Question about Interlink RemotePoint Navigator Remote Control
INTERLINK Navigater 2.4
Need to calibrate pointer with dell computer ASAP!!!
  • 3 Answers
Http://www.smklink.com/library/media/papers/pdf/RemotePointNavigatorUserGuide.pdf
This should sort you out, but if you can't get the link, you remove the receiver from the pc and reconnect it after a few seconds. Press and hold the "Next" button on the remote (the right arrow) until the red light on the remote turns back on. the LED on the receiver should turn from flashing green to solid green then back to flashing green.
Posted on Sep 17, 2009
How to calibrate galaxy mini 2 S6500
Have you tried this?
Go to Menu - Settings - Language & Keyboard - Touch Input - Text Input. Then choose either Calibration Tool or Reset calibration
Jun 19, 2014 | Samsung Computers & Internet
My shark navigater lift away hose came off. How can I fix this?
it should just snap right back into place if not you need to get a hole new hose
Mar 18, 2014 | Shark Navigator Bagless Upright Vacuum
1994 Mercury Grand Marquis temp gauge reads hot
Check sending unit, Ford/Mercury put out a TSB, technical service bulletin : Article No. 95-13-2 07/03/95, on erratic temp sender units.
You troubleshoot as follows :
  1. Turn ignition switch to On or ACC position.
  2. Connect a 10 ohm resistor between gauge lead and ground. The centerline of pointer should fall within the band around the H mark.
  3. Connect a 73 ohm resistor between gauge lead and ground. The centerline of pointer should fall within the band around the C mark.
  4. If gauge tests within calibration, replace sender.
  5. If gauge is out of calibration, replace gauge.
Mar 16, 2013 | 2000 Mercury Grand Marquis
Touchpad not working smoothly on dell laptop
Hi all. I was able to fix 2 x E5430 with touchpad unresponsiveness. I tried all other fixes suggested like uninstalling drivers, trying different drivers, adjusting touchpad settings from software, uninstalling antivirus etc, spent 3 days solid on it...ALL TO NO HELP in my 2 E5430's.
..... So I followed a tutorial online to pull apart the touchpad http://blog.parts-people.com/2016/01/25/dell-latitude-e5430-p27g-001-palmrest-touchpad-removal-and-installation/. There is a metallic adhesive that earths the touchpad. Press and rub the adhesive so it makes good contact with chassis it is stuck to, reassemble, that's it! My 2 Dell E5430's now work as expected. No jerks, no unexpected double clicks, no dragging stuff around by accident!!!!! Yah for me!!!
Dec 31, 2012 | Dell Latitude E5430 Laptop Computer- 3rd...
I have windows 7 I get two cursers when I use the pen, how can I fix this?
This problem appear in some Windows 7 applications, for example in PDF Annotator.
The solution is given in Scramble cursor in portrait mode (with solution) - Page 2, and also appear in the FAQ section of PDF Annotator website:
1. Open "Control Panel -> Mouse Properties -> Pointer Options" and activate "Display pointer trails" and change the trail length to "short". Apply the changes.
2. Restart your application.
Oct 07, 2017 | Adesso CyberTablet 12000
Touchpad/Pointer do not function when pressed/glided ...Dell Latitude D410 w/ Windows XP Facts / what i've done: 1. BIOS - is set to use both Touchpad and external USB mouse 2. Turn computer off &...
Hi! Welcome to www.fixya.com.
You can try to download the Alps driver in this Link; http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_PM_D410&os=WW1&osl=en&catid=&impid=
If nothing happens after reboot: Its definitely a hardware issue. You have to call out fo warrant department your manufacturer so it will be fix.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 26, 2011 | Dell Latitude D410 Notebook
Touch pad problems
Dell has their own utility for the touch pad.. it may be its own icon in control panel
Feb 11, 2010 | Dell (6F858) Cooling Fan
My dell latitude 610 touch pad is extremely slow
Try changing the pointer speed of your touchpad:
1. Go to Control Panel
2. Select Mouse
3. Click Pointer Options
4. Adjust the motion speed to fast (whichever you prefer)
Hope this helps.
Dec 07, 2009 | Dell F3534 Touchpad
Mouse pointer frozen
I would try re-syncing the mouse. If it doesn't work right away, try a reboot and then syncing the mouse. There is a little button on the bottom of the mouse that will allow you to do this.
If you need me to go further in depth i certainly will - just let me know but I would say that it's probably your problem.
Let me know if this works or not so i can try to find the correct solution if this doesn't to it for you. I'm here to help!!
Aug 15, 2009 | Interlink Mouse
Thermostat calibration?
It's on page 32 of the manual for Thermador's built in convection ovens. 1. turn off the oven 2.touch and hold the start pad and then touch the bake pad 3. 0 (zero) appears in the temp digits. release all pads 4. touch bake and 0 changes in increments. max adjustment is 35 degrees F. 5. to complete change touch start for lower oven on double ovens do this: touch the roast pad instead of the bake pad continue with steps 3-5.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Interlink RemotePoint Navigator Remote Control Logo
137 people viewed this question
Top Interlink Televison & Video Experts
Greg Cann
Greg Cann
Are you an Interlink Televison and Video Expert? Answer questions, earn points and help others
