Question about Hotpoint Aquarius WF000 Front Load Washer
Door seal how do i replace the door seal for a hotpoint aquariue wf440 thanks paul
    President:
  • 1,462 Answers
Switch off from mains
remove outer clamp holding door boot to cabinet and peel off door boot.
remove work top
there is a clamp holding door boot to tub. undo clamp and pull door boot away
lubricate slot in door boot that goes on to the lip of the tub using washing up fluid
starting at the top, insert lip of tub into slot in door boot. working both ways round, push door boot onto lip
fit outer clamp
push door boot on to lip of the cabinet and fit clamp.
test for leaks on a rinse cycle (water level is higher) water will be a bit foamy till washing up fluid is washed away
easy job but needs a bit of patience so go for it
Posted on Sep 07, 2008
Hotpoint AQCF852BU Condenser Tumble Dryer
how do i change the belt on my hotpoint aquariue ctd00 model ctd00p
Oct 22, 2010 | Dryers
How to replace door seal part number 1603291 on hotpoint washer
Hi -Can I myself replace and repair a seal on a bosch front loader? Thanks for your help and your time!
Thank you,
Linda
Nov 17, 2009 | Washing Machines
Hotpoint aquarius wf440 : my washing 'smells' after a wash so think filter needs changed/cleaned; where is it located, have lost my manual?
if i were you i would buy some detergent that cleans washers in the normal wash cycle without no clothes in it then you will find that the smell as gone,do this regular once a month to keep all the pipes fresh.rgrds,paul
Jul 07, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Problem with wf440 hotpoint
check to see if door is locked may be interlock
Dec 19, 2008 | Hotpoint Aquarius WF000 Front Load Washer
E30 flashing when I try to start wash program on Hotpoint Aquariu
E30 indicates a motor problem, you will need to call an engineer.
Possible worn brushes which you can do if you know what you are doing.
Nov 24, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WF440 Repalce Door Seal
no need to remove front panel
remove clamp that holds boot to cabinet and peel away boot
take top off
undo clamp that holds boot to tub and pull boot off
lubricate slot in new boot that goes on to lip of tub
starting at top, insert slot onto lip of tub and work your way round in both directions pushing slot onto lip
refit clamp
push door boot onto lip of cabinet and refit outer clamp
test on rinse cycle for leaks (water level is higher
water will be a bit foamy till fluid is washed away
Sep 06, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Door seal replacement
should be held on by a sprung ring round it. prize it off with a screwdriver and pull the seal towards you.
Aug 18, 2008 | Hotpoint Ultima WD72 Front Load...
HOTPOINT AQUARIUS WF440 BEARING REMOVAL/REPLACEMENT
Are you talking about the main tub bearing?If so I dont recommend replaceing this bearing,because the problem will only keep repeating itself.
May 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wma46 door lock
make sure door seal is fitted correctly to the cabinet. you may find that all that is required is to push the door harder than usual till the seal beds in
Mar 29, 2008 | Hotpoint WMA46 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
271 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
