I turned off my laptop by pressing the power button and now the laptop will not restart. It goes to a screen that says "We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this." It has options (Safe Mode, Start windows normally...) But it always goes back to the same screen...
  • 118 Answers
You want to time in the number corresponding to start windows normally and press enter.
Posted on Sep 07, 2008
Hi. Every time I turn my Toshiba Satellite Laptop on (A305-S6905) it turns on normal then it goes to this black screen and says "A disk read error occurred press ctrl+alt+del to restart." I...
The disk read error message appears when the motherboard can't read what is in the hard disk and use it to launch the Windows boot process.
It means that the hard disk is dead and everything on it is lost, including the recovery partition that new laptops use instead of the recovery disks. You will have to replace the hard disk (a quite complicated job that only an experienced person should do) then order a recovery disk from here
https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/serviceUnitVerification.jsp
and use it to reinstall Windows.
Jul 15, 2011 | Toshiba Satellite A135-S2386 Notebook
My laptop will not turn on when I press the power button. There is a screen that says toshiba leading innovations with the options of pressing f-2 or f12 for setup or boot selection menus but then the...
AFTER YOU ON THE SYSTEM BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 15, 2011 | Computers & Internet
ACER ASPIRE 5532 LOCKED UP, WON'T GO PAST THE "ACER empowering people" logo at startup. press f2 and it says "please wait" then won't do anything else. Pressing f12 to change start-up...
1. Turn the Laptop off 2. Remove the battery 3. Disconnect the AC adapter from the laptop 4. Disconnect any peripheral devices from the laptop such as printer usb cables, PCMCIA cards etc. 5. Push and hold the power button for 60 seconds then let go 6. Connect the AC adapter to your laptop 7. Push power button to turn on the laptop 8. If this resolves the issue shutdown the laptop connect the battery and turn laptop back on
If issue is not resolved restart the computer and begin tapping the F8 key repeatedly until you see a screen that gives you options to enter different modes. Highlight "Safemode" and press enter. If the computer boots completely into safemode you likely have a driver that has corrupted or a hardware device that has failed. Likely driver failures are video card drivers. Got to Device Manager and uninstall the video card driver and restart the system. You can do this with other drivers as well.
Mar 05, 2011 | Acer Computers & Internet
Dear sir My HP ProBook4510s showing a white screen with hp logo and "Select User to Login" but there is no option to select user. If i type anything and press enter key three times it is...
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Feb 08, 2011 | HP ProBook 4510s FM849UT Notebook
I am trying to reset my toshibe m45 s165 to its factory settings, but when i try the whole press "0" and power at the same time, the laptop keeps turning off since im holding the power button,...
Do not hold the power button down while pressing the "0" key - it'll shut the computer off again. You just need to push it once to turn the power on and then hold the "0" key immediately after you push the power button on - just like turning on the laptop, but this time you're holding the "0" key down.
Feb 05, 2011 | Toshiba Satellite M45-S165 Notebook
My other ASUS is not allowing me to go on it. When I log on it says "We apologize for the inconvenience, but Windows did not start success fully. A recent hardware or software change might hev caused...
Restart the computer and press F9. This will bring up your Asus System Recovery. Follow the prompts on screen. This will take approximately 20 mins to do but it should fix the problem. Hope this helps : ) If it doesn't or you are unable to bring up the System Recovery screen let me know.
Jan 01, 2011 | ASUS Eee 4G Notebook
Turn my acer aspire 3680 2022 on and get a screen that said we apologize for the inconvenience but windows did not start successfully. a recent hardware or solfware change might have caused this.then it...
It appears that the issue might be with some hardware malfunctions. It may happen due to hardware failure, BIOS mismatch or due to
static charge. Let us try the basic troubleshooting. Turn Off the
Computer, remove all the devices attached to the computer, the power
cable and battrey, now holdon the power button for 15 secs (make sure
adpater and battery are uplugged) it will drain out all the static
charge. Now, restart the computer and keep on tapping F2, you will enter
to BIOS setup utility, press F9 (click "Yes", if you are prompted) and
then press F10 (Click "Yes", if you are prompted), it will restart the
computer. If still it is not booting to normal mode, then we have to
perform a full system recovery & it is a distructive process as you will
loose all the datas on the computer. To do so, Turn Off the computer,
now as soon as you hit the power button, keep on holding "Alt" key &
keep on tapping "F10" key, i.e Alt+f10, it will open the recovery
console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer
May 21, 2010 | Acer Aspire 3680 Laptop
Hi yes when i press the start button for my laptop it resets
when yit says the "we apologize screen" try doin the "controle-alt-deleat" command. if that doesnt work, try pressing the escape key. if that Still doesnt work, try pressing the end key. my guess is that you were either looking at something you souldnt have been, or you clicked on an ad. Eitherway, it sounds like you got a nasty virus. if nothing else works........ reformat.
Feb 10, 2010 | Toshiba Satellite M115-S3094 Notebook
Lap top turns on, however Windows will not start. It keeps going the the "We apologize for the inconvenience,..." choose how you want to restart.
Hi Lisa,
Somehow you have activated the startup sequence request in the msconfig utility. Start up your laptop, press F8 till you come to the boot sequence options menu, select Safe Mode, hit ENTER wait, then when in safe mode, a warning wndow appears just informing you that you have started in Safe Mode ... bla bla bla... Click OK. Then press start button, go to Run.. and in the dialogue box type msconfig and hit ENTER. In the msconfig utility window check on the dot next to Normal Startup - Loda all device drivers & services. Click apply & Ok then Restart your unit. I think this should solve your problem.
May 05, 2008 | Computers & Internet
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
