Question about Dishwashers
1E error Lg Dishwasher LD 14AW2 - need guru advice
Water intake error message (1E), but water is pumping in, and will drain when machine turned off and started again.  however, will not pump away mid-cycle - does this sound fatal?
  • mcintosh25 Apr 28, 2009
    i had motor replaced last year now having same problem should i get a new dishwasher
  • 641 Answers
SOURCE: Dishwasher LD-14AW2, stopped working mid cycle
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Posted on Sep 15, 2007
  • 10 Answers
SOURCE: LG LD-14AW2 (03 error)
agreed O3 is not a LG error code. OE is more likely and if so it could be the main pcb faulty, a blocked drain pump or a blocked spigot under the sink where the drain hose connects onto.
take care.
Posted on Jul 22, 2008
ginko
  • 19396 Answers
SOURCE: LG ld-14aw2 dishwasher
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
Posted on Jan 31, 2009
MNTECH
  • 1543 Answers
SOURCE: 1E error LD-14aw2
I do not have specific info on your model, as I believe it is one not intended for USA distribution (where I am at) but, you might want to check the following, which applied to some LG dishwashers produced between Jan or 2005 and Feb. or 2007.
The black mastic sound insulation material inside the dishwasher door can soften from the heat inside the dishwasher, allowing the wires inside the door to become embedded in it. If this has happened, the insulation on the wires can soften and begin to dissolve, resulting in shorted or broken wires. This may cause various error codes which may send you on a wild goose chase.
Take the screws out of the door and inspect the black insulation and the wires. If any wires are embedded in the black mastic, you may cut them and bypass them with a new section of wire, then make sure to add an insulating material to separate the wires from contacting the black mastic. In severe cases, the inner door panel must be replaced (they no longer use that type of mastic) and the wiring harness for the dishwasher would also be replaced. (a set of all the wires and plugs).
Posted on Aug 25, 2009
SOURCE: LG Dishwasher
Had a similiar problem I tried reducing water pressure from water inlet (external to dishwasher) and this worked to a certain degree, although may result in being unable to fill, if you turn down too far. Water silencer (try plumbing stores) was fitted between mains and dishwasher and this fixed the problem.<!-- from fixya rte -->
Posted on Aug 17, 2010
Error code 1e on lg dishwasher
You have some water problems.
Check the intake water solenoid, do you have water in the washer?
If yes, check the drain house and pump
Mar 14, 2013 | LG LDF7932ST Dishwasher
LG dishwasher LD-14AW2 starts up & tries to drain for about 2 mins & then the alarm comes on. The wash, rinse & dry lights are flashing. The hose is raised and not blocked because we can blow...
Hi Jeff - am not too savvy with LG - am a Electrolux/Miele serviceman is it possible to gain access to the drain pump from inside the unit? I think it does sound like there is a restriction somewhere perhaps the pumps not running freely.
To check you pour water inside , take the drain hose , operate machine to see how good the flow of the drain is, rule of thumb if you cover the outlet no flow then the problem.
hope this is a start..
Jun 17, 2011 | LG 24 in. LD-12BW5 Free-standing...
1E error LD-14aw2
Aug 25, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
My husband has just installed a LG LD 14AW2 which was given to us
OE = Outlet Error It involves everything related to pumping the water out. Easiest is to start at the drain and work back. Check for a plugged drain. then a kink in the drain hose. A plugged hose?
If problem remains, remove lower rack and unscrew/remove the filter from the sump area, looking for debris. Rinse out any filter in the mesh filter. Look again for anything that is blocking the drain outlet. Reassemble and run a cycle.
If problems continue, the probable cause is a failing pump motor. Servce call time.
Good Luck!
Mar 30, 2009 | GE GSD5920 Dishwasher
LG dishwasher not working showing 1F in timer display
I am not aware of an LG code 1F. But there is an error code "1E"
After you double check that the water valve is open that feeds the dishwasher, focus on the inlet valve (solenoid)
As you remove the inlet valve, if you see the screen is filled with gunk, clean it and retest.
Good Luck!
Feb 28, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Possible cause:
Remedy:
Aug 26, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
Sep 15, 2007 | LG 24 in. LD-12BW5 Free-standing...
E1 Error Message
agreed all LG d/w with E1 is the wash motor faulty.
take care.
Jan 12, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
230 people viewed this question
Top Dishwashers Experts
