Gas burners serve as the primary source of heat in a variety of home appliances: water heaters, gas dryers, and gas cooktops and ovens, and-of course-- furnaces and boilers. When the burner fails, most gas appliances are designed to stop working altogether to prevent a gas leak.
As a rule, it's best to have gas burner problems fixed by your gas utility service person or a qualified heating technician, but there are a few steps you can take to avoid paying for a service call.
Most appliances that utilize gas burners need electrical power in order to operate. If the burner doesn't work at all:
1) Be sure the circuit breaker serving the appliance is "On" or that its fuse has not blown. Check both the main electrical panel and any secondary sub-panels that supply power to the furnace or appliance. If necessary, reset the circuit breaker or replace the fuse. If the circuit blows again, there is probably a short in the electrical system. Call an electrician or furnace repair technician or see HERE for electrical repairs.
2) Be sure the appliance's switch is turned on and that the appliance is plugged in (when applicable).
3) Be sure the appliance's power switch is turned on. This may be on the appliance or, in the case of a gas furnace, next to or inside the furnace cabinet. If it isn't on, turn it on and wait a few minutes.
4) Be sure the thermostat or heat dial is set properly.
5) If the appliance has a pilot light, be sure it's working.
6) If none of this works, call your gas utility or an appliance service technician.
I have a 2-year old 3-burner Ducane grill (model #30731202) that is not burning at full capacity....
(More)
I have a 2-year old 3-burner Ducane grill (model #30731202) that is not burning at full capacity. All of the burners have all of sudden started to burn at about 1/3 capacity (top temp is around 200 degrees). I have replaced the gas lines, including the regulator. I have also replaced the tank and it's full. And lastly, I have scrubbed all 3 burners and removed all external dirt and debris. It would clearly appear that the burners are not getting enough propane, but I feel that the problem must be closer to the source rather than thinking that all 3 burners have becomed clogged at the same time. I would be grateful for any advice. Thank you!!
Hey There- Have just purchased a Luhr Jensen Little Chief Smoker 2nd hand only the cord provided is...
(More)
Hey There- Have just purchased a Luhr Jensen Little Chief Smoker 2nd hand only the cord provided is the wrong one??? Would you know where I could get a replacement cord?? I need a 220v cord for New Zealand.. Any help would be hugley appreciated!
When I plug in my George Foreman Grill and turn it on - it shows a flashing E and I can't set the...
(More)
When I plug in my George Foreman Grill and turn it on - it shows a flashing E and I can't set the temperature using the arrow keys to get it to preheat. What's the problem?
I put fuel in the tank, pumped with my finger on the hole, turned on the gas and held a match but it...
(More)
I put fuel in the tank, pumped with my finger on the hole, turned on the gas and held a match but it will not light.
