber Bung)
The top disk's X, or lK will split open, and paste will slowly ooze out.
Or the rubber Bung will have one edge poked out of the case, and paste will slowly ooze out.
OR both.
So much paste loss, and the capacitor operates at a weakened state.
TOO much paste loss, and the capacitor fails.
(A Capacitor is designed to slowly build up a charge, then release it all at once.
Crude comparison, is a large swimming pool slowly filled by a garden hose, then one wall of the pool is taken down all at once.
Some cameras use capacitors for the flash unit )
It isn't so much that the computer isn't giving a display.
The reason for no display, is that the computer isn't working, in order to send out a video signal. (No Signal)
More in a Comment.
Regards,
joecoolvette
May 06, 2012 | Computers & Internet
What kind of cpu do i need ? i have asus p5nd2-sli motherboard with no cpu in it
Compatible Processors Pentium 4, Celeron D, Pentium Extreme Edition, Pentium D 64-bit Processors Compatibility Yes Processor Socket LGA775 Socket
Seems that you need Socket LGA775,and CPU: Pentium 4, CeleronD, Pentium D, Pentium Extreme Edition. For more Details go here:
http://www.google.com/products/catalog?hl=en&q=p5nd2-sli+motherboard&cid=13414569805758042878&os=tech-specs
Nov 16, 2010 | ASUS P5ND2-SLI Deluxe Motherboard
Computer will not boot to windows. the screen displays phoenix - awardbios v6.oopg, an energy star ally copyright(c) 1984-2004, phoenix tehcnologies, ltd p4m800-m7 (pm48m309 bf) main processor: intel(r)...
The light you're referring to is the HDD Activity Lamp.
(HarDDrive)
It blinks green when it's operating, and orange for inactivity, or not operating.
You're getting to the BIOS Post screen, but BIOS is handing over the computer to the Operating System.
(Windows XP is an example of an O/S)
When you press the Power On button;
1) A temporary connection is made from the motherboard to the power supply. A 5 volt circuit is made. This turns the power supply on. (Soft Power On)
2) The BIOS chipset, is the first chipset to receive power. (Chipset is a slang term for IC. Integrated Circuit)
The BIOS program, ( 64MB in size), looks to see what all devices are connected.
(Harddrive, optical drives, mouse, keyboard, etc.)
3) Then BIOS does a Ram Memory count,
4) Turns the Processor on,
5) Then hands the computer over to the Operating System.
It looks like BIOS has recognized your Intel Pentium 4 processor, (2.66GHz frequency rate, 533MHz FSB), but hasn't turned the processor on.
[Let me stop,and explain something real quick.
Where you see -
Intel (r) Pentium (r) 4 cpu 2.66ghz (133x20.0)
The r stands for Registered. Intel and Pentium are registered trademarks of Intel Corporation.
It's a Pentium 4 model.
2.66GigaHertz is the Frequency Rate. Slang term for frequency rate is 'Speed'.
Giga = Approximately 1 Billion
Hertz stands for Cycles per Second.
At maximum capacity, your Pentium 4 processor can operate, at a 2.66 Billion Cycles per Second frequency rate.
133 stands for 133Mhz. 133 MegaHertz.
Mega = Approximately 1 Million
This is the Clock Rate. Intel processors are 'Quad-Pumped', so the FSB is actually 533MHz.
(FSB = Front Side Bus)
The 20.0 is the multiplier.
20 times 133Mhz = 2600 Mhz,
or 2.66GHz ]
Now, why is the processor not turning on?
Suspect the Power Supply.
Not enough power to turn the Processor on.
1.ALL the lights for your computer use less than 1 Watt.
2.EACH fan uses 2 to 3 Watts.
3.A typical processor uses 55 to 125 Watts!
(The Processor hasn't been turned on, so nothing else is receiving power yet)
This is the basic specifications for your processor,
Scroll down the left column of the list.
Where you see Pentium 4 505, Pentium 4 505J, and Pentium 4 506. Your processor is one of these three.
Scroll across. You will see 2667 MHz. 2667Mhz is rounded off to 2660 MHz, or 2.66GHz.
You will see 533M/T as you scroll across.
M/T stands for MegaTransfers. A more accurate description of FSB. Front Side Bus.
Scroll further across. You will see 20x. This is the Multiplier. (Look up)
Lastly scroll across a little further. You will see 84W.
This stands for 84 Watts.
Your processor operating at maximum load, uses 84 watts.
Why do I suspect the power supply?
Because it's the number 1 thing to fail in a computer.
Electrolytic Capacitors fail inside, or are failing.
They have Electrolytic Paste inside them.
The paste has developed a gas, (Hydrogen gas), and has popped seals for the capacitor's case.
This results in Electrolytic Paste slowly oozing out of the capacitor, and resulting in the capacitor failing, or has failed.
Electrolytic Capacitors are used as Filters in a computer power supply. They filter the incoming AC electricity from your house, and the outgoing DC electricity made from the power supply.
When capacitors are failing, or have failed, they create a bad power rail.
There are three main power rails in a computer power supply.
1) The 3.3 Volt power rail
2) The 5 Volt power rail
3) The 12 Volt power rail.
With a weak power rail due to failing capacitors, or a bad power rail due to failed capacitors, you do not have enough power to turn the processor on.
Solution?
Use a known, good, compatible power supply for a test. If the power supply is found to be bad, replace it.
Questions?
Dec 20, 2009 | Biostar P4M80-M7 Motherboard
My AMD x4 processor problem with gigabyte motheraboard
please load windows xp 64 bit . it will work well.
also check the temperature of motherboard and processor in bios
if temperature high use good heat sink and cpu fan .
Sep 19, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
What are the compatible processor for asus p5p800 mx
Asus P5P800-MX Motherboard Features
64bit CPU support
64-bit computing, the next generation technology to replace current 32-bit architecture, delivers advanced system performance, faster memory access and increased productivity. This motherboard provides excellent compatibility and flexibility by supporting either 64-bit or 32-bit architecture.
Intel EM64T
Intel EM64T (Intel Extended Memory 64 Technology) allows processors to run newly written 64-bit code and to access larger amounts of memory, which delivers exceptional graphic performance and higher data processing speed. Digital media applications can take advantage of Intel EM64T in high quality video and audio processing as well as 3D rendering.
Intel EIST
Intel EIST (Enhanced Intel SpeedStep technology) automatically adjusts Intel 64-bit processor voltage and core frequency according to system performance demand, establishing a self-managed, lower-power consumption, less heat and quieter environment. Combined Intel EIST and ASUS Q-fan technology (adjusts fan speeds according to system loading), this motherboard provides excellently quiet, cool and efficient platform for Intel lovers.
Intel 865GV chipset
Leveraging the Intel 865GV chipset to support P4 CPU on 800MHz FSB, Dual-channel DDR 400 memory, Intel Hyper-Threading Technology, and a full-range of advanced features, P5P800-MX really delivers a full-value, high-performance solution for today's most demanding tasks.
Intel LGA775 Pentium 4 CPU
This motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800MHz FSB, 1 MB L2 cache, Hyper-Threading Technology and core-speeds up to 3.6GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date.
Jul 27, 2009 | ASUS Computers & Internet
REPLACE FAULTY CPU CELERON 3.06GHZ WITH PENTIUM 4 CPU
Your motherboard specs are at http://www.foxconnchannel.com/product/Motherboards/detail_spec.aspx?ID=en-us0000152
Looks like you could go up to a 3.8GHz P4, make sure you get a fan that will cool it properly.
Dec 28, 2008 | Foxconn 661FX7MF-S Motherboard
Pentium D problem
Hi oilian,
Be glad it did shut down. If it didn't, your new CPU could haveover heated. There are a few reasons for a CPU to over heat.
1.) There is no thermal grease or too little on the heat-sink assembly.
2.) The old thermal grease was not removed or the old thermal tape was not removed.
3.) The heat-sink assembly was not cleaned completely with alcohol before applying new thermal grease.
4.) The CPU fan is running too slowly.
5.) The heat-sink fins are possibly filled with dust build-up & the CPU fan can not cool the heat-sink assembly. Boot to the bios & go to Hardware Monitor. There you can check voltage, CPU fan speed, CPU temp & other bios monitored settings.
Good luck oilian!
Mike
Oct 01, 2008 | ASUS P5GC-MX/1333 - Motherboard - micro...
My computer won't start but power supply and Motherboard is okay
if i understand correctly you swapped the cpu to another computer and it did not work... you need to purchase or find another cpu that is compatable with your motherboard.
Robert
Aug 25, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
CPU fan
When you say power is going to the mobo, are
other fans and lights turning on? You also may have forgotten to plug in
the large ATX power cord from the PSU, or the smaller 4-pin rectangular 12V
power cord. Is the correct local voltage setting for your PSU selected (110
or 220)?
Feb 19, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
