Question about Nintendo DS Console
Date settings gone
The ds shell of my sons ds was broke after i chaged teh shell i got stuck on this issue can you help me?
  • Samm_73 Oct 14, 2008
    It is solved, i had to flash it due every time it was powered off the settings were gone, now even if the settings are gone the flashed bios bypases the warning screenand i am able to use it.
    thanks
    Samm
    Guru:
  • 155 Answers
When you turn on your DS, on the main menu screen at the bottom in the middle there will be a DS icon, click this and it will provide you with options to change the time, date and other stuff.
Hope this helps,
Robin
Posted on Oct 14, 2008
    Scholar:
  • 125 Answers
Is it a ds or a ds lite?
Turn on the unit with no cartidges. Press the screen to acknowledge the warning message.
On the next screen, press the tiny ds icon at the center bottom of the lower screen. This enters the setup. Fromhere you can press the clock calender icon (blue one) to set the time. Youcan also change other settingswith the other icons.
Posted on Sep 17, 2008
System date error! Please check NDS system date. I get this error message when I put my son's DS on. It won't load up. It's stuck with a Loading message & then the above message as well. Please advise...
well this happened to me and i u have to do is go into the options, click on the calender and set the date back about a year . simple as that
i hope it works for u
Apr 14, 2010 | Nintendo DS Lite
Where is NINTENDO DS Lite code located?
it should have been on the bottom of the DS, check maby your kids took it off, or contact NINTENDO
Oct 16, 2009 | Nintendo DS Lite Console
Nintendo ds lite won't chage or come on
um maybe its the power cord or if not inside the ds the plug wher u put the power cord is broken
Jun 06, 2009 | Nintendo DS Lite Console
Replaced the shell and now the touch screen isn't responding!
I have actually done this same thing attempting to repair my old gray DS. Had to replace the screen to screen cable and touch pad, but that is another matter.
When the DS screen to screen cables are out of place, the DS will act exactly like this. The screens will flash once and the DS won't even attempt a charge. This is a safety feature of sorts in the DS design to prevent a possible short.
I'm assuming you had to remove the screen to screen communication cable when replacing the shells so you most likely didn't put the cable in all the way into the correct ports.
Sometimes even if they are off just a bit the machien just won't use it and act like its outright dead.
Best thing to do is to go back and reinsert the cables again.
There should be a small line on the board just under where the cable should be. You need to try and aling the cable with this line as best as you can.
Push the cable as far back into the port as you can without forcing it in. You should never need to use much force at all.
Press the plastic tab down and lock the cable in place with the port and do the same with the second one.
Once thats done, plug it in and turn it on.
It should normally go into the settings as these are usually erased when the battery is removed.
If it continues the odd dead like behavior. Simply attempt the precedure over again until you ahve it right.
Commonly you may see odd colorisation and the like if the cable is in enough but not in just right.
Take your time with it and be paient. Its not always easy but isn't too hard once you figure it out on your own.
The same info should help with other cable problems like this aswell.
Good luck with the rerpairs.
May 09, 2009 | Nintendo DS Lite Console
Nintendo DS hinge broke
You can find the info for replacing the shell here:
http://site.powergamingparts.com/RepairNdsl.html
Dec 22, 2008 | Nintendo DS Console
Hinge problem
There out it is nothing like a broken hinge only repair solution, the only way to get it repaired is to buy a new replacement shell and replace the broken parts or the whole shell, but some cheap shells wont last and will broke again so read reviews. And if you are not too skilled be careful when replacing or you can get your DS more damaged.
The best is to find a good case broken DS, like water damage etc. to get only the original plastic parts. I should love to have to buy only the broken parts needed but you have to buy the whole thing.
Nov 14, 2008 | Nintendo DS Lite Console
Ds lite
yes the new shell has this piece it's just not in the photo, it's in a bag not seen in most photos, you can replace this for about $25.00, or use a repair service on ebay
Aug 25, 2008 | Nintendo DS Console
Nintendo ds broken hinge
need to replace the hinge (shell housing) about $25.00
Aug 22, 2008 | Nintendo DS Lite Console
DS hinge
yeah these kind of things can be a pain. we provide this service. if your interested united.gamez@gmail.com
May 19, 2008 | Nintendo DS Console
Dropped and broke !
If your pretty good at dealing with small wires and parts there is a guide I found dealing with this problem
http://www.instructables.com/id/S405TMEFA0CVIFR/
Hope this helps and good luck repairing your son's DS Lite.
Jan 14, 2008 | Nintendo DS Lite Console
Nintendo DS Console Logo
76 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
