Question about Hoover HCA331FFK
Refregerator isn't working
It just stopped working this morning! Any help would be much appreciated.
    Novelist:
  • 74 Answers
To operate, a refrigerator needs electricity. If the refrigerator's light doesn't work and it's motor doesn't run: 1) Check the power. Make sure that the receptacle works (plug in a working lamp or a circuit tester). If the receptacle doesn?t work, check for a tripped circuit breaker or blown fuse. 2) Be sure the cold control is turned on. 3) If you discover that the refrigerator is plugged into a working outlet and the cold control is on, but the device shows no signs of life, leave the door closed to retain the cold air and call an appliance repairperson.
Posted on Jan 18, 2006
REFREGERATOR NOT COOLING
You have a ice obstruction,or fan in freezer may not be moving air to fresh food part of fridge, or the defrost heater may not be working.try YouTube
Dec 22, 2017 | Refrigerators
My cooktops eye stopped working
Is the oven not working as well? If it isn't working check your breaker for that appliance.
Oct 06, 2012 | Frigidaire FEC36S6EB
I've had the refregerator for 10 months.. All of a sudden water is appearing on the floor next to the refrigerator. Where could it be leaking from?
Pull it forward and seei if the drain pan is either overflowing or empty. If it,s empty, check the drain isn't blocked, causing meltwater to leak from inside. If it's overflowing, check the door seals properly and the defrost settings are ok.
May 22, 2012 | Samsung RFG297HDRS 29.0 CuFt French Door...
MY ROF2ETI HAS STOPPED WORKING RECENTLY THE POWER INDICATOR LIGHT ISN'T ON, CHECKED FUSE OK IT'S ONLY 8MONTHS OLD, ANY HELP APPRECIATED.
If it's not too late, I have just repaired one of these. The time switch circuitry has failed.
I can repair this unit. Call Nic on 01202 814081 (Bournemouth)
Jun 14, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
My computer was working this morning and then when I tried to turn it on today, it is showing no sign of power to the computer. The only light that is on is the light showing that the computer is plugged...
The problem with your laptop isn't related with power supply. Even if your battery isn't working, it would have started with the help of the Charger/External supply.
The actual problem seems to be related with the Planner/Motherboard. When it stops working, it causes major problem. You should consult the manufacturer of your computer and if it is in its warranty period, they'll repair/replace it for free.
Apr 17, 2011 | Toshiba Computers & Internet
Top refregerator not working
look for ice in back wall of freezer . this is a no frost and that means no frost .. you may have a defrost system failure .. mm
Jul 04, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Refregerator
if your sure its not working ,you have to remove the cover in the freezer on the back wall and it requires a volt meter to make sure its not working.
Jun 13, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Maytag mfd2561 water dispencer and ice maker issues
Most likely it is the High Voltage Control board located in the unit compartment (take off the back cover where the water lines are) i have had lots of them failing and doing all kinds of odd things, so far it has been that computer. Part number 12002608
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Hoover HCA331FFK Logo
592 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
tom wright
tom wright
JONFRIDGEDOC
Level 1 Expert
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
