Question about Dishwashers
Fisher & Paykel model dw60cdx1 display showing E6 and first four lights flashing
  • Anonymous Jan 02, 2009
    have same problem error code e6 on fisher paykel dw60cdx1 dishwasher
SOURCE: Fisher and Paykel model RF610
The F24 error show that the sensor in the ice maker is out of normal ranges. The usual fix is to replace the sensor in the ice maker.  Also worth checking it to see is the water to the ice maker has frozen up in the value (switch the fridge off for a day). If the error still exists after that you will need to replace the ice maker sensor. You have a 2 year warranty on these parts so the fix should be free.
Posted on Mar 24, 2009
  • 3230 Answers
SOURCE: Fisher & Paykel dishwasher model dd602 error code F4
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Posted on Jun 26, 2009
  • 784 Answers
SOURCE: F1 Error on Fisher & Paykel Nautilus
It leaked before leading to this.
1- Unplug the power.
2- Dry out the leak.
3- Before taking off the lid seal, check if Lid actuator working by going to diagnostic mode. 4- Select LD.
5-Pull the drawer half way out so you can see the lid going down or not when you turn on by pressing lock button.
6- Press the lock button again to release the Lid.
7- Most the time it is a Lid actuator problem and your seal look good, then you replace the Lid actuator only.
8- If it is a problem with the Lid actuator and your seal look bad then replace all .
Posted on Jul 03, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
TheMobilian
  • 8220 Answers
SOURCE: Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Posted on Sep 08, 2009
Fisher & Paykel ActiveSmart 517L Top Freezer E521TRX3 control panel lights blinking
Hello Ajay Gaddi...
Flashing panel...
I got NOTHING after reading several manuals
(seems to be a UK model... We have limited information here in the USA)...
Accept my apology and try these references
(as appropriate)
If after checking these points you still need assistance, please refer to your nearest
Fisher & Paykel Authorised Repairer, or contact us through our local website listed on the back cover.
In New Zealand if you need assistance...*
Call your Fisher & Paykel retailer who is trained to provide information on your appliance, or if we
can be of any further help, please contact our Customer Care Centre.
Toll Free: 0800 FP CARE or 0800 37 2273
Fax: (09) 273 0656
Email: customer.care@fp.co.nz
Postal address: Fisher & Paykel Appliances Ltd, PO Box 58732, Botany, Manukau 2163, Auckland.
If you need service...*
Fisher & Paykel has a network of independent Fisher & Paykel Authorised Repairers whose fully
trained technicians can carry out any service necessary on your appliance. Your dealer or our
Customer Care Centre can recommend a Fisher & Paykel Authorised Repairer in your area.
In Australia if you need assistance...*
Call the Fisher & Paykel Customer Care Centre and talk to one of our Customer Care Consultants.
Toll Free: 1300 650 590
Fax: (07) 3826 9298
Email: customer.care@fp.com.au
Postal address: Fisher & Paykel Appliances Ltd, P.O. Box 798, Cleveland, QLD 4163
Fisher & Paykel has a network of qualified Fisher & Paykel Authorised Repairers responsible for
servicing only Fisher & Paykel branded appliances. Our Customer Care Centre can recommend a
qualified Fisher & Paykel Authorised Repairer in your area.
In United Kingdom if you need assistance...*
Phone: (0845) 066 2200
Fax: (0845) 331 2360
Email: customer.care@fisherpaykel.co.uk
Postal address: Fisher & Paykel Appliances Ltd, Maidstone Road, Kingston, Milton Keynes,
Buckinghamshire, MK10 0BD
Aug 21, 2017 | Fisher Refrigerators
E6 error code on fisher & pykel single door dishwasher
1-Time Flash & E6 error troubleshooting, part 1 of 3 for ...
? 3:04
https://www.youtube.com/watch?v=sYNN1Rvc7r0
Dec 18, 2012 - Uploaded by MitsubishiHVAC
1-Time Flash & E6 error troubleshooting, part 2 of 3 for Mitsubishi Electric Cooling & Heating - Duration: 2 ...
LG Control Panel Overview
www.lg.com > ... > Repair > Locate Repair Provider
LG ElectronicsAn OE error code indicates the washing machine is draining slowly or not at all. This is usually ... When you see the E6 error icon, it means there is a clutch error.
Nov 19, 2015 | Fisher and Paykel Dishwashers
Getting error code E6 on our Fishare and Paykel dishwasher DW60CDX1. Unsure how old it is, and if it's worth repairing?
E6 is a spill over alarm it basically means it is filling with to much water, it sounds like the water inlet valve is starting to jam open, tell me if you open the door does the water keep coming in? if it does the valve is jammed open which is a relatively cheap fix, if it stops when the door is opened it is likely a pressure switch or flow meter problem or possibly a control board.
Aug 28, 2014 | Fisher and Paykel Dishwashers
What is the flood switch on a dw60cdx1
We had an F1 error with our F&P dish draw,Isolated the power to machine, then I removed the drawer & cover from the flood sensor, Dried water with towel & used hairdryer. Power cycled the unit & has fixed the problem.
Had used a different powder & believe that it created more foam that caused the machine to flood slightly
Jul 03, 2014 | Fisher and Paykel DS602 Dishwasher
How do I clear the error on a Fisher and Paykel DW60CSX1 error message E6
to fix essentially you need to reboot... unplug at wall - wait about 30 seconds - 1 min then replug. should reboot and be back to normal.
if you can, pull drawer out at end of cycle so condensation does not cause this problem going forward... ours does this when it's higher humidity
May 18, 2014 | Fisher and Paykel Dishwashers
Fisher & Paykel Dishwasher DW60CEX1
My Fisher and Paykel dw60cex1 is displaying an error of E6??
Feb 22, 2012 | Dishwashers
E6 fault unable to reset all cycle lights showing
E6 is "Flood switch activated."
Turn the water off and disconnect power to the dishwasher, then empty water from the inside. Clean drain well and check the drain hose at the back. If that does not work, then the water pressure switch is at fault. Call your Fisher & Paykel dealer or Authorized Service Center.
Dec 06, 2011 | Fisher and Paykel 24 in. DS603MFC Built-in...
I have a Fisher and Paykel DW60CDX1 dishwasher, the display originally came up eith an error code for the door, which seemed to be the problem as it restarted with some pressure on the door, then it...
Old question, but for anyone else, hears the answer - http://www.recalls.gov.au/content/index.phtml/itemId/1015047
This model has a product recall, minehas done the same as described above, recall issued Aug 2012.
Mar 06, 2011 | Fisher and Paykel 23 in. DS603H W Built-in...
Numbers flash from one through to four in order on sc233ala model mobility scooter and will not drive
Hi. Is a Fisher and Paykel scooter? While the lights are flashing, press the horn button. The lights will stop flashing and display a fixed pattern, this is the fault code. Once you have done this let me know what it is, and I will be able to tell you what the fault is.Neil.
May 20, 2010 | Health & Beauty
Dishwashers Logo
258 people viewed this question
Top Dishwashers Experts
