Question about APC MasterSwitch Power Receptacle - Power distribution strip- 4 Output (ap95103202) UPS System
Receptacle Doesn't Work
What do I do if a receptacle doesn't work?
    Novelist:
  • 74 Answers
By far the most common problem with a receptacle is that it doesn?t work. Because receptacles are very inexpensive and easy to replace, it makes sense to replace them when they cease to work properly. But before you go to the trouble of buying a new one and installing it, make sure that the old one is truly defective. For a non-working duplex receptacle, first make sure the problem isn't with the appliance or lamp. Some appliances, such as hairdryers, have overload protectors that automatically shut them off if they begin to overheat. Try a second appliance or lamp in the receptacle. If the receptacle still doesn't work, you'll usually find that the circuit breaker has tripped or the fuse has blown, the receptacle has become faulty, or there is a switch that operates that receptacle and it needs to be turned on. The problem is rarely the wiring. 1) Test the receptacle with a second lamp or appliance. 2) Be sure that one half of the duplex receptacle (or the entire receptacle) isn't controlled by a switch in the room. 3) Check the circuit breaker (or fuse) for that receptacle's circuit to be sure it has not tripped (or blown). If it has, reset the breaker or replace the fuse, and try plugging a working lamp or appliance into the receptacle again. 4) If it still doesn't work, turn off the receptacle's circuit breaker, unscrew the cover plate from the receptacle, and use a voltage tester to be sure none of the wires in the electrical box are still "hot." Then check to be sure that the wires are securely fastened to the receptacle's terminals. 5) Look for signs of charring. Replace the receptacle if it looks damaged. 6) Put the cover plate back on, turn the circuit back on, and try the receptacle again. If it still doesn't work, turn the circuit back off, remove the receptacle cover, and replace the receptacle with one that has the same amp and voltage ratings. 7) If this doesn't solve the problem, call an electrician.
Posted on Jan 18, 2006
What type of fuse does it use?
Posted on Aug 08, 2007
3 Suggested Answers
  • 74 Answers
SOURCE: Replacing a receptacle
As always when working with electricity, shut off the power. Use a circuit tester to make sure that the power is really off. Unscrew the receptacle's cover plate; be sure you get a replacement receptacle that's the correct type for your wiring?though most receptacles are standard, aluminum wiring should only be connected to receptacles designated CO-ALR. When installing the new receptacle, connect the black (hot) wire to the brass terminal screw, the white (neutral) wire to the silver screw, and the bare (ground) wire to the green ground screw. Unscrew the receptacle cover plate and unscrew the receptacle. Disconnect the wires from the terminals. Form a curl with a pair of needle-nose pliers so the wires hook clockwise around the screws, then tighten the terminal screws. Screw the receptacle to the box and add the cover plate.
frankzcomput
  • 268 Answers
SOURCE: half of a dual receptacle outlet is not working,
This is fixable but not by a computer tech. You will need to take this unit to a place that does TV's and other electronic repairs. They will best best at correcting this type of issue. Most techs will say just replace the unit.
Thanks,
MyLive-Tech 1-888-361-8511
http://www.mylive-tech.com
Posted on Jan 29, 2010
I have a Kenmore 90 series dryer, and I have power to the 220/240 plug then when I open the door the light doesn't come on or the dryer doesn't run. I'm not sure where to look next, I don't...
Make sure both sides of the receptacle has 110 volts. Take meter and keep prong in ground slot and then put red prong in the others. You should have 110 volts in each one. If not change receptacle.
Sep 11, 2017 | Dryers
24 volt trolling motor (motorguide) not working. Have 24 volts at receptacle in hull of boat but when I plug in the trolling motor and check the volts on the plug, I only read 6 volts. Any idea whats...
You have a high resistance short either inside the wiring or the lower unit. This will cause a voltage drop. I would be very careful not to keep it connected too long cuz the battery is trying to keep up with the current demand and may explode.
Oct 03, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
My wave maker blender from Hamilton beach doesn't work... What do i do? I bought it a few weeks ago and have used it about a dozen times now. I saw a solution saying the GFI button has to be checked....
the GFI is the receptacle in your kitchen, not on the unit itself,, the reset is the small red button in the middle of the receptacle ( sometimes gray) you just push that in to reset it,, newer homes have these in restrooms and kitchens for safety issues , however, back to your problem, try plugging the unit in to a receptacle without a GFI ,, if it works, its due to the high amps needed to start your blender and it trips the circuit. if it doesn't work,, Just take it back where you bought it , so you don't void any warranty on the unit and just get another one
Jul 03, 2011 | Blenders
Rear registration light doesn't work ...have changed bulbs and fuses still not work...
Could be just a bad connection. Check it for voltage with your lights on. If you get 12V, your connection is probably either weak or oxidized. You could try bending the connector wires out a little if it's a plug-in type bulb, or cleaning the socket if it is a socket type bulb. It helps to use some dielectric grease on the bulb/receptacle as a preventative measure against corrosion.
Jun 23, 2011 | Ford Focus Cars & Trucks
Hello. I just plugged my danby and there's no light, no nothing: it doesn't work? It used to work perfeclty last summer. What can I do?
Marie, the problem may be with the receptacle that it's plugged into. Unplug the AC unit and plug a lamp into the receptacle to see if it works. If it doesn't, the circuit breaker for that outlet may be tripped in your home's circuit breaker panel. Or the receptacle may have a loose wiring connection or internal damage, which wouldn't necessarily trip the circuit breaker, until something like an AC unit is plugged in.
Hope this helps you troubleshoot and solve the problem.
Jun 08, 2011 | Heating & Cooling
Slow cooker light does not come on and crock does not heat up when plugged in
Have you checked another receptacle? If you plug it into a known good receptacle, and it still doesn't work, it's broken. You should just buy a new one.
May 06, 2011 | Rival SCVP609 6-Quart Slow Cooker
We unplugged our Bunn and left it unplugged overnight to do some painting. When we plugged it back in the light doesn't come on the warmer and the water does not heat.
The unit is not getting power. If the receptacle is protected by a GFI, then press the Reset button. Otherwise, check that the circuit breaker (or fuse) to that receptacle isn't tripped.
May 06, 2011 | Bunn GR10 Coffee Maker
Keeps tripping GFI outlets
The key here is to identify the problem as being either the coffee maker or the GFI receptacle... a simple test can be done as follows...
Try plugging the Coffee Maker into another GFI receptacle .. you may have one in the bathroom? If it trips that too, then you have an internal wiring problem with your coffee maker.. if it doesn;t ..then your GFI receptacle may be bad or on the verge of going bad .. either way..this should narrow the problem down to one or the other.. hope this helps..
Aug 30, 2008 | Keurig B60 Coffee Maker
Refregerator isn't working
To operate, a refrigerator needs electricity. If the refrigerator's light doesn't work and it's motor doesn't run: 1) Check the power. Make sure that the receptacle works (plug in a working lamp or a circuit tester). If the receptacle doesn?t work, check for a tripped circuit breaker or blown fuse. 2) Be sure the cold control is turned on. 3) If you discover that the refrigerator is plugged into a working outlet and the cold control is on, but the device shows no signs of life, leave the door closed to retain the cold air and call an appliance repairperson.
Jan 18, 2006 | Hoover HCA331FFK
APC MasterSwitch Power Receptacle - Power distribution strip- 4 Output (ap95103202) UPS System Logo
1,077 people viewed this question
Top APC Computers & Internet Experts
Alun Cox
ATS dude
Level 1 Expert
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
