Question about Acer Aspire 5580 Notebook
Acer 5580 Bluetooth and USB port problem
Had my motherboard changed due to a failing graphics card by engineers at Acer Service Centre. After the change, the bluetooth failed. Basically when u flick the catch on the laptop to switch the bluetooth on, it says no device and you cannot find the bluetooth in the device manager. However the bluetooth driver is still running.
There is also now a msg that pops up at startup that says unknown device detected in USB port and is missing a driver. The problem is there is no device plugged into any USB port.
Finally very often a msg will pop up during usage that a USB port has malfunction and needs to be replace.....
This is my 6 repair for my Laptop since getting it last April... and they just refuse to entertain my request for a new laptop. Really pissed as it seems that the set I have is one of those defect sets. 2 dvd drive changes, 1 OS reformat, 2 LCD changes and 1 Motherboard change....
  • 1 more comment
  • shihabv Nov 23, 2008
    the same problem
  • tmnn Jan 06, 2009
    yes i have the same two problems related to bluetooth and usb port.i gave that to service centre and no results came up.m greatly irritated by the sound of the usb port notificatioin..
  • Anonymous Jan 09, 2009
    I don't know what is USB\VID_046D&PID_0896\5&1EA0B166&0&7
    Master:
  • 461 Answers
There may be a bent connector on one of the USB ports or a defective USB controller on the motherboard. The bluetooth connector may not have been reconnected or the bluetooth module was not reinstalled after service. Sadly you will need to have it serviced again. They most likely will not replace it it with a new laptop, but maybe a refurbished one. You could push for a warranty extension for amount of time the system has been due to need of repair. Good Luck.
Posted on Dec 06, 2008
Is it noisy the Aspire ATC 605 UR13 and is it a some what good gaming pc
This would be a great system if it had a dedicated graphics card. Based on the specifications you've listed, it appears it doesn't have one.
Have no fear, any current generation PCI 3.0 graphics card will fit in it.
Hope this helps!
Sep 16, 2014 | Acer Computers & Internet
I have Acer Aspire 5580. I am facing problem with the graphic, it is showing lines and color patches. When i am extending the monitor to external display, the external monitor is showing nice graphics. I...
if you changed the screens to a working one, then you should have a clear image on the main screen, or its damaged, or one of the monitor ribbons is not seated properly. have you updated your graphics driver?
Sep 19, 2017 | Acer Aspire 5580 Notebook
Usb port issues
You could try uninstalling the USB items in Device Manager and allow them to be reinstalled. Also verify USB is enabled in the BIOS.
Dec 06, 2008 | Acer Aspire 5580 Notebook
All USB ports not working
Sounds like a shorted out board. If you use a faulty device.. these can EASILY short out the USB controllers on the motherboard.
Alternative is to purchase a "PCMCIA USB expansion card" till you can replace the motherboard.
best wishes.
www.techvisitor.com
Oct 30, 2008 | Acer Aspire 5100 Notebook
Acer 5100 usb ports,Cam,PCMCIA
This happened to me before - I have an Acer Aspire 5100. I had to take it to Acer (it was under warranty) and they changed the motherboard. Hope this helps =)
Sep 18, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5580 unable to powr on
hello!
Try check the power cable to for connection, Please sure that the cable transformer is not busted. If ever the cable is good then, something wrong with input power of the laptop, guess that the fuse blown. please open an check the power line from input to all the connection inside. If affraid to do so, then you can contact your vendor, im sure they have a tech to fix your problem. If not then i am ausre you that the know the service center of your laptop. Kindly verify your manual, i guess the toll free is listed there.
May tis help:
best regards, Melnavz
Feb 23, 2008 | Acer Aspire 5580 Notebook
Acer TravelMate 4020 Blutooth
does not have ! Look at the "communication" tab
Acer TravelMate 4020 Notebook Specification:
Operating System Linux BE (Basic Edition) Platform Intel® Pentium® M processor 725 (2MB L2 Cache, 1.6GHz, 400MHz FSB)
- Intel® 915GM Express Chipset
- Intel® PRO/Wireless 2200BG Network Connection 802.11b/g Memory 256MB DDR2 SDRAM, upgradeable to 2GB Display 15.4" WXGA TFT LCD, 1280 x 800 pixel resolution Graphics Intel® 915GM integrated 3D graphics, featuring Intel® Graphics Media Accelerator 900 and up to 128 MB of shared memory, supporting Microsoft® DirectX® 9.0 and dual independent display Audio Audio system with built-in speakers
MS Sound compatible
Built-in microphone Storage 60GB ATA/100 HDD Optical Media Drive DVD/CD-RW Combo Drive Communication Modem: 56K ITU V.92 modem
LAN: 10/100 Mbps Fast Ethernet
Wireless LAN: integrated Intel® PRO/Wireless 2200BG network connection Size & Weight 364 (W) x 279 (D) x 33.9/38.9 (H) mm (14.3 x 11 x 1.3/1.5 inches)
2.95 kg (6.48 lbs.) Power ACPI 1.0b power management standard
32.6W Li-ion battery pack (4-cell), battery life: 2.5 hours Special Keys & Controls 88-/89-key Acer FineTouch™ keyboard with 5-degree curve, inverted "T" cursor layout, international language support, 2.5 mm (minimum) key travel
Touchpad with 4-way scroll button
12 function keys, four cursor keys, two Windows® keys, hotkey controls, embedded numeric keypad
Four easy-launch buttons: Internet, email, Empowering Key, one user-programmable button
Two front-access LED-buttons: WLAN, Bluetooth® I/O Ports Three USB 2.0 ports
PC Card slot (one Type II)
External display (VGA) port
Headphones/speaker/line-out port
Microphone/line-in jack
Ethernet (RJ-45) port
Modem (RJ-11) port
DC-in jack for AC adapter Software Optional Items Li-ion battery pack
65 W AC adapter
256/512 MB or 1 GB DDR2 533 soDIMM memory modules
External USB floppy disk drive Warranty 1 (one) year International Traveller's warranty (ITW) Price
Jan 21, 2008 | Acer TravelMate 2300 Notebook
If possible 2 upgraded my acer aspire 5580 laptp video card?
no the video card in laptops is inbuilt . its fixed like graphics chipset in mother board of dektop
Dec 22, 2007 | Acer Aspire 5580 Notebook
Acer c5600
Bro first thing! Which bluetooth module your acer laptop is using plz can you tell us?? so we can provide you information about the drivers!
Mumbai Acer India (Pvt) Ltd. # GR2, D Wing, Ground Floor, Remi Biz Court, Plot # 9, Shah Industrial Estate, Andheri (West), Mumbai - 400 058. Tel : +91-22-66975217, 66975218, 66975219, 66976999, 66975220. Fax : +91-22-56975220. e-mail : ailintouch_blr@acer.co.in
Dec 08, 2007 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5580 Notebook Logo
1,047 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
