Question about T-Mobile Dash Smartphone
I dnt get it
Wat do you meen a lil bubble like a dent it or something
    Brigadier General:
  • 7,752 Answers
Explain more pls
Posted on Sep 21, 2008
How to remove dent from back door?
Mainly would depend on type of veh. and dent ,just bowl shape or creased line dent that wasn't here B4 so after inteior door panel removed and access to outside body skin is possible . This is where you could push dent using only soft material tools to back and to push with . If dent is bubble shape 5 - 10 inches you can puchase rubber suction puller or stronger glass transport suction tool and pull it out on exterior panel itself.
Paul Douglas
Apr 06, 2015 | Cars & Trucks
Wat do;s Err-80 meen
Looked up on Canon.es and this is what I found.
FAQ: What does the error code 'Exx'?
FAQ ID: 44574
Last Modified: 22-Jan-09
Cause
Answer:
When an error occurs the camera will display an error code like "Exx", where "x" represent numbers.
See the list items at the bottom of this page when it shows following error codes.
"E18" error of the target unit / lens barrel
"E30" and "E50" error of the CF or SD card
When an error code "Exx" different from those already mentioned, the camera off and then turn to try to capture or play back images.
If this error persists or an error code appears often, there was a malfunction of the camera.
Note the error code and contact the retailer where you purchased the camera or the nearest service center for Canon.
I hope this helps
Jan 24, 2012 | Canon EOS-D30 35mm SLR Camera
Hay i have a 1991 subaru gt legacy.the car starts fine but runs a lil ruff,but its wen u give it a little throttle it runs more rrough and then u gve it more and then its alryt.the coil packs r fine and i...
Could be a few things, if you pull the plug wires off the coil and there a little bit corroded and light green in color I would replace your coil. The easiest check is to check and see if the EGR valve and vacuum solenoid are working properly. Locate the EGR valve, It's about 6 to 8 inches from the throttle body towards the drivers side. It looks like a small stepped flying saucer about 3 inches in diameter with a vacuum line going to it. Get something like a golf "T" to fit into and plug the vacuum line once you have disconnected it. Drive the car to see if there is any improvement in driveability. If not, then there are more things to look at but those are the most common. I hope this info helps.
Jul 28, 2011 | 1991 Subaru Legacy
Whn i put a game in my ps3 it just has tht lil bubble spinnin round thn nufin. Wats wrong wiv it
The disk drive is brocken. The same thing happend to me. You need to take it to the shop it came from and they will give you the details of how to get it fixed. It will be sent to sony and you will have it back soon. Unfortunaitly you will probably lose all your game data like I did.
Nov 22, 2010 | Sony Playstation 3 (PS3) Console
I have a 1987 4 door jeep cherokee chief it will
check ur fuel pressure i should be about 39 psi with hose off and about 31 with hose on if its lower then that take the cap off the gas line its a lil black cap and inside it looks like a stem for a bike or tire on truck turn key on and push stem in if it sprays alot of gas then idk but if it doesnt then u need a new fuel pump had same problem but mine was fuel pump and ignition switch maybe swap out ur ignition switch under ur steering wheel column its a lil black box with about 7 prongs on it when u disconnect if that dont work get some soap put around ur hoses and see if u have a leak soap will bubble if u do u will have to crank it til u see bubbles its just a few ideas
i have a 87 jeep cherokee chief straight six w/lift pre-runnered out
Jul 22, 2010 | 1987 Jeep Cherokee
E 76
Just try searching RROD in google and you'll find exactly wat you need to fix this problem, best of all most can be downloaded for free and u will only need a set of small screw drivers and torx bits and the repair kit from ebay will cost you between £2 and £3.
Mar 27, 2010 | Microsoft Xbox 360 Console
1988 mazda
Probably the timing belt just like you think.
Feb 25, 2010 | 1988 Mazda B2200
Please Help me set up internet
first off when you plug in your ethernet cable to the PS3 before you turn it on unplug your modem for like 2 mins after you plug it back in wait about 1 min then power on your PS3 then look for something that says create user, or new account you should be able to just hit X on it and it will walk you through all the steps. you will need a valid email address. if you still can not get it then your user guide that came with your PS3 should tell you just how to do everything. if you dont have a user guide then go on www.us.playstation.com and on the top right hand corner of the screen is a "search playstation" type in user guide and it will give you an online user guide. good luck
Sep 28, 2008 | Sony Playstation 3 (PS3) Console
Dnt have ym can u come at gtalk?????
wats ur email add? i can send it there
Aug 21, 2008 | Nokia 6600
T-Mobile Dash Smartphone Logo
22 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
