Remotec Remote Master 580 (BW0930) DVD Code
Do you know the code for a Sansui SAN0313 DVD player. I tried 0455 and 0505, together with the Library Search function, all to no avail.
  • Anonymous May 05, 2009
    I have a sansui0693 and neither the codes from the code list nor the library search function will work....help?
3 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: Need a code for a universal remote to control my DVD player sansui san0313
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 23, 2008
  • 109 Answers
SOURCE: I have a remotec F-BW0930 and the code for AWA dvd
I don't have other code for your DVD but I can give you the steps on how to program your remote to your DVD without the list of codes.
1. Turn on your DVD.
2. Press the DVD Mode Key.
3. Hold down SET on the URC for 2 seconds until the indicator lights up.
4. Enter 0005. The indicator should go out immediately.
5. Press the DVD Mode Key again as in step 2.
6. Hold down SET for 2 seconds until the indicator lights up and your URC is ready to start searching.
7. Aim the URC at your DVD, press the power key repeatedly, slowly until the DVD has been turned off. Once your DVD has been turned off, immediately press SET to lock in code and the indicator should go out.
Posted on Jun 13, 2010
I would like to no if I can pair a remotec universal remote control to a LG BP240 Blue-ray /DVD player and if so what is the code I need to pair them
Use the code search function of your Remotec to find a code for your LG Blu-ray player. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Jun 01, 2016 | LG Televison & Video
Need remote code for remotec bw0930 to work Toshiba 40cv700a
0286,0281. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. See it in "Mosaic" or "Magazine" view. It will make surf easier. Or, do a search by type in the brand name of your device at its search box, and press "Enter".
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 17, 2014 | Televison & Video
Code for celestial pt4299hds
0004 0009 0053 0105 0109 0189 0135 0001 0008 0042 0058
Aug 28, 2012 | Acer Televison & Video
I have a remotec F-BW0930 and the code for AWA dvd players 00375 does not work, I have an AWA DP220, do you know the code?
Jun 13, 2010 | Universal Remote Control Remote Control
I need 4 digit code for daewoo tv using the remotec remote control
Hello dennisdl,
Try one of these codes, hopefully one of them will work for your model Daewoo:
0101
1501
1511
2611
May 25, 2009 | Universal Remote Control Hampton Bay...
Sansui VRDVD4000
Universal remotes rarely fully work with these type of units. Call Orion customer service 800 289 0980 to price an original remote.
Oct 09, 2008 | Sansui VRDVD4000 DVD Player/VCR
Jensen JR400
Code For Model JER422
Code 3168 for Sansui DVD Code 3401 for Sansui DVD Code For Model JER422
Code 2010 for Sansui VCR Code 2031 for Sansui VCR Code 2111 for Sansui VCR Code 2123 for Sansui VCR Code 2130 for Sansui VCRif these dont work try
http://remotefinder.rca.com/
and if you cant find one there then your remote does not support this device.
Dec 24, 2007 | Jensen JER-422 Universal Remote Control
Televison & Video Logo
593 people viewed this question
Top Televison & Video Experts
Electro Med Services...
