Question about Sony KV-9PT60 9 in. Portable Television
It would not power up
I bought the Sony KV-9PT60 TV from CircuitCity used. I think it was one used with their video camera displays. It's marked as 1996 model, it may have been used for 5 years and I have had it in use for 5 years. Lines started coming across the top of the screen distorting the picture this past year. I came home the other night and it would not power up. It acted like it started too, the speaker made that little bit of noise, the power light turned green but within a split second it was off again. I have to press the button a couple of times before it will repeat what I described. When it was working the screen never came up right away upon pressing the power button. I think it did when I first got it. This has been the perfect TV for me and I sure was hoping it would last a couple of more years until HDTV was the only signal broadcast and I could afford to get a HDTV. I'm limited on money, I do not want to buy another TV and sure wish I could get this one repaired easily.
  • 3 Answers
You should open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced or buy a new one. good luck!
Posted on Jan 19, 2006
How do I turn off the "video 1" display in the upper left-hand corner?
With almost any Sony remote with the button marked display this can be done---if left on too long it will burn the image into the screen of the set.
Oct 15, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Suddenly, "No Signal" display when cable box/VCR Connected to UHF/VHF Jack
How long have you owned the tv? You have two options though your best bet is to locate your nearest authorized service center to have the tv repaired.
Thanks,
lee
Sep 14, 2008 | Sony KV-27FS13 27" TV
Who is selling it now?
Found one on eBay
http://compare.ebay.com/like/320545871123?var=lv<yp=AllFixedPriceItemTypes&var=sbar&rvr_id=229497687531&crlp=1_263602_309572&UA=WXF%3F&GUID=0defda6c12c0a02681f586a5ffc75dcb&itemid=320545871123&ff4=263602_309572
May 03, 2011 | Sony KV-9PT60 9 in. Portable Television
I DON'T KNOW WHERE TO PLUG MY DVD CABLE IN TO MY KV SONY TRINITRON- THERE DOESN'T SEEM TO BE ANY PLUGHOLES
Hello
You can connect the DVD player ot your Sony TV in two ways. One way is via AV cable, and the other is S-Video cable. If you use AV cabel, connect the cable's one side ends to output sockets of the DVD player, marked as Audio-L, Audio-R and Video. Connect the other side of the cable's respective ends ot TV's respective sockets, marked as Audio_L, Audio-R and Video. This socket can be located at the back of your TV. If you expects a beetter picture quality, you can connect the TV-DVD by S-Video cable. If you connect it via Audio Video cabe, switch the TV to get AV-1, AV-2 etc, by input selector option. If you connect S-Video cable, Select TV' to recive S-video input via its input selector option. You can do these selections by the help of TVs remote control. OK.
Feb 23, 2011 | Sony KV-36XBR200 36" TV
Chanel numbers and video stay on screen. example the number 3 always on in corner of TV screen or video number always on the screen.
hello, you should press the display button
at the remote control that marked with the i letter or with the ? sign . good luck!
Feb 09, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony KV-20S40 stuck on channel fix
I have just got a kv-20s43 and your best bet is to try to restore settings, here, To reset TV to factory settings, turn the TV on, Then, while pressing the reset button on the remote control, press POWER on the TV. The TV will turn itself off, then back on, the original settings wiill be restored... definition: ch. fix- 2-6: Select when you want to control all channel selection through a cable box. Select the appropriate channel(usually 3 or 4) and use the cable box's remote control for channel selection. VIDEO: select from available inputs when you have connected video equipment and you want your TV fixed to it.
Feb 01, 2010 | Sony KV-20S20 20" TV
Sony KV-36XBR800 Video mode stays on screen all the time
Very easy fix.....just press the "display" button on the remote control so that the on screen display is turned off when you are watching TV.
Jan 29, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Video Labels stay on - Sony TV Model KV-32V16
Press Display / ' i ' button TV original remote and on-screen display will disappear.
I repeat, you need Sony TV original remote to do so, universal remotes do not have such button.
Jan 14, 2009 | Sony KV-32V16 TV
Sony KV-9PT60 9 in. Portable Television Logo
102 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
