I would definitely look into the switch at this point. Make sure there are no blown fuses in the relay as well. But most likely your switch is the problem.
Side note. The bulbs are still good in the car right. I have seen cases where both headlights burn out because of voltage surges caused by bad wiring etc. Also I have seen someone pull the headlight switch in a certain position so both the dim and brights were on (depending on car) and this caused both headlights to burn out.
Hope I could help
HEADLIGHTS NOT WORKING
It
can be faulty headlight switch or issue with its wiring. Or its faulty head
light fuse.
To
troubleshoot the issue i suggest you few help links with appropriate solution.
So you can follow the test and confirm what exact problem is there in your case
of headlights not working:-----
Click
the link below: -----
http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
• Working of Headlight switch?
• Both headlight bulbs blow together?
• Car
headlight bulbs don't last long?
http://technoanswers.blogspot.in/2012/06/2007-dodge-caliber-low-beam-headlight.html
http://technoanswers.blogspot.in/2012/04/2001-chevrolet-tahoe-both-low-beam.html
http://schematicsdiagram.blogspot.in/2012/04/low-beam-headlights-modification.html
How to Replace a Headlight
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight.html
Bulb
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-bulb.html
Switch
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-switch.html
How to Replace a Headlight Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-assembly.html
How to Replace a Park Light Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-park-light-assembly.html
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-door.html
http://schematicsdiagram.blogspot.com/2012/01/how-to-replace-hid-headlight-bulbs-for.html
These
will help.
Thanks.
How to Replace a
Headlight Switch
Low beam headlights Modification?
Headlight Assembly Removal On Honda Accord
http://technoanswers.blogspot.in/2012/06/headlight-assembly-removal-on-honda.html
Honda Headlight Assembly Removal
http://schematicsdiagram.blogspot.in/2012/06/honda-headlight-assembly-removal.html-----------
How to Replace a
Headlight Door
All headlights not working?
How to replace HID headlight bulbs for lexus
400h?
• Car headlight bulbs don't last long?
These will help.
Thanks.
I have pretty much the same problem. I have Hi Beams parking and fog lights but my low beams just don't work. I figured a fuse was blown cause what is the odds that both bulbs would blow at the same time? I checked the fuse in the dash and it was fine. I traded the Relay in my engine compartment from the AC which is the same relay and they still didnt work. I am going to go get a new bulb now to see if that is the problem. Hope so, sure dont want to have to deal with the expensive/crappy service from my dealer. Will let you know.
have same issue highs work lows dont fuses good but i blow bulbs almost weekly.
