Question about Philips GoGear HDD075/17 MP3 Player
Problems with repair
When i cut it on and repair it start repairing then it show up ok i push it and it want click over then when its sit for a while it freeze
  • 8,596 Answers
With this model, you have to uninstall Windows Media Player 11 completely from your system - rollback tov ersion 10, and then perform the Repair. Then, the repair should work without causing a refreeze of your player.
Posted on Sep 07, 2008
Looking for repair manual or help with problem
ok,there are 3 safety switches,(i have the same mower,i bought for 50 bucks because they couldnt start it),a seat switch in case you fall off,a brake/clutch switch,so you have to step on it to start and a deck switch,so if your deck is engaged,it wont start,if you can guarantee that you wont fall off or screw around and get your foot cut off,i will tell you how to bypass the safety switches,
pull the cover off the motor,see the single small black wire connected to the coil?not the spark plug cable,pull that wire off of the coil,now,find a switch that you can use for a shut off,connect a wire to the coil and run it to your dash,connect another wire to ground,connect each of them to either side of the switch,you will use that to stop the motor,put the cover back on,sit in seat,push in clutch and start your mower.be careful,there are no safety switches now,dont go up a hill sideways you will get killed if it rolls on you.
Jul 19, 2015 | Craftsman Measuring Tools & Sensors
Motor will not start
Ok this isnt really a clear description but I will give it a try. First is there gas in the engine? Has it been sitting long? If it has been sitting then gas could have gelled in the carb and you need to clean out your carb. Is the fuel on/off switch in the on position? Do you have spark at yoru plug? Is your oil low? If all those things come back ok, then move to your pump. Try starting it while holding in the trigger on your wand. If it cuts off again when you let go of the trigger then you know that your pumps unloader is the problem and needs to be repaired or replaced. Good luck and let me knwo what you find
Feb 20, 2015 | Garden
Bribbs 550 ex carb leaks
If it doesn't leak when it is running and the leak doesn't affect the way it runs, I would put an in-line cut-off valve on the fuel line between the gas tank and the carb. After you shut it down close the valve until the next time you get ready to start the engine.
Dec 10, 2013 | Garden
My dell m90 will not start up.It goes through the starting windows routine and then goes to a black screen?
when you start up your computer press f8 a menu will come up select Last know configuration that worked press enter.see if that works.If not press f8 again and select safe mode press enter see if it will boot to safe mode.if it boots go to my computer right click your boot drive select double click tools then click check now button a menu will come up tick automatic repair then start repair.It will ask you to shedule a repair click ok when you restart it will check and repair your hard drive.If this does not work you can put your operating system disk in your drive and boot to it and click repair and follow the on screen instructions
Oct 26, 2012 | Dell Precision M90 Notebook
My taskbar and start button is not showing and after pressing window button nothing is showing. I have installed window 3 times but problem is not solved. Please help to resolve this.
download TweakUI install it, click Start>Run, and type in TWEAKUI now click ok, in the window that pops up, click on Repair, now click on the down arrow in the right hand pane, make sure Rebuild Icons is selected, now click Repair Now, Click OK, then Reboot, all should be well then.
http://download.cnet.com/Tweak-UI/3000-2072_4-10002117.html
Sep 17, 2011 | Computers & Internet
The problem of my microwave panasonic, i flug the socuit then ok,i put one minits then i start but the fuse inside the microwave cut off then i change the new fuse but still cut off what is the sulution...
I would call an approved Panasonic repair shop, as there is a possiblity that the invertor is faulty and that requires specialist equipment to repair it.
Jan 12, 2011 | Panasonic NN-S960WA Microwave Oven
I am reasonably able mechanically. How complicated is it to clean the carb on a 15hp yamaha outboard
Hello there:
Usually if its just a water issue and it has not damaged the castings from sitting you can remove the carb, fairly easily dissasemble it if needed and spray it out well with carb cleaner Make sure to use a lint free rag and wipe down alll of the parts after you have sprayed them and left them sit for 2-3 min and than respray reassmble it. if any o-rings are cut or swelled they will have to be replaced. a service manual will have all the pics nessisary. its a simple carb though. for repair and the price for replacement parts are fairly cheep ok?
best regards michael
Oct 13, 2009 | RTO Oar Sockets
Windows will not start
Ok ...that message about the PXE is showing up because the computer cant find an operating system on the hard drive for some reason.
Try booting from your Vista DVD ,let setup start then running Start Up repair ....
3. If prompted, press any key to start Windows from the installation disc.
NoteIf your computer is not configured to start from a CD or DVD, check the information that came with your computer. You may need to change your computers BIOS boot order
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7. On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Jan 02, 2009 | Microsoft Windows XP Professional
Philips GoGear HDD075/17 MP3 Player Logo
103 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
