Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Machine doesn't spin
My washing machine has stopped spinning a few days ago. Is there something I can do?
Maytag perfoma washing machine I just encountered this (won't spin) problem and was helped by a very courteous repairman. The machine set for several days between uses, my wife then decided to wash a load. It went through the agitation cycle fine, but when it came time for it to spin, all that happened it the motot kicked in and it started to smell hot. I checked to see if it was a belt and found that both belts were fine. I then called the shop were I bought the unit and talked to the repairman. He had me remove both belts, and check to see if the center pulley would turn. I could turn it clockwise, but not CCW. I then inserted a screwdriver into the pulley to act as a lever and pulled sharply. The drum broke loose and I was able to turn it. It seems that the upper bearing on the shaft becomes corroded from water leaking into the bearing. The machine is about 5 years old. I turned the timer to spin and it did not move, however, I had taken off the front cover. ( There are two clips on the bottm which hold the front cover in place. These need to be pried open to release the front. The cover is then raised to about 45 degrees and it will slip off) by pulling on the motor I could get the tub to spin. I ran it through the spin cycle several times to loosen up that bearing and it works fine. I do have to make sure the unit is used every day or two to prevent the unit from siezing up. The repair for this problemm is rather expensive so I will be looking to replace this machine in short order. However,thanks to the repairman for leading me through this while he was on the phone. This is the one advantage of buying a unit from a full service dealer. Posted by WFD 1/25/07
Posted on Jan 26, 2007
    Problem Solver:
  • 6 Answers
Re: my earlier response about the noisy machine during spin cycle It turns out to be a severly rusted spin bearing as I suspected. Evidently the seals under the tub leaked some water into the bearing. The rust created locked up the bearing until I manually turned the basket from the top. It was quite a job to get to the bearing: removed the top panel, basket cover ring, agitator and basket (pull really hard); removed the plastic nut(destroyed it) and seal assembly from the drive shaft inside the tub (made a special tool for this (a 2"x10" plate with two holes)); removed the tub( 4 screws inside, about 6 outside, and two hoses); removed the metal disk cone-shaped plate above the transmission ; and removed the bearing assembly from the plate.
Posted on Mar 05, 2007
This is a major problem with the Maytag Neptune Series and you could list the parts and part numberes for the wax motor, circuit board and mold ridden door gaskets.
Posted on Mar 01, 2007
I have the same problem exactly. Turned the basket to loosen it up after it froze. Now it spins but is very noisy. Sounds like the noise is coming from just under the tub, where the top bearing is located.
Posted on Feb 25, 2007
Problem could possibly be the coupler, a small part located between the motor and the transmission (drive)- easy repair - simply remove cabinet...
Posted on Jan 24, 2007
    Problem Solver:
  • 10 Answers
It sound like it could be a belt. if the motor runs while in the spin cycle then most likely the problem is the belt.
This model doesn't seem to have a belt. I believe that it is direct drive.
Posted on Jan 23, 2007
This has happened to me twice. Honest to pete, all I did to fix it was reboot it. I literally unplugged it and plugged it back in (after taking all the crap off the top). I think sometimes when you set stuff on top it triggers something to stop the spinning and protect the drum. They are serious in the instruction book about not setting anything on top of the machine. Good luck.
Posted on Jan 18, 2007
Some times the dryer is directil connected to the spin motor.in this case my be the capacitor is fualty or the motor winding it self
Posted on Jan 17, 2007
These washers are not belt driven but are gear driven these gears might have slipped it requires you to remove the cabinent and is rather easy once you get it apart..
Please include instructions on how to replace the washing machine belt.
Posted on Jan 07, 2007
    Novelist:
  • 74 Answers
If the washer seems to complete all of its cycles, but it doesn't spin: 1) Be sure the load of clothes is not lop-sided. If the tub becomes unbalanced, it may spin erratically or not at all. Sometimes you can just open the lid and reposition the clothes. This automatically resets an off-balance shut-off switch. Just close the lid and re-try. 2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during the spin cycle. If the switch doesn't click when you press and release it, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The belt may be loose, worn, or broken. If you're fairly handy, tighten or replace the belt, otherwise call an appliance repairperson. 4) Call an appliance repairperson; there may be a problem with the controls.
Posted on Jan 18, 2006
TRANSMISION
Posted on Feb 27, 2007
  • 90 Answers
The Direct drive/Motor coupling may be broken. If so, call a repair man or turn the washer on its side and unbolt the motor from the agitator rod and replace the coupling. The coupling is two plastic pieces connected to a black foam circle.
  • Bill Batross
    Bill Batross Jan 19, 2009
    Did my advise help? because, I had the same problem.
2 Suggested Answers
SOURCE:
honeymokey
  • 3113 Answers
SOURCE: Washing machine will not drain or spin out.
Model number please.
Posted on Jun 16, 2009
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
I have a Whirlpool Ultimate Care II washing machine, model number: LSQ9110PW3 that stopped working properly two days ago. At first it seemed to not be able to go into the spin cycle. However, I just...
You have one of the best washers ever made... It is called a "Direct Drive" by us technicians. You probably need this part, but NEVER get rid of this machine as NOTHING out there is this good- not for anyprice. https://www.repairclinic.com/PartDetail/Whirlpool-Washing-Machine-Motor-Coupling/285753A/1195967?modelNumber=LSQ9110PW3&ss=a11b5d654521&mr=1
Apr 07, 2017 | Whirlpool Washing Machines
Washer tries to spin but stops after afew seconds
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jul 17, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My washing machine drains but does not spin
Look for a motor belt that is worn out and make sure that the drum turns freely (machine off).
Aug 01, 2009 | Magic Chef CAV2000AWW Top Load Washer
Washer Froze, Spin Cycle Sounds like Jet Engine
when it goes into a high spin does it sound like a freight train in your house if so your bearings are going bad
Dec 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing machine
This deffenitly could be the brushes. Wierd sound normally comes from the electric sparking between the stator and the brushes. If it are not the brushes the best bet will be the bearing.
May 13, 2008 | Bosch Classixx WFO 2466 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
3,898 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
