Washing machine motor fan belt broke - Washing Machines
    Novelist:
    Champion:
  • 261 Answers
Either Maytag or Ge or older than 87. Inspect pumps and pulleys before buying a belt to save a trip. If the wear isnt too bad a part number is on the belt and bringing the belt will save a trip too. Replacing the belt, first lace it on the pump and motor and finally the large drive pulley in the center, it will be easier.
Posted on Sep 07, 2008
Belt come off washing machine how can i fix
if it has a belt tip it over and see if it is broke, if it does not have a belt, check coupling to transmission where motor mounts to transmission. if this is bad it will effect the way it works. if it has a coupling, then remove motor to replace it. the couplings do not cost very much usually less then 20.00,
Jan 19, 2010 | Washing Machines
We have a Whirlpool LEC 8858 EQ1 and we think the motor is bad but we can't get down to it because of the fan. How do you remove the fan?
Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
Thanks for contacting fixya.com
Jan 05, 2010 | Washing Machines
Wont wash dry or spin. Motor runs. I think my son overloaded the machine. Could the belt be broken?
Hi there
i read your report. Yes it dose sound like your belt has broke.If you can spin the dryer with your hand with no Resistance then it's your belt that's broke. hope this info helps. Ty you for writing to fix ya.
Best Regards Richard
Dec 03, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch washing machine wont spin or empty
PAV2300 Top Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 20, 2009 | Maytag PAV2300 Top Load Washer
How do you install a new belt? its hard to fit around !!
Youmust loosen the motor bracket bolts and this will allow the motor to swing. Put belt on the motor pulley and feed the belt onto the large drum pulley and at the same time turn the drum pulley so that the belt pulls onto the pulley groove. Put some tension on the motor to tension the belt - not too much tension though. Holding the motor & belt tension, tighten the motor bracket bolts - job done. Should take no more than twenty minutes to complete.
Apr 14, 2009 | Washing Machines
The belt from an Indesit washing machine broke a wire
The wire you refer to is an earth wire, it has probably pulled of the motor or the frame of the m/c.
If you can't see where it came from, don't worry too much, all you need to do is fasten it to a metal part of the m/c so that is is making a contact to earth.
I assume that you can get a belt o/k
Make sure that the drum and motor are free before you fit new belt.
Plz rate my solution
Thanks.
Dec 23, 2008 | Indesit Washing Machines
The belt broke on the washing machine
You will have to remove the whole motor assembly out, then remove the water pump using torx 20 from the whole motor
Dec 14, 2008 | Amana ALW480DA Top Load Washer
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
Fan belt broken?
The motor bracket is broke, which allows the motor to "jump" causing the belt to come off.
Oct 14, 2007 | Equator EZ 2512 CEE Front Load Washer /...
Washing Machines Logo
136 people viewed this question
Top Washing Machines Experts
