Question about Hoover HCA331FFK
Runs but doesn't cool
My refregerator seems to be working, but it doesn't cool. What is the problem?
  • jepoy_pc Jul 17, 2010
    Problem For Kooppel 7 Tons model PC60...
    The circuit breaker of compressor trip when we ON the unit, we try to check the terminal of compressor we got a high resistance reading..what is your other opinion of this problem is the compressor totally defective..pls help
    Guru:
  • 462 Answers
Verify the compressor is running first and the fan close to it. Check for dust dirt in the condenser coils underneath. Clean as necessary. Feel of the compressor CAREFUL if its HOT to the touch and hasn't been cooling listen to it for the 10 to 20 minutes your talking about. If its precisely 15 minutes on then off and the fan motor under by the compressor starts and stops at the same time your controller (thermostat or sensor/board assy.) is not sending power on to the compressor - replace as necessary. If your fans keeps running under neath the compressor is not working correctly. here is what to do to check it.
The fan staying on underneath is the tattle tell. If its not running something else is turning off and on the compressor (they run together normally) and fan motor look to the controller.
If the fan stays on it means (usually) the compressor should be running also. So the controllers are at least telling it to run. If the fan isn't up to speed or the coil is blocked with dust and lint/dirt this can cause (in some setups) both fan and compressor to overload from heat.
Assuming you have voltage to the compressor and the coils are clean and the fan motor under is working up to par, The compressor or its start components are at fault. Here is what to look for:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Getting to this step: Either your compressor is broken inside or the start components are not working properly. Ohm the compressor terminals to ground and across to each other.
If any read anything to ground the compressor is bad.
Your readings between the compressor terminals should all be different and you should have 1 low 1 medium and 1 high resistance reading.
Add the low and mid reading together and the sum should be close to the highest reading. If it reads say 20% more or less then retest it a couple of times to confirm your not slipping on the terminals.
Assuming the above checks out: Get a new Start relay (start capacitor if so equipped) relay and overload (and capacitor if it has one) In other words everything that is external and attached to the wires or terminals on the compressor, and replace them on to the compressor. Then if it starts problem solved if it still does same thing the compressor is bad (broken mechanically inside the compressor) and you have to decide to replace compressor or replace the refrigerating compressor be it AC or Refrigeration.
A few times I have gotten a compressor to start after leaving it off for 6 to 12 hours then retrying it. See the compressor unless left off for 6 to 12 hours and sometimes as long as 24 hours Is tight due to linear expansion from heat. And about 1/2 the time it is ok after new start components are installed. The other 1/2 the compressor will be ok for a day or 2 then stop again. Most likely from a “hard spot” in the movement of the internal parts in the compressor.
30 years of doing refrigeration and this has not changed.
Please rate me as high as you can and ask me to clarify anything you don’t understand.
Posted on Apr 14, 2009
  • Farley Redfield
    Farley Redfield Apr 14, 2009
    Normal
    0
    false
    false
    false
    font-size:10.0pt;
    understand.
I took the back cover of the freezer off and found it all iced up. after defrosting all the ice; found the defrost coil tube busted into a dozen pieces and coiled filiment broke. i took longest piece and hooked back between the two ends of the defrost connections so the defrost would work. good enouph. if you don't want to pay for a repairman for a 10 year old fridge
Posted on May 27, 2007
Check the coils under the freezer for dust and clean them
Posted on May 06, 2007
Try replacing the overload relay attached to the compressor.
Posted on Mar 26, 2007
    Novelist:
  • 74 Answers
If a refrigerator doesn't cool at all, the problem is often with basic electrical controls-almost never with a need for a boost of refrigerant. Do not assume that the problem is related to the compressor or the sealed hermetic system-these types of problems happen only rarely. It may have dirty condenser coils, a door that doesn't seal tightly, or a defective temperature control. 1) Check the cold control. Be sure it is set to "cold." Normally, the temperature inside the refrigerator should be about 37 degrees F. 2) Listen for the freezer fan inside the freezer. When the freezer fan is running, it means the defrost timer and the cold control in the refrigerator are both set to cool. 3) Listen for the compressor fan, where the compressor is located (typically behind or beneath the refrigerator. When the freezer fan is operating the compressor fan should also be working (most of the time). 4) If one of the fans is not working or the compressor is off, the refrigerator will offer very little cooling or none at all. Call a repairperson.
Posted on Jan 18, 2006
SOURCE:
REFREGERATOR NOT COOLING
You have a ice obstruction,or fan in freezer may not be moving air to fresh food part of fridge, or the defrost heater may not be working.try YouTube
Dec 22, 2017 | Refrigerators
My samsung rs2533rs is not cooling
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 23, 2012 | Samsung Refrigerators
What temp should my golf run at if the cooling system is operating properly? Runs perfectly on the highway but when i stop start it goes from min temp to only half on the gauge but seems to be runnning...
the temp seems to be fine. 80degrees celsius or less in stop and go traffic is normal,especially since the cooling fans are working and coming on at the proper time. the what seems to be running rough is another problem that doesn't seem to related to the cooling system temp. may want to check the spark plugs for worn electrodes.
Aug 08, 2011 | 1994 Volkswagen Golf
Bottom Freezer works well..But the top refregerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 12, 2011 | Amana Refrigerators
Freezer works but not the refregerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 24, 2010 | Samsung RS2556 Side by Side Refrigerator
Top refregerator not working
look for ice in back wall of freezer . this is a no frost and that means no frost .. you may have a defrost system failure .. mm
Jul 04, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Regrigerator stopped, now freezer too.
It is due to the defrost timer is not working. Once it is replaced, you should be good for another year. The information is given by the repairman. I have this replaced two days ago. The MayTag part number is: 61005988.
Aug 07, 2008 | Jenn-Air JSD2789GES Side by Side...
Bottom Freezer
This is the way it is supposed to work. Modern refregerators are designed to keep the freezer temp between 0 - 10 degrees. As long as it is not freezing food in the refrigerator compartment all is well. On most units the only real cooling control is in the refregerator. This is the one the cycles the compressor. The freezer control usually only controls the amount of cold air allowed into the fridge. All cooling coils are usually in the freezer. it just pushes cold air into the fridge
Jul 04, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Refregerator
if your sure its not working ,you have to remove the cover in the freezer on the back wall and it requires a volt meter to make sure its not working.
Jun 13, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Hoover HCA331FFK Logo
1,189 people viewed this question
Top Hoover Refrigerators Experts
Jon Tutas
Jon Tutas
Level 1 Expert
Steve F
Tom Chichester
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
