Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Washing machine dead...
Y machine doesn't turn on. What is wrong with it?
Looks like the central control unit in back under top cover. Sears pn 8181692 $110 plus shipping
Posted on Nov 26, 2007
    Novelist:
  • 74 Answers
If the washer doesn't operate or make any noise when set on any cycle, or if it stops suddenly when it should continue onto the next cycle, it may not be receiving electrical power or, if the motor stopped mid-cycle, the machine's overload protector may have tripped. In this case, take out some of the articles to reduce the load and let the protector reset itself, then restart. Otherwise: 1) Be sure it is plugged in and turned on. If necessary, check the receptacle it's plugged into for power, using a working lamp, appliance, or voltage tester. Be sure the washer lid is closed completely. 2) If the receptacle seems dead, check the circuit breaker or fuse that serves that circuit. 3) Unplug the washer and check the power cord. If necessary, replace the cord. 4) Open the lid and check the lid switch and the tab on the lid that it pushes against. Press and release the switch: if it doesn't click when you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 5) If the washer still doesn't work, the controls may be faulty. Call a service person.
Posted on Jan 18, 2006
Mah8700aww
An eleven-year-old washing machine is nearing retirement age.
Aug 07, 2017 | Washing Machines
What is wrong when you turn the key to start and the radio and all the instruments turn on but the starter doesn't click and the engine doesn't turn on even after trying to jump start it
Dead battery
Dangerous practice to try & jump a dead battery
The battery cables could be loose at either end or corroded internally
Most likely the battery is worn out, if original to car
since it was new, or the starter solenoid is worn
You do not want to jump any vehicle made after the
year 2000 or your asking for possible problems with
todays electronics.
You need a good battery that has been tested & fully
charged, then only jump with a jump pack,not another car
Jan 21, 2013 | 2008 Buick Lucerne
I just removed the back cabinet of a Whirlpool Duet Dryer and found a dead mouse where the power cord connects to the cabinet. Machine powers up but doesn't turn. I noticed that the neutral spli
if the wire has a metal end on it and its connected to the white wire, or neutral line, then something is wrong and that should connect to something
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 05, 2012 | Whirlpool Dryers
The Hot Point washing machine has stopped agitating but does spin-what is wrong?
The most usualthing wrong when the Hotpoint brand washer doesn't agaitate is a stripped agitater coupler,i don't see a model number in your question so i don't know if yours uses that coupler but its by far the leading thing wrong with that problem.
This youtube video will show ya how to replace that coupler,watch it and take off your agitator to see if that's the problem. http://www.youtube.com/watch?v=N26MCQKuXn0
GENE
Oct 13, 2011 | Hotpoint Washing Machines
Washer won't agitate or spin
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Sep 07, 2011 | GE Profile WPRE6100G Top Load Washer
Every time machine is turned on, it blows the circuit breaker. Doesn't matter which circuit it's plugged into. Doesn't matter which place in the cycle it's at. Where are the mostly...
Not much information for DIY repair. It is a portable machine suggest taking it to a repair center and request an estimate for repair.
Dead shorts such as this indicates from the successive breaker tripping are usually easy to troubleshoot by a qualified technician and could be an inexpensive repair.
It is a very dangerous condition, dead shorts are rare and can present a hazaderous condition for the user!!! Do not attempt any additional use.
images-hioxyjzsrsihrx1txyibv0ns-4-2.jpg Hope this helps?
Jun 29, 2017 | Haier XQB40-F Top Load Washer
Lg washing machine has power but the display on the front panel keeps on but i can't operate the machine and if the power button is pressed it doesn't turn off. please give me some solution about...
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB. I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 30, 2011 | Washing Machines
My wash machine will not agitate or spin out
if a whirlpool and its dead ck your lid switch,if not dead but makes ratchety noise probally broken motor coupler
Jan 14, 2010 | Washing Machines
Washing machine suddenly stopped working only 17 months old
unplug from the wall about 1min then plug back in this will reboot the cpu on the machine
Aug 23, 2009 | GE WPXH214A Front Load Washer
Hoover washing machine
take top off and check the suppressor capacitor - the round thing the incoming mains is connected to
Oct 21, 2008 | Washing Machines
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
1,489 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
