FixYa.com
Tags:
Coleman 2 Burner Compact Gas 425F499G Grill
Pilot goes out
posted by Guest on Jan 18, 2006
The pilot of my gas burner won't stay lit, what do I do?
Best Solution
posted on Jan 18, 2006
Thanks for Trying (70)
nagev
Rank:Wiz Wiz
Rating: 76%, 2346 votes
If the pilot won't stay lit, the thermocouple may be loose or faulty, the pilot orifice may be clogged, or the pilot light's flame may be set too low and needs to be adjusted.
You can clear a clogged orifice with a piece of thin wire, such as a bread tie with the paper stripped off of it. Be sure to turn off the gas to the furnace first! Also shut off the switch or circuit breaker that controls power to the furnace. Just poke the thin wire into the tiny orifice where the pilot flame normally burns to knock off any ash or debris.
Some pilots have a flame adjustment screw for adjusting the flame. To adjust this, refer to your owner's manual. Normally, this is simply a matter of turning the flame adjustment screw to achieve a full, steady 1 1/2-inch to 2-inch flame that doesn't have any yellow in it.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Coleman 5068-700 All-in-One Grill / Smoker Coleman Propane Grill Stove 9921-700 Coleman LG40811E Grill George Foreman GGR50B Grill George Foreman GP100 Grill Kenmore 16223 Grill ACE (THA-2020) Grill
Can you Help with these Grills and Smokers problems?
Grills and Smokers
Jenn Air Grill
Brand new grill. When I turn on... Answer This...
Grills and Smokers
cobb cooker instructions
I brought a cobb cooker and it... Answer This...
Grills and Smokers
burner drop
I have a 6 burner with side... Answer This...
Grills and Smokers
little chief top loader
i need the grills for a little... Answer This...
Grills and Smokers
viking outdoor grill,...
My control knobs and ingition... Answer This...
Repair Service
Find Grill and Smoker Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
