Question about NetGear RangeMax WPN824 Router
Rp614 netgear router
After setting up with cd all lights are on router and modem but when i try to go on to internet it saying cannot connect can you help
  • 6,487 Answers
TRy first to power down the mode and router for about a minute then after a minute power back the modem first and wait again for a minute and then power the router back , if all the lights are ON already try to access the internet if still not working you may need to contact Netgear about your router.....
Posted on Nov 05, 2008
TalkTalk Modem Smartax MT882 to Netgear RP614 problem
Well your modem and router IP is same thats why you can't connect your router with modem
your have changed IP of the router,please follow steps to resolved your issue
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm or 192.168.0.1 address bar. press enter
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Hope it can resolved your issue
Happy to help
Thanks for using Fixya
Apr 04, 2010 | NetGear RP614 54 Mbps 4-Port Web Safe...
How to install a router witout the insatll cd
Are you trying to install the router.You can do it manually without the CD.
MAke sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by nstructions
Jan 15, 2010 | NetGear RP614 Router
Netgear Rp614 router is not supported on my windows vista 64 bit os. How can I get it to work?
Hi, follow the steps below to reset and reconfigure your RP614:
RESET:
At the back of the router you will find a small tiny hole (which says restore to factory default settings). Press the button with the help of a paper clip and hold it down for 30 seconds. After 30 seconds, please release the button and power off the router for 5 seconds then power the router back.
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that there is no direct connection between the modem and the computer (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with http://192.168.1.1 or http://192.168.0.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 29, 2009 | NetGear RP614 Router
New router will not hook up to my laptop.
Check your physical connection first. From the modem, it should be connected to the router's Internet port, then your computer must be connected to port 1 on the back of the router. Then do a power cycle, run the setup CD. If it doesn't work, you need to manually configure the router. You may need assistance from Netgear tech support. Call their toll free number
Jun 20, 2009 | NetGear RP614 Router
Router wont connect to internet
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://192.168.1.1 or http://192.168.0.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
From the above configuration, please check if you can now access the Internet.
Apr 26, 2009 | NetGear -DSL Web Safe Router/ RP614 -...
NEtgear RP614 cannot connect after a electricity shortage in our home :(
Reset the router to factory default. Usually done by unplugging the router hold in the reset button and plug in the router wait 30 sec. release reset button Wait 30 more sec. and unplug router again. Then reset your computer to obtain ip address automatically in network properties. Next shut down your computer, router and modem. First re-power the modem, give it time to boot (about 2 to 3 Min. for Cable and dsl or 7 to 10 min for satellite), next re-power the router, again give it time to acquire it's info (about 2 min.) then start your computer and try to access the Internet, all should be well...
Good luck, and have a great day...
Tim
Mar 23, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
The light of internet is orange,not yellow.
The router should have reset button on the back. This will reset it to factory defaults. If you have an ISP that gives you internet without a username and password like rogers then you should be good to go. If your ISP is like Bell then you will need to get into the website of the router and configure it.
Nov 28, 2008 | NetGear -DSL Web Safe Router/ RP614 -...
Netgear Wirless Router
You need to make sure your internet is still working. Its possible the storm caused some damage to the dsl line
Can you plug a normal broadband modem in and connect to the internet?
If you can, then try unplugging your router and plugging it back in, give it a few mins to boot up and try again (if you havn't tried this already)
If still no luck you'll have to do a master reset and set your router back up and try that, however at this point I'd guess the storm killed your router.
If you havn't got a broadband modem that plugs strait in, then ring your ISP and ask them if they've had any problems thier end.
hope this helps
Tony
Feb 27, 2008 | NetGear RP614 Router
How is it not working? You get limited or no connectivity or it isn't functioning at all. Firstly, let's do a power cycle. Push the reset button for 5 seconds, unplug for 45 seconds, and reset 5 seconds, and unplug for 45 seconds. If that doesn't work try a hard reset. Alright, it's time to do a hard reset, this will rest all your passwords, Take a Pen or a pin, push the pin the the reset hole for 45 seconds, Uplug the modem for 1 minute, reset hole for 30 seconds, unplug for 30 seconds, and it should be hard resetted also power cycle.
Aug 25, 2007 | NetGear RP614 Router
NetGear RangeMax WPN824 Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
