Question about Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110 gas model
How to replace timer panel
  • 1 more comment
  • trevsd Nov 01, 2008
    This is great just what I need to fix the problem, however your instructions don't say how to remove the front panel. If poss could you fax me the instructions (01245 459 830) or let me know the link at Rangemaster
    Many Thanks
    Trevor
    This is just what I need, thanks. However you instructions don't include how to remove the front panel, would it be possible to fax me the instructions (01245 459 820) or send me the link at Rangemaster for the instructions
    thanks
    Trevor
    Many Thanks
    Trevor
  • 3 Answers
Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED!
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Posted on Nov 04, 2008
  • tinling Nov 06, 2008
    http://www.rangemaster.co.uk/Siteimages/...
    This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
    Hope this helps! Ovens still working just got to go and buy a wee timer.
I have downloaded the users guide from rangemaster.co.uk which has details of how to change parts & a wiring diagram, Hope this helps. Here is a section..............
5. To Remove Clock
Disconnect from electricity supply.
Remove the Control Panel (See 2). Pull off the timer
control button(s).
Remove the timer/mounting bracket assembly from the
control panel by removing the fi xing screws.
Remove the timer from its mounting bracket by
depressing the plastic lugs on the timer case, at the
same time pulling the unit forward.
Reassemble in reverse order. When replacing leads
refer to the wiring diagram. Check operation of timer.
BEFORE SERVICING ANY GAS CARRYING
COMPONENTS TURN OFF GAS SUPPLY.
Posted on Oct 30, 2008
This is not a solution per se, it's how to replace the clock with a new one. Take note this is for older Rangemaster 110 gas ovens (Leisure Badge)
you require a replacement clock, Part number P035624.
This replacement clock will have 2 white blocks with terminals whereas his original only has one white block on the back.
Ignore one of the white blocks and wire the clock exactly the same as the old one i.e. brown & blue wires to the bottom 2 terminals (either way around, it makes no difference) and the pair of wires which go to the white block on the old one goes to 1 of the white blocks on the new clock.
Setting of the clock involves pressing the minute minder button & cook time button (old clock was set by pressing the cook time & stop time buttons).
Hope this is not too confusing.
Posted on Nov 20, 2008
The ovens in the rangemaster will not work as the timer is not working. The timer will not flash and when it does decide to flash it goes right back to non flashing zero. Can i use the cooker without...
Try putting your grill on low for 30 minutes to one hour the clock should start to flash then leave to flash for five minutes after which press reset. It worked for me on my rangemaster 110 (gas)
May 15, 2011 | Rangemaster 110 (Gas) Kitchen Range
Have leisure rangemaster 110 5487 ng cream. Have totally lost display for clock, timer etc. How do I replace this?
Phone Gas On Spares with model number 5487 followed by the following 6 numbers after 5487 and they will quote you for a replacement Programmer
Apr 11, 2011 | Rangemaster 110 (Gas) Kitchen Range
I have a leisure rangemaster 110 dual fuel cooker. The auto timer has gone wrong. How can I bypass this timer
at the back of the timer/clock there are 4 wires live and neutral to power the timer/clock and 2 others they may be red or orange. safely connect these other 2 together and you are good to go. if you need a new clock email me info@topoftherangeltd.co.uk
Feb 12, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
How do i bypass the clock on my rangemaster 110 cooker
Have had trouble with our timer on our Rangemaster 110 so ordered a new timer only to be credited as it is no longer available. Dont realy want to buy a new cooker this side of christmas, any way of bypasing the timer ?
Nov 11, 2009 | Rangemaster 110 (Gas) Kitchen Range
How do you set the correct time on the rangemaster 110 cooker
Press in either the first and second buttons on your timer (newer types) or the second and third buttons (older types) and while holding them in press the plus or minus buttons to set the time.
Oct 24, 2009 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110
i used the solution above worked great as i never used the clock anway . but instead of removing the whole hob i simply un screwed the front panel 5 scews. pulled the front panel out about an inch and used a pair of long nose pliers to remove the blue wires cliped them together. then just screwed the panel back took about 5 mins.
Nov 01, 2008 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110 main oven does not work
That looks like a problem with the control panel assembly.
Try first unplugging power cord for ten minutes, then plug back.
Press the selector wheel for 5 seconds and see if this reset it.
If that does not work , then you need to replace the control assembly. YYou find diagrams and replacement parts by entering the model number here.
Oct 23, 2008 | Rangemaster 110 (Gas) Kitchen Range
Oven will not ignite
Comment by tinling, posted on Nov 06, 2008 http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
Jul 11, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
How to use the ovens without the clock
If your clock is not working we can repair it for you.
www.appliancetimers.com
Howard
Apr 20, 2008 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110 (Gas) Kitchen Range Logo
3,325 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
