Garden Logo
A
Anonymous Posted on Aug 19, 2011
I have a B&S Lawnmower with a 5.0 158cc engine. 6 months old. Engine began reving up and slowing down while in use last month. Now will start after priming engine but will immediately die. It will keep running if I keep pushing the primer but will die when I stop. What is the cause of this.
Kelly
Level 3:
  • Master 3,740 Answers
  • Posted on Aug 19, 2011
Kelly
Master
Level 3:
Answers
3740
Questions
Helped
2163339
Points
12091
Tha smallest pin hole in the rubber of primer bulb can cause the symptom you describe
Try this. (2 people required)
Prime engine
Start engine
Press primer bulb HARD and hold it in. Try to keep your thumb centered to block the internal hole in the carb.
If engine runs normally replace the primer bulb.
If it keeps doing the RPM changes carefully tighten the carb mounting screws. This should resolve the problem.
I can help you with parts sources but need your actual engine number. The 4 - 6.5 hp briggs engines came with 3 different carbs and only the engine number will help resolve which parts you need for your engine.
Engine number would be similar to this:
10T802-0016-B1
Thanks for choosing FixYa, Kelly
Stephen McGuinness
Level 2:
  • Expert 143 Answers
Stephen McGuinness
Expert
Level 2:
Answers
143
Questions
0
Helped
73804
Points
376
The diaphragm between the carburettor and the fuel tank needs renewing.
2answers
2006 Dodge Caravan 2.4L engine... after timing belt was changed other problems.... any ideas what could be the problem?
Never once in your story did you say the vehicle when it was in
the repair shop was actually properly diagnosed,nor was any
testing done that actually found any problems
That is & was the main problem
No one has done anything but throw parts at codes
Common sense tells you most if not all of the parts replaced
did not fail,isn't possible at all
You also keep saying the problem-what problem
Codes have nothing to do with replacing parts at all
Codes as used to test systems that set the codes,that doesn't
appear to have been done
You have to know the problem,when & under what conditions it occurs & the broken timing belt may be some how related
Also the vehicle sat for 5 months with old fuel in the tank
You need a fresh start & a new shop that knows how to test
a vehicle
Have these shops actually gone for a road test before & after
any work was done & looked at data & driven 20 miles or more?
Have you driven the vehicle with a mechanic along for the ride
until it acts up,without that, you have little chance they even care
to get involved,at least the parts installers you have been to
2002 Kia Rio the battery keeps dying while the car is running and the lights keep going down in the windshield wipers running real slow its got a six month old alternator the lights and turn signals go...
Charge the battery start the engine and confirm that the voltage at the battery is about 14 volts with engine running . If not it is likely the alternator is bad or the electrical connections from the alternator to the battery are defective.
A significant drain from the battery can be determined by observing the battery voltage after stopping the engine.
If it is under 12 and continues to drop trouble shoot for battery drain. If you suspect the radio pull the fuse and observe.
05 taurus code p1633 stalls at idle or when slowing down
The KAM circuit for the PCM and the a/c is on the same circuit.
If the PCM does not have memory voltage it will loose the settings every time you turn the key off.
You might want to check the fuses in the engine compartment for a blown fuse for this circuit.
Of course it could have another problem too, such as a faulty idle air control valve.
3helpful
4answers
How often should I change the Transmission fluid, normal driving ? Thank you Gary
It's listed in your owner's manual. Schedule A is normal driving conditions.
SCHEDULE "A"
7,500 miles (12 000km) or at 6 months
- Change engine oil.
- Replace engine oil filter.
15,000 miles (24 000km) or at 12 months
22,500 miles (36 000km) or at 18 months
- Inspect front wheel bearings.
- Inspect brake linings.
30,000 miles (48 000km) or at 24 months
- Replace engine air cleaner filter.
- Replace spark plugs.
- Drain and refill automatic transmission fluid and filter (4.7L).
37,500 miles (60 000km) or at 30 months
- Drain and refill automatic transmission fluid and filter (5.2L/5.9L).
- Drain and refill transfer case fluid.
45,000 miles (72 000km) or at 36 months
- Flush and replace engine coolant at 36 months, regardless of mileage.
52,500 miles (84 000km) or at 42 months
- Flush and replace engine coolant if not done at 46 months.
60,000 miles (96 000km) or at 48 months
- Replace ignition cables (5.2L/5.9L).
- Inspect PCV valve, replace as necessary.
- Inspect auto tension drive belt and replace as necessary (5.2L/5.9L).
- Drain and refill automatic transmission fluid (4.7L).
67,500 miles (108 000km) or at 54 months
75,000 miles (120 000km) or at 60 months
- Drain and refill transfer case.
- Flush and replace engine coolant if it has been 30,000miles (48 000km) or 24 months since last change.
- Inspect auto tension drive belt and replace if required.
82,500 miles (132 000km) or at 66 months
90,000 miles (144 000km) or at 72 months
- Inspect auto tension drive belt and replace as necessary.
97,500 miles (156 000km) or at 78 months
105,000 miles (168 000km) or at 84 months
- Flush and replace engine coolant if it has been 30,000 miles (48 000km) or 24 months since last change.
112,500 miles (181 000km) or at 90 months
120,000 miles (192 000km) or at 96 months
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Poulan Pro lawnmower (Briggs and Stratton 128 cc engine) will start when primed but will not stay running. New Lawnmovewr, < 3 months since purchased at Walmart
IF IT IS A BRIGG & STRATTON ENGINE YOU CAN GO ONLINE TO BRIGGS & STRATTON.COM AND ASK THEIR TECH SECTION ABOUT THE PROBLEM. FOR 3 MONTHS OLD SOUNDS LIKE DIRT OR WATER MAY HAVE GOTTEN INTO THE TANK. WHEN YOU PRIME THE MOWER YOU ARE FORCING GAS INTO THE CARB AND ENGINE AFTER THAT THE ENGINE SHOULD PULL THE GAS IN THE ENGINE, I WOULD SAY THE CARB MITE NEED REBUILDING BUT NOT AT 3 MONTHS
2answers
1993 Goldwing Aspencade With Slight Engine Miss??
could be a out sinked carb or gum from sitting gas won't last long
91 oldsmobile cust cruisr, shuddering, engine loping
do u have a OBD 1 scan tool? try and find one on ebay for your car, I sold mine some time back, was $400 new got $50 for it, but I fixed allot of problems like yours because it allowed me to look at real time engine data going to and out of the engine control computer (ECM)
Top Garden Experts
Jay Finke
Jay Finke
john h
