Question about APC MasterSwitch Power Receptacle - Power distribution strip- 4 Output (ap95103202) UPS System
Replacing a receptacle
How do I replace a receptacle?
    Novelist:
  • 74 Answers
As always when working with electricity, shut off the power. Use a circuit tester to make sure that the power is really off. Unscrew the receptacle's cover plate; be sure you get a replacement receptacle that's the correct type for your wiring?though most receptacles are standard, aluminum wiring should only be connected to receptacles designated CO-ALR. When installing the new receptacle, connect the black (hot) wire to the brass terminal screw, the white (neutral) wire to the silver screw, and the bare (ground) wire to the green ground screw. Unscrew the receptacle cover plate and unscrew the receptacle. Disconnect the wires from the terminals. Form a curl with a pair of needle-nose pliers so the wires hook clockwise around the screws, then tighten the terminal screws. Screw the receptacle to the box and add the cover plate.
Posted on Jan 18, 2006
My electric Bosh cooktop is humming when the element heats up. Is this normal?
If the noise is emitting from the element the most likely cause is a bad connection where the element plugs into the receptacle. You are likely hearing the voltage/current sparking/arcing between the terminals of the heating element and the prongs inside the element receptacle. When this happen it will require replacing the receptacle and the element because it will burn off the contact points of where the two touches to make the connection. If you just replace the element and not the receptacle too, it can cause the terminals on the new element to burn out. Perhaps get a qualified person to have a look at it - it just may need a service...
May 07, 2017 | Cooktops
How come the burners on my general electric stove
Whenever I replace a block, it doesn't hurt to file or sand the male contacts on the surface burner. Be safe.
Sep 30, 2014 | Kitchen Ranges
Replacing microwave control panel - ribbon cable help needed
Some connectors have a lock.
Jan 30, 2013 | GE JVM1790SK Convection/Microwave Oven
Want to install a duplex switch in a double gang box that currently has a receptical and a single switch. The existing single switch is wired in a switch loop and operates a switched receptacle. I would...
So you're replacing the receptacle in the 2 gang box with a switch that will control a receptacle? If so there's no reason you couldn't use the feed from the receptacle. As long as you maintain the integrity of any existing runs through the box...you're not adding any devices really so there shouldn't be a problem with the branch circuit device count. Bear in mind this stuff has the potential to burn your house down so be real clear on what you're doing and make a good secure job of it. When in doubt call in a pro....
Dec 09, 2010 | Leviton 5224-2 Wall Duplex Switch
Can i fix a Dimplex DS5603 by replacing the plug?
change the plug noting the polarity. one wire in the flat cable has a rib running the whole length, the other wire has no rib. the ribbed wire goes on the brass screw in the replacement plug. the non ribbed wire goes on the nickel shaded screw. the green or yellow/green goes on the green screw. the plug is getting warm because the spring tension in the receptacle is getting weak. any little bit of arcing in the receptacle will create heat.
Oct 14, 2009 | Dimplex Heating & Cooling
Jkp77 heating element is sparking and made popping sounds
HI, the element receptacle may be defective or, the coil as well. i recommend replacing the element and receptacle in this case.
**Test the continuity of the element. if the test is ok, replace the receptacle.
Jul 07, 2009 | GE JKP15 Electric Single Oven
Oil dipstick receptacle broke
VERY common.. best bet before you pay dealer is to try ebay
Dec 26, 2008 | 1999 Volkswagen Beetle
Power failure
Code actually calls for the refrigerator to be on a separate circuit for this reason. you may have a refrgerator that may have a higher voltage spike at compressor start up and that is causing the trip. You can try upgrading your GFCI to a 20amp (most are 15amp). Although you may have to replace with a standard outlet if the problem does not subside.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Jul 28, 2008 | Electrolux 25.9 Cu. Ft. Side-by-Side...
AC adapter receptacle on motherboard
http://www.laptoprepair101.com/laptop/2006/01/28/toshiba-satellite-m35x-a75-power-jack-problem/ Hope this helps a little.
May 19, 2007 | Toshiba Satellite L25-S119 Notebook
APC MasterSwitch Power Receptacle - Power distribution strip- 4 Output (ap95103202) UPS System Logo
82 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Alun Cox
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
