Question about Whirlpool Dishwashers
Whirlpool Dishwasher Model ADG 7560 Unit is only 2 weeks old. Program cycle starts, runs for approx 30 seconds then stops. This is an intermittent fault, sometimes it works OK
  • Anonymous Mar 28, 2014
    Turn on whirlpool dishwasher and 30 seconds later it turns itself off
Found outlet pipe was kinked, stopping water flow
Posted on Sep 09, 2008
Whirlpool integrated dishwasher model ADG 7460 Have run the engineer test cycle and it stops and drains water after 2 mins; start light blinks 5 times.
F5 or 5 times flashing.
Variable speed motor failure.
- Connection between Spray pump (Variable speed motor) and control board interrupted.
- Frequency converteron Spray pump broken or control board defective.
= Check the power voltage on the motor. BUS: 5V DC, Motor: 230V AC
Reaction: Cycle stops, drain pump drains out,failure indication.
SPM blocked (MPH motor unit)
Failure condition:
- This failure is only indicated during the active test program
- The electronic detects an irregular deviation of the motor current consumption.
Spray pump blocked = check pump housing
Short circuit in motor or wiring = check motor values
Reaction: After 5 attempts to reactivate the spray pump motor the cycle stops, drain pump drains out, failure indication.
Sep 03, 2015 | Whirlpool Dishwashers
Why Whirlpool ADG-6558/1 IX stops sometimes the wash cycle after 15/30 min?
reset the panel by hitting normal-- heat dry NOT at the same time until all lights flash then push cancel and it should start. element is going bad
Jun 02, 2014 | Whirlpool Dishwashers
Whirlpool dishwasher 1 year old model adg 7560/1 - green start light flashing and beeping - will only do rince cycle
I have exact same problem with mine. Had Engineer out to tell me it requires new motor. The total cost would be €260. He blamed sand in water as we live near sea. By the way mine survived for 2 1/2 yrs with fairly gentle use
Dec 19, 2010 | Dishwashers
I have a Whirlpool integrated dishwasher ADG 7560/1. Can you tell me if there are any points where it should be screwed to my kitchen unit sides or surface to stop it moving when I open the door. Thank...
There should be two metal tabs on top of the exterior cabinet that you use to screw the dishwasher to the underside of the kitchen counter top. The feet are also adjustable on most models so they are not only level, but also to make the unit fit better inside the access opening under the cabinet where it is installed.
Aug 13, 2010 | Whirlpool Dishwashers
Decor door help for Whirlpool ADG 7560/1 integrated dishwasher
call for service to change the outer takes about 15min.
Feb 24, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Whirlpool dishwasher stuck on prewash cycle
the eprom memory is brocken,the main board must be changed.
Feb 14, 2010 | Whirlpool 24 in. ADG7952 Built-in...
We have a Whirlpool ADG 7560 dishwasher which has recently started playing up. When switched on for a normal wash, after a short time the machine starts to beep. If you open the door the green programme...
Sounds like something is becoming intermittent, but after the system warms up, the connection "holds." These are difficult to troubleshoot until the unit actually stops working. If the unit is in warranty or you have a service contract, it's definitely worth a call to your service center and schedule a home visit.
Sep 21, 2017 | Dishwashers
I have a whirlpool dishwasher (gu2500xtpq6) wont fill up
water level should be approx 1/4--1/2 inch below the heating coil.. this is normal fill level
Apr 28, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwashers Logo
1,083 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
