Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Banding Just changed both cartridges and when images onto ordinary A4 cartridge paper I'm getting banding running across the image (about 20 of them per four inch print). I've recalibrated and deep cleaned (twice). I believe the problem is with the black ink cartridge as text suffers from this as well. Any ideas what might fix it?
  • awbre Sep 08, 2008
    I'll give Kodak a call, I think, as you say, it probably does need a new printhead.
    Problem Solver:
  • 13 Answers
Try running a deep clean and after the clean, calibrate the printer. If that doesn't work, call kodak tech support, you may need a new printhead.
Posted on Sep 08, 2008
Why is my printer missing lines
I think you need to change your ink cartridge.
Jan 24, 2015 | Brother MFC Office Equipment & Supplies
Xerox Phaser 6110 Banding Cure
As usual, my Phaser 6110N (light use, home office network duty, printed less than 2000 pages in the 4 years or so I've had it) developed a banding issue. Rather than invest in a new toner unit, I decided to take it apart and have a look at it. What I discovered is the toner feed mechanism was clogging up and not distributing toner to the imaging drum.
This is a messy job, I did it in the bathtub (dry of course!), and it's simply a case of removing the side covers from the imaging unit (I'd recommend putting the drum in a thick black plastic bag to prevent overexposure) taking care not to lose any parts, and sliding the toner feeders out of the unit. You can then remove the top cover and it will allow you to clean out the mechanism with a small dry paintbrush.
Remove just enough to de-clog the mechanism, and especially the feed conveyor at the back - this takes toner from the cartridge and feeds to the roller screws that feed the imaging drum.
If you've only got banding problems with one colour, only de-clog that particular colour. It's messy and no point wasting expensive toner! Black and red where problems for me, in both cases the conveyor mechanism was chock full of toner and there was very little in the feeder roller screws.
Re-assemble the imaging unit and run a couple of test patterns through the printer. You'll probably find that the first few pages are especially faint - when you first power up the printer from new, it fills the feed mechanisms from the toner cartridge, I haven't found a way to make it do this again (maybe someone can hack together a maintainence firmware update?). The more you emptied from the feeder, the longer it'll take to even it up. Once it's got the page mostly covered, you're back in business.
After I'd done all this, my banding problem went away! Of course, the bath was covered in toner dust and it took a while to get rid of it all!
on Jul 07, 2011 | Xerox Phaser 6110 Laser Printer
Z6100 banding verticle in black
When you banding vertical do you mean Across paper feed direction OR With paper feed direction?
If its across the feed direction the chances are thje issue remains with the individual printhead, Print out a quality maintenance print to find which Printhead is not working as well as wanted, then replace ( or clean using the plotters control panel under image maintenance.
Errors along the feed direction can be down to Software/ Main Pca /
Mar 11, 2014 | HP DesignJet Z6100 Wide Format InkJet...
Thank you Kitty but I'm not clear on how cleaning the Print Heads and replacing toner would fix this faded banding issue. I printed long Vertical bars of Magenta, Cyan, Yellow and Black. All colors fad at...
you need to clear the rollers and the heat drum (fixes the image and melts the toner onto the paper) if you have done any two sided copy, or have used paper with an image on one side, the ink may have gotten onto the roller and left a trace which would account for the banding being in the same place all the time. the rollers and etc are difficult to get at, and not really a job for amateurs
Mar 10, 2011 | Samsung Office Equipment & Supplies
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Banding when I print in colour... how do I correct
You have to check the settings given to the printer first then confirm whether the toner cartridge of the printer is still good. Thanks
Sep 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Phaser 7700 steaks on Magenta, sometimes yellow.
Each color has its own laser. Use the cleaning wand in the front door to clean the lens covers for each color. You will need to remove the waste toner cartridge in front of the the slots to do this. If that does not cure the problem, you will need to replace the developer housings for the colors that are streaking. The manual can be downloaded at:
and parts purchased at:
Dec 12, 2008 | Xerox Phaser 7700 Laser Printer
Horizontal banding on prints
try aligning the print heads before cleaning them
Oct 10, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Lines on page
The effecds like 'banding' very often this happens when the ink is running low.
When you say 'full color' do you mean at the 'best' [i.e. most ink used] setting or the you are printing the image on a full sheet of paper?
How do your images appear when you print small, say wallet sized, single image only on the page? draft mode? Gray scale?
Jul 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Image quality
Not my area of expertise,but maybe a change
in ink cartridge or material is in order
May 17, 2008 | Xante PLATEMAKER 4 Laser Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
100 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
