My vhs player/recorder will fail to eject, because the tape gets caught around what I would call a capstain post and when I forcefully pull out the tape, the tape hangs up and I have to manually lift the tape up over that post that has it caught. I usually end up with about 1 ft. of tape that is badly wrinkled and sometimes I just ruin the tape. What will solve my problem
  • 8,596 Answers
Reset the unit by unplugging it/repluggin it after 30 seconds, and then use a VHS cleaner.
Posted on Sep 07, 2008
I have a Toshiba dvr 7 vcr dvd recorder. It occasionally gives an error message 85 when I am trying to copy a VHS tape to DVD. What does this mean and is there a way around it?
Commercial movie VHS tapes have copyright protection added to the tape. There is hardware in the recorder (mandated by law) that will sense this signal and not allow copying of these tapes to another tape or any other media. There are hackers that have built devices and modified equipment to circumvent this, but you risk legal action if caught.
Jan 20, 2015 | Toshiba DVR7 DVD Player
My VHS player will occasionally accept the vhs tape but then it pulls out the film then turns off or ejects the tapes how can i fix it
Unfortunately there is some damage to the drive mechanism of the VCR. This will need to be fixed. I can't say what is causing it, but it is clearly not pulling the tape back inside the cassette before the eject action takes place.
Mar 18, 2017 | Emerson 4-Head VCR Video Cassette Recorder...
When inserting vhs tape, the player pulls the tape from inserted vhs
That is exactly what a typical M-Load mechanism is supposed to do. Once the VHS tape cassette is inserted, cassette housing cover will be flipped up and two arms will pull tape out of cassette housing to wrap tape around cylindrical spinning head housing that contains video heads and, if VHS HI-FI, audio heads as well. When stop or eject button is pressed, arms will retract and tape will wind back into cassette housing. What type of problem are you experiencing with unit? It may have nothing to do with M-load engaging tape around head cylinder.
Mar 22, 2014 | Samsung DVD-VR325 DVD Recorder/VCR
I have a philips DVDR3510V ( DVD/VHS Recorder) which is 16 months old. The problem is that the buttons on the recorder do not work ( except power button) . We thought we had got round this as the remote...
I can only speak to getting the tape out. If all else fails, you can take the player to your local best buy and have them remove the tape for a minimal fee of no more than 30$.
Jul 18, 2011 | Philips MWD2205 DVD Player/VCR
Vhc tape is stuck in my video cassette recorder, it is a much older vcs, is their any way I could possibly that I can get it out without breaking the vcs?
Take ur finger senses all around the VCR the open flap door for sensors also pushes the eject button too as the same time,when the right sensors it hit ur finger the VHS tape will come out.
Mar 16, 2011 | Zenith Televison & Video
A vhf tape got stuck in the machine. I could see the tape itself was caught on some moving prongs. now i don't know the proper setting for the prongs and cannot get any vhs tapes to play.
Hi, if VHS tape is in you have only one solution..to disassemble DVD/VCR ..Can you do it ? you may try !!t
Here's how to do it..
* 1 Turn off the COMBO. and unplug it.
* 2 Remove the 4x screws off COMBO on the sides and take off the DVD/VCR casing.
* 3 Look for the Tape which messed up with VCR transport mechanism ,try to release tape of the transport with your hand..
* 4 Since EJECT feature works with power only ,while you keep the tape off from transport plug the device to power and turn it on..Don't worry,you will see the eject mechanism starts moving back on forth,keep the tape off it and let it eject..
* 5.When tape is out .If it destroyed badly normally you should not use it however if the recording in is valuable for you you can cut the chewed portion and
splice it back together .(Pls see the video included...How to fix a broken VHS tape.)
* 6 While it is open,place another Tape to see if mechanism works properly. and eject it...
* 7 Replace the casing and the screws. Plug the player in and turn it on. Now player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
http://www.youtube.com/watch?v=Q1PJWA2KGyg
Mar 13, 2011 | Philips DVD740VR DVD Player/VCR
A VHS tape is in the recorder but will not eject. The flap opens when eject key is pressed, the cassette comes up, does not come forward, and then goes back down. The recorder then switches itself off.
Hi, the problem is the tape has got chewed up inside the video the only way your going to get it out is by taking the case of but dont do this whilst its plugged in.
you need to take the tape off and you may have to cut the tape so you can put the case back on and switch it on so the tape will eject, you need to get what ever is keeping it stuck free, the chances are the tape has got chewed up around the drive and this will need cutting free to allow the tape to come out.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks.
you could try fast forwarding a bit or rewinding a bit then try ejecting but failing that your going to need to take the case off to free the tape
Sep 01, 2010 | Panasonic DMR-E95HS DVD Recorder
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Tapes not playing
Hey do the tapes play at all? sometimes some tapes recorded
on other machines won't play on others. maybe you need to adjust the tracking on the VCR you are playing it on. If the tape
was recorded on a VCR that is misaligned it might not play back
on another VCR. Also the tape may have been recorded on a
super VHS VCR in et (extended definition) mode if so they won't play on just any VCR. If the picture looks scrambled like a
premium channel on analog cable then it's probably recorded in et.
and if its recorded on super VHS tape it may eject out of your VCR.
They don't make these S-VHS vcrs anymore but people still
have them around. There is also Digital VHS they're not
compatible with VHS either. A VHS recorded in et mode will
play on some more expensive vcrs it should say so on the box
or instructions.
Nov 14, 2007 | RCA VR634HF VHS VCR
Toshiba M-752 Video Casette Recorder
Take the top cover off, and see if there is an obvious reason for the no-eject, as in tape spooled out and wrapped around something. Next, is the tape drawn back into the tape housing? Under normal operation this is done before eject. A defect in the tape itself, or in the VCR mechanicals can cause a no "pull in" condition. Otherwise, you could carefully try to assist an eject- push eject, lift lightly on the tape. Sometimes the entire carriage mechanism can be removed with tape in place, but often, screws holding this in place are obscured by the tape, and, if carriage is gear driven, proper gear alignment must be reestablished. This can be a tricky problem, getting tape out without damaging anything, especially since late VCRs are made rather fragile to start with.
Aug 14, 2007 | Toshiba W522 VHS VCR
62 people viewed this question
 Grubhead
Grubhead
