Motor for Akai GXC-740D Casette Deck
I have an Akai GXC-740D Cassette Deck, its motor is running very hot, speed is variable and a faint burning smell. Had no problems in so many years except periodically changing the belts and re-vulcanising the rubber capstan rollers. Can anybody help please, i would like to keep this machine going. Will be grateful for any help/advice
  • pelagic4 Sep 11, 2008
    Thank You! i will get the necessary information and pass it on.
  • 1,512 Answers
Hi pelagic
The motor is probably faulty. The heat is a give away for that. Many motors for older decks can still be sourced. Can you see what part numbers may be on the back plate of the motor and I can find a source for you. Awaiting your reply
regards
robotek
Posted on Sep 11, 2008
Replace Run Capacitor.
Posted on Jul 24, 2012
How do I connect speakers to an AKAI GXC-725D cassette player?
manual looks like its available here. you have to register but its free
http://www.hifiengine.com/manual_library/akai/gxc-725d.shtml
Dec 12, 2014 | Akai Car Audio & Video
Nakamichi cassette deck one. i bought new motor for this deck because the old one was surging (checked the voltage for fluctuation 1st to make sure it wasnt a pre-motor problem). installed it and the new...
There will be either a hole in the top of the motor with a speed adjusting preset. Or there will be one on the printed circuit board. New Motors don't come set up. You have to adjust them for each deck. You will need a small screwdriver to adjust. You will have to figure out by ear when the speed is right.
Feb 23, 2014 | Audio Players & Recorders
Akai cassette deck GXC-725D
It could be head dirt, bad switches, broken head wire or electronics problem. A Technician or you if you know electronics will need to get into it further to find where the problem is. There si no magic wand except some alcohol and a Q tip if the heads are dirty.
Dec 06, 2012 | Audio Players & Recorders
Akai cassette deck GXC-725D playback only on one channel
Clean switches, check head wiring if it is a three head deck and then there could be bad relay contacts, defective electrolytic capacitors and even a malfunction in a muting circuit. That is why there are no easy answer but to get in with a scope and find out where the signal stops.
A 303 cassette deck - the belt has been changed. The feed spool and capstan turn fine. The take up spool does not turn and play stops after 5 sec. Take up spool is fine in fast forward. Help !
This is a case of a failing reel motor. What happens i sthe brushes become aged and wear down and the motor has what they call a dead spot on the Commutator. The motor will work fine at high speeds as the inertia is working for it but when you use a slow speed as in play mode the motor hits the dead spot and stops. You will need a new reel motor in the most likely case- I can service the deck if you want at Skywave Tape Deck Repair Chicago area. I will most likely put a new motor into the deck.
Oct 04, 2010 | Teac V377 Single Dual Cassette Deck
The fan on the bryant high efficient heat pump moves very slow or not at all
Hi, this is a 3 ton unit. It may or may not have a variable speed fan. You are saying it turns very slow or just stops. I believe you either have a problem with the run capacitor, or you are loosing this motor. They are putting variable speed blower motors on some units now, but if you are talking about your condenser fan motor, it may have a head pressure control to speed up this motor when the ambient temperature is higher and slower when cooler, but to stop when running indicates a motor or run capacitor problem. Check the cap. for oil leaks, swollen and deformed, burned terminals. If you find this, replace it. Remove the fan guard and carefully with the power off after it has ran for a while touch to see how hot the body of the motor is. If it is to hot to touch, you are loosing this motor. If you have a clamp around amp probe or know someone who may, you can look at the data plate to see what this motor should be drawing as far as amps and compare your readings to this. You will know for sure doing it this way.
Shastalaker7
A/C, & Heating Contractor
Jun 21, 2010 | Goodman CLQ36AR49 Air Conditioner
The tape runs a bit fast on play mode. Is there an adjustment for this or is it a board or motor problem.
Sometimes the motor has a control pot on the top. You might find it under a label, it will be only a small circular hole.
Otherwise trace the wires from the motor back to the PC board, you should see a Pot for the speed there.
Please bear in mind that if it is a second hand machine somebody could have replaced the motor with the wrong type.
Nov 23, 2009 | Yamaha KX 390 Stereo Cassette Deck Single...
Telex EH 1-2-1 Single Cassette-Speed Drift
Tape drive motor may not be running at correct speed. Calibrating motor speed adustment requires professional service
Mar 19, 2008 | Telex EH 1-2-1 Single Cassette Deck
Repair of Sansui cassette deck D-1000W and Compu Receiver Z-5000X in India.
This is a fairly old and obsolete model and its components are now not manufactured. If you are lucky, some stockists may have replacement part, but normally at very high price.
Nov 06, 2007 | Audio Players & Recorders
Motor plays at a very slow speed
capstan belt may be failing. check this by removing lid and touch the capstan flywheel when running. if it is easily stalled/slow to come up to speed and or the belt slipping badly then belt will require replacement.
Oct 14, 2007 | Sony TC WE435 Stereo Dual Cassette Deck...
469 people viewed this question
 Grubhead
Grubhead
