Question about NEC VT47 Multimedia Projector
NEC VT 660 Status light on
The Status light comes on when I press on/ stand by and nothing happens...I can't get the projector to switch on....says I've pressed control panel key when control panel key lock is enabled....okay but how do I rectify the problem? Grateful for some advice...
  • johnmcphie Sep 07, 2008
    My machine is a VT 560...the status light remains on when I press on / standby...machine dead...last solution did not work...
    Thanks...problem solved by renewing batteries in remote....it's a Doh!moment
    President:
  • 2,712 Answers
Your cabinet button is locked. Try holding down the EXIT button for 10 seconds and see if this helps.
Posted on Sep 07, 2008
    Genius:
  • 1,268 Answers
Download the user manual HERE
Page 34 - Lamp Indicator - Blinking Red light - Lamp has reached its end of life.
Solution - Replace the lamp.
Replacing Lamp Instructions - on page 30
Cleaning Lamp - page 31
Hope that helps.
  • 1,879 Answers
Any other lights ? lamp, temp
    Master:
  • 763 Answers
If really needs a repair then try to see your repair service for this kind of situation. if no other choice. they have tools to repair or change something on the internal hardware. hope that helps!
CHARCOIS
  • 4,472 Answers
How long have you owned the unit? How long have you been having this problem. Once I have more information I can assist you further. Please try and not reject/move on to another expert til I get all the information necessary.
Thanks,
Lee
  • Lee A.
    Lee A. Sep 07, 2008
    Does the light blink at all what color is the light?
    Thanks,
    Lee
    Master:
  • 726 Answers
Ok try this take the batterys out of the remote for a few minitues and turn the projector off at the wall so it looses the memory and the remote should to
The projector turns on but won't project any light through the lens.
If this is a NEC VT series projector, Change the lamp. When if it continues to blink amber and not project and image after installing a new lamp check the lamp cover to see if the micro switch tab on the lamp cover broke off. Some models have a built in lens cover. If the cover is not slid over to open completely the light may not turn on.
May 19, 2014 | NEC VT800 LCD Projector
I have a nec vt560 and the power light stays orange and the status light is off until buttons are pressed. bottom line is...i cant get the projector to come on...the power light never turns green.
The projector is in standby mode, which is a good sign.
When you press the ON button for "at least 2 seconds or more", what happens.
Do any lights come on at all?
Mar 20, 2011 | NEC VT560 Multimedia Projector
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
May 28, 2009 | NEC VT595 LCD Projector
Lamp not lighting
Reset the lamp and try it.
Mar 28, 2008 | NEC VT660 Multimedia Projector
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
Whatever button i press the status light flashes and nothing happens?
hi 1) Check that the power cable is plugged in and that the power button on the projector cabinet or the remote control is on. See pages E-16 and 17 in the manual http://www.fixya.com/user-guide/p155892,m5221,gm34/NEC-VT460-Multimedia-Projector.aspx 2) Ensure that the lamp cover or lamp housing is installed correctly. See page E-30. 3) Check to see if the projector has overheated or the lamp has reached the end of its usable life. If there is insufficient ventilation around the projector or if the room where you?re presenting is particularly warm, move the projector to a cooler location 4) You have pressed control panel key when Control Key Lock is enabled good luck
Apr 20, 2006 | NEC VT460 Multimedia Projector
NEC VT47 Multimedia Projector Logo
646 people viewed this question
Top NEC Office Equipment & Supplies Experts
Electro Med Services...
Greg Cann
Greg Cann
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
