Question about Coleman 2 Burner Compact Gas 425F499G Grill
Burner doesn't turn off
I have a gas burner that sometimes doesn't turn off. Any ideas?
    Novelist:
  • 74 Answers
If the burner stays on and will not go off, the gas valve or furnace limit switch is defective. Immediately turn off the gas to the furnace by turning the inlet valve so that it is perpendicular to the gas pipe. Call your utility company or a furnace repair technician.
Posted on Jan 18, 2006
  • Gene Haynes Jan 17, 2014
    Avery is full of BS
SOURCE:
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
All 4 electrodes spark when only one is turned on
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | GE 36 in. JGP628 Gas Cooktop
Dacor gas range. I'm trying to figure out why it
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 01, 2010 | Dacor Preference RSD30 Gas Kitchen Range
On our 6 burner gas coocktop, the right two burners don't light
May 10, 2010 | Thermador SGS36GS Gas Cooktop
I have a tappan gas range all the burners but one works when i turn it on. You can hear the flow of gas, and the oven doesnt work. what could that possible be
Mar 25, 2010 | Tappan 24 in. Freestanding Gas Range...
The gas burners are not igniting when being turned on??? When the dial is turned the gas comes on but the burner does not lite - no clicking sound? Thanks for any help!
Feb 09, 2010 | Heartland 3635B Dual Fuel (Electric and...
Viking cooktop gas unit ignition clicks on all burners when I use
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire gas range model FGF316WGSH, all burners have gas but neither of the igniters will work when the knobs are turned to lite
Sep 08, 2009 | Frigidaire FGF316 Gas Kitchen Range
Gas burners/electronic ignition
Jan 26, 2009 | Tappan TGF657 Gas Kitchen Range
Coleman 2 Burner Compact Gas 425F499G Grill Logo
442 people viewed this question
Top Coleman Grilling Experts
Paul Carew
Raymond Ramirez
Raymond Ramirez
john h
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
