Question about Motorola Mobility RAZR V3
Phone not turning on
you posted a problem that your razr v3x would not turn on.
I have the same problem, the keypad lights up but the screen remains blank and the phone doesnt turn on. It is not the battery, I have checked on my sisters phone.
did you find an answer to your phone?
Yes it clearly is a connectivity thing. thanks for bringing that to light for me. i dont exactly understand how you fixed it so it doesnt turn off all of the time. please reply asap!
Posted on Oct 09, 2008
Okay, so i had the same exact problem and heres how i fixed it... first i took off the battery cover exposing the screws holding the speaker/phone charger part on and unscrewed them i took a hair dryer to the phone drying up any water (because it did this to me while i was in the rain and i thought it may be water damage) and the little 4 pronged part that your battery terminal thing touches to and pushed them gently when i put my battery back on the part i took off with the screws pushed the battery up at an angel when i tried turning my phone on it worked fine so i thought the hair dryer must have done it but when i tightened the screws back up the phone turned off... its clearly a connectivity problem with the battery thing (the 4 brass triangle type things) my phone works now but the back is a little loose seeing as how i cant tighten the screws up... its not a complete fix but hey it works right.
Hope this helps,
Posted on Oct 08, 2008
I got no screenies?
yah, i think you lcd is the problem
maybe u should replace it
Jul 20, 2009 | Motorola Mobility RAZR V3x Cellular Phone
My vodafone razr v3x turns on then turns straight off
battery not holding charge mine did same change battery I verified problem by borrowing battery from my other phone and turned on no problem
Apr 24, 2009 | Motorola Mobility RAZR V3x Cellular Phone
The screen of my mobile phone does not work
just change the belt inside
i hope it will work properly
Dec 17, 2008 | Motorola Mobility RAZR V3x Cellular Phone
V3x does not start
what do mean? the phone turn on then shut off? did you see the light in LCD Screen?
Sep 12, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola RAZR V3x Whiye screen problem
I have managed to fix the problem by doing a software update.
I stumbled across the solution..........I had the phone connected to the computer when I started it in the 'boot loader' screen as opposed to just turning it on. This time the computer recognised the phone was connected and through the motorola software update program I was able to update the software and the phone now works fine.
BTW I did lose all my address book, messages etc.
To start in the boot loader screen hold down the * + # + pwr keys all at once.
Jul 29, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola v3x problem
The connection from your LCD to the systemboard might have a loose connection or might be disconnected.
If you have the skills, you can open up the phone (back part or keypad part) there should be a screw at the back and u must use a creditcard or any card similar to slide out the casing.
On the uppermost part of the board should be the flex which looks like a brown film and it has connectors that hooks up with the board. Just try to re seat it.
Hope this helps...
Jul 22, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola V3x won't turn on
ok! battery is problem in your mobile! change the your battery! thats it!
thanking you...........
keep rating meee
Jul 08, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Broken Motorola V3x
have you ever installed a new battery since you have had the phone?
Jul 01, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Try starting it in bootloader mode. Hold down the # and * key then press the power key. (3 keys in total). You should get a bootloader screen. If you do your phone can be saved. If not...
Apr 15, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola razr v3x
Hi There RobbieLou Thank You For Your Post
No You Will Not Need Any Other Programs To Recieve Your Pictures Just Folo Prompts
Now For The Resolution Does Your Pc Have Bluetooth By Any Chance If So Turn Your Bluetooth On And Send From Phone Via Bluetooth\
Solution #2
Easier Way Yet If You Have A Usb Data Cable To Plug From Your Pc Usb To Phone Port
I Hope This Helps Just A Quick Note If This Helped Please Rate Me That Would Be Great If You Have The Time To :)
Thank You
Dec 19, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Motorola Mobility RAZR V3 Logo
81 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
