Pink and Green Horizontal lines across screen
Normally, horizontal lines on an LCD or LED monitor indicate a bad control board inside the monitor. However, occasionally the problem can be caused by loose or bad cable connections. The only things that you can really do is to disconnect both ends of the monitor cable and reconnect them firmly. Also, you can disconnect the monitor cable completely and just leave the power cable. With only the power cable attached, you can turn the monitor on and off. The monitor should have a "startup screen" or display a message that says something like "Video Cable Disconnected". If the green and pink lines are still present without your computer connected, then the monitor has gone bad. The good news is that Samsung SyncMaster monitors usually carry a 3 year warranty, whereas most monitors only have a 1 year warranty. You may be able to have the monitor replaced at no cost to you if it's less than 3 years old.
