Question about Philips 27PT543S 27" TV
TV is on but picture comes and goes.
Just started this evening. Its been hot in California and I haven't used my TV much. Clicking noise heard when I try to change the channel. What could it be?time for a new TV?
    Problem Solver:
Tv is on but no picture
Posted on Dec 28, 2008
My 55ld520 screen goes black, turn off for short time comes back on but then goes black again.
Start simple by using different cables, whether they be HDMI, VGA or standard COAX cables. They could be losing the connection. Also, it's possible the power supply is wearing out and it gets too hot. You might want to simply try some spray air duster type thing to clear out any dust that can make it hot.
Sep 20, 2014 | LG 55LH40 55 in. LCD HDTV
Tv went blank and started making a clicking noise
Main board fault. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 01, 2014 | Proscan PLED4274A 42" LED TV 1920x1080, 60...
1988 Toyota Camry LE clicking noise during acceleration
start with premium gas or injector cleaner, could be a low octane ping. this may be hard to diagnose with out hearing the noise so the other thing i would have you do is remove the belts and run the engine. sometimes when a bearing in an alternator, idler pulley, a/c compressor or belt tensioner goes bad they can make a clicking noise. try to listen if the noise is coming from the belt area, the transmission area or some other spot. spin all the pulleys with the engine off and wiggle them to see if any are bad
Mar 31, 2014 | 1988 Toyota Camry
Samsung HLN617W No Sound. As I turn on the TV, the speakers give off a "sputtering" noise that can barely be heard. After a while the speakers come on. But, what used to take five minutes (2...
Red light comes on but then the tv is playing but after about 3 hours it just goes out but I can still hear the sound then if I go back after about 4 to 5 hours if I turn it on it plays no problem. Now the lamp just went. I think before replacing the lamp maybe I should replace cooling fan also.
Jun 07, 2011 | Samsung HLN617W 61" Rear Projection HDTV
TV will not turn on. Clicking noise heard from inside.
These sets use what is called a "switch mode" power supply. In order for them to work there is a capacitor that "kick" starts the process. If that cap goes bad, the power supply will not start up. Also, there are other caps inside that maintain the oscillation required for the power supply to work. There are 2 options for you here.
1) Replace the entire power supply module.
2) Repair the existing one.
Sicne these types of power supplies are not the easies to diagnose or repair, I would suggest that you replace the power supply module. That should resolve the problem.
Please note that there are other causes of the reported problem, but hte power module becoming defective is the most common.
Dan
Feb 10, 2009 | Akai PT5492S 54" Rear Projection...
Sony Bravia XBR-2 32-inch LCD with popping noise problem
Unfortunately, we have the same problem. We hear popping and our sound goes lower. It is not the cable box for us, it's definitely the TV; however, it happens, on our set, after its been on for a few minutes and then goes away after half an hour or so -- however, this evening its been happening for the past hour and the TV has been on for the evening.
Jun 10, 2008 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Toshiba Plasma clicking noise
Check the fan, it may be dust or a bad bearing.
Oct 10, 2007 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
No picture, tv has a clicking sound
Could be a bad flyback transformer and shorted horiz output.
Sep 12, 2006 | RCA P52945 52" Rear Projection Television
TV went out
it shut down when was viewing ah..ok there is a short and could be in the horizontal circuit or in the power supply regulator any way thats a job for a tech...good luck
Aug 10, 2006 | RCA P46922 TV
Philips 27PT543S 27" TV Logo
174 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
