This is an old post, however, the problem is not in the door switch. If you check the wiring diagram the switch goes back to the board to a relay. The relay is sticking. The solution is changing the board.
The GE GSL22JFPH refrigerator door gets lower over time. When it gets low enough the light stays on when the door closes. There is a vertical bolt along the hinge line. Push down the hinged plastic "hinge cover" under the door right on the hinge line and you can get a wrench on the bolt to raise the door. I have to do this every 6 months/
It's difficult to tell if this is happening but you should be able to see the light go off when the door is a fraction of an inch from closing. You can also feel the bulb (be careful!) when you first open the refrigerator in the morning-it will be hot if it has stayed on.
A light bulb that stays on will warm the refrigerator's interior, cutting down on efficiency. Test the light switch button that the door closes against-when you push it in all of the way, the light should go off.
If the light stays on even when the door is closed, the light switch is defective and must be replaced. If you are adept at simple repairs, this is a job that you may be able to handle yourself-be sure to unplug the refrigerator before working on it. Otherwise, call an appliance repairperson.
I have the same exact model (Maytag MTB2191A) fridge and I've
encountered the same problem in which the light is on while the door is closed.
When the door's closed, you can actually see the
light on, through whatever bad seal is going on there - plus it also
means that the light switch isn't being pushed as it should with the
door closed.
The issue is the closing door is not aligned with light off switch.
After year of putting up with this issue, I found a solution today. It's very simple. I unscrewed the light fixture a bit and now, viola, the door aligns with the off switch. The light turns off when I close the door. what a pain and what a simple fix.
my LG refrigerator is doing the same thing but the switches are working because the digital control center LEDs go off when the door switches are in the closed position and the fan comes on
This refrigerator is a peice of junk, everyone who purchased it should get a full refund, many people are having the same problem with the lights staying on, this is a fire hazard. please help by writing reviews. Lets get this peice of junk off the market.
Samsung refrigerators are unlike most, in that there is no mechanical door switch. There is rather a magnet in the upper edge of the door that creates a contact with the frame of the refrigerator, much like the magnetic contacts on a window burglar alarm. Check to seei f the magnet possibly fell out.
Also, the light will not go out until the door is almost completely closed.
A friend and I have the same exact model (Maytag MTB2191A) fridge and we've both encountered the same problems with them. This light on thing is one of them. I don't believe it has anything to do with the light switch and here's why:
When the door's closed, you can actually see the light on, through whatever bad seal is going on there - plus it also means that the light switch isn't being pushed as it should with the door closed.
I found that if I tried to sort of push the door upward, the seal with close and I didn't see any light. But you can just stand there and watch it unseal itself.
Both of us have had problems with food that's way too cold and food that's ok, depending on where it is. This HAS to be why. Even on the lowest setting, things away from the bulb freeze, while things closer to the bulb do not.
GE Monogram making loud noises occassionally (about every 10 minutes or so). Fridge is about 6 or 7...
(More)
GE Monogram making loud noises occassionally (about every 10 minutes or so). Fridge is about 6 or 7 years old. Just started. still cooling fine.
The freezer seems to overcool (no limit) and there is no light in the display or inside the...
(More)
The freezer seems to overcool (no limit) and there is no light in the display or inside the refrigerator. there is only one compressor. What can this be?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
