Question about Jl Audio 12W3 Car Subwoofer
Static sound I have a 12in jl sub and when connect it to my amp it has a weird static sound anybody can help??
Check rca cables
Posted on Sep 16, 2008
My 12w7 has like a springing sound inside it, what is it?
Blown voice coil,,,,it was connected to a JL AUDIO amp correct? w7`s can ONLY be powered by JL amps due to ohm load.Advice buy a better quality sub,w7 is over-rated
Feb 07, 2013 | Jl Audio 13W7 Car Subwoofer
How should i have my 4ohm single voice coil JL audio 12in subs connected to my kenwood kac-9104d 1800 watt max power (500x1 @4) amplifier?
On the outputs of the amp there is:
1 2 3 4
terminals. Internally in the amp the positives (1 and 2) are connected together and negatives (3 and 4) together. So there is no difference between hooking up in any of the configurations 13, 14, 23 or 2->4. If its a matter of style, probably use the 14 set, since they're furter apart and harder to short out that way, but electrically it doesn't matter.
Feb 21, 2011 | Kenwood KAC-9104D Car Audio Amplifier
When I hook my JL W7 sub to my alpine mrd m1005
You need to have the amp bench tested at a car audio shop. Sounds like a dead short in the amp. Try turning the crossover on the sub "off" and connect any other speaker to it. if you have the same outcome, your amp needs serviced. Post a comment with your results and if I can think of anything else you could try beyond that I will. Hope this helps
Aug 17, 2009 | Car Audio & Video
What would be a better amp for my jl audio 12in w6v2
its not the amps my dude ur ohm loading is wrong if u have a 4 ohm stabled amp n ur speakers r 2 ohms naw thats not gonna fly caus it cant put out what ur asking 4 so u need 2 reload ur subs try this link http://www.bcae1.com/spkrmlti.htm this should help u out n save u money
Jun 17, 2009 | Jl Audio 12W6v2 Car Subwoofer
My amp shuts off with my 12in w6's when i turn up the volume
oh no you need a more powerfull amp i recommend selling the one you have and upgrade to a bigger amp ive had the same problem or if not unbridge your amp so it dosent work the amp to much
Mar 16, 2009 | Jl Audio 12W6 Car Subwoofer
No sound out of subs
undo all the wires to the amp and the speakers and simply rewire em.
Feb 25, 2009 | Jl Audio 12W3 Car Subwoofer
Sub makes loud noise when car is shut off
Does it make noise if the RCAs are unplugged? If not, the RCA shield on your head unit may be burned open.
If the amplifier is set to signal sense, it will take longer for the power light to go off.
Nov 13, 2007 | Jl Audio 250/1 Car Audio Amplifier
Jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
Nov 01, 2007 | Jl Audio E6450 Car Audio Amplifier
Bad amplifier need help!!!!
if you unhook the rca's does it persist?
Mar 26, 2007 | Jl Audio 300/4 Car Audio Amplifier
Jl Audio 12W3 Car Subwoofer Logo
180 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
