Question about Apple MacBook Mac Notebook
MacBook Repair Application
Having problems installing a macbook application, I get this message -
"You can not open the application … because it is not supported on this system"
The application ends with ".sea", so I think this might be the problem, what can I do to repair this?
If it is not what benz06 said then it may be a classic application. If you are running Leopard than classic applications no longer run which may also give you that error message.
Posted on Sep 17, 2008
How do i reset my note book
Posted on Sep 14, 2008
  • 21 Answers
I believe you will need to download Stuffit Expander. We used to use SEA files a lot in the old mac days, but now they've been replaced by the DMG file. Anyway, Stuffit has a free version that can be found here. Since they don't make it extract itself on the new Macs, you need a program to do it now. If that doesn't work, you might have a corrupt file or something else. Let me know what happens.
Posted on Sep 07, 2008
How do i get acu edit for my macbook. i have the janome 500E
contact Janome they might have the proper software you need .
Apr 12, 2016 | Janome Sewing Machines
I cannot open iPhoto on my MacBook, missing python framework. Will allow remote access using TeamViewer for help.
It looks like your version of iPhoto may not be compatible with OSX 10.9.5.
Can you check which version of iPhoto you have installed... go to Applications, select the iPhoto icon, press the "command" and "i" key at the same time, and see what it says under 'version'...
I would suggest launching the App Store application and checking for any updates, especially anything to do with iPhoto.
If you've updated iPhoto but the library is an older version, then this may help:
https://discussions.apple.com/thread/6469058
Oct 11, 2014 | Apple MacBook Mac Notebook
I cant track my macbook. do i need to install a gps device?
Check out LoJack to see if it can be installed on the computer. If it ever gets lost that can locate it and shut it down and even erase the hard drive if necessary
Mar 20, 2014 | Apple Macbook 13 Inch A1342 2.4ghz Mac Os...
My macbook air cannot preview anything by its Preview application. i cannot open iphoto. when i start, if i open Macintosh HD or any other folder on Desktop then I cannot open system preferences and vice...
I would start by attempting too restart. If this does not fix it, open Disk Utility (Applications -> Utilities -> Disk Utility). From here click verify permissions and then verify disk. If either of those come up with errors, then click the corresponding solution (repair permissions or repair disk). This should solve any problems you are having, but if it does not, Insert the USB drive that your MacBook Air came with and reinstall the OS. Good Luck!
Dec 26, 2010 | Apple MacBook Air
There is a small little coloured ball that comes on my computer and then it freezes while I am playing a game
Thanks for contacting Fixya Support.
Anytime you see the "rainbow pinwheel" which does manifest itself from time to time in Mac OS X environments, this is an indication of either a software issue or even a hardware issue.
Considering you are playing a game, it would be safe to assess that this issue you are having is in relation to the game you are playing (being unresponsive), means that this is a software issue.
There are several variables in regards to fixing issues with the spinning pinwheel in relation to a software.
If your application is not responding, you can first of all Force Quit the application by selecting Apple Command, Option and the Esc keys, and either select the game application in the window, which should be displayed as "Not Responding" and Force Quit or select Finder and simply relaunch it.
If you are unable to get your Mac OS X system to respond at all, then try a PRAM Reset process as shown below:
--PRAM RESET --
• First, hold in your power button for approximately 10 seconds to do a hard shutdown, if you have not already turned your Mac off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
This should help with the freezing issue:
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the startup sound for the third time.
• Release the keys and allow the Macbook to start up.
--Check to see if you are able to launch and play your game now.
If neither of these steps work, then if you have your Mac OS X installation disc which came with your Macbook, then I would finally recommend you perform these steps below with the installation (Macbook Restore) disk:
-RUN DISK UTILITY WITH MAC OS X INSTALLATION or RESTORE DISK-
Insert your Mac OS X Startup disk (Note: make sure the disk contains the same Mac OS X platform that your Macbook is currently running)
•Reboot your Mac
•At the Apple Chime, press the C key and hold it until you see a White screen, gray Apple and eventually a Spinning gear.
• Release the C key only after you see the Spinning gear.
•Mac will boot from the startup disk to the Installer environment
• From the Installer Menu bar, click Utilities > Disk Utility and open up Disk Utility application.
• Click on on the hard drive at the top of the window in the left sidebar and
• Select "Repair Disk"
**Let Disk Utilities run this repair the disk until completion
• At the end of this process, reboot your Mac
Now attempt to run your game application and see how your system responds after the Disk Repair process.
If the Macbook still persists in freezing or the game application still causes the spinning pinwheel to appear, then you may need to increase your Macbook's RAM memory, as the game may require more memory resources than you current have installed with your Macbook, or it may not be compatible with the current version of Mac OS X you are running with your Macbook.
I hope these steps point you in the right direction.
Regards,
-Mactechtrainer
Aug 20, 2010 | Apple MacBook Mac Notebook
Can't open or edit a doc. file from PC on MacBook air
You need to have installed MS office for Macintosh in order to open .doc files.
Feb 24, 2010 | Apple MacBook Air
Wacom Graphire 4.40 Install question
Make sure you have no old Wacom drivers installed in your applications folder. If you do, then you will need to uninstall each driver via the "remove tablet" utility.
Oct 13, 2008 | Wacom Graphire4 Digital Pen
Apple MacBook Mac Notebook Logo
112 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
