SOURCE: Oil pressure light comes on after driving on highway for 10 miles
Sounds like your sending unit sensor - if it was your pump going out, your engine would be history by now. Rule of thumb, if your oil check light ever comes on, it's usually too late to remedy the problem. You have a major issue, but since you've obviousely drove it quite a bit since then and it still hasn't seized up, I'm guessing you're ok...for now. Since you took it to a shop and they said you're ok, I'm assuming they checked your level and visually checked for leaks and found nothing. Either, you've got somethijng partially blocking your pick-up tube for the pump which is in your oil pan, or a electrical issue with the sensor. I would start by having someone check the sensor out and go from there...good luck.
SOURCE: Check engine and VSC lights on
I talked to you on the live chat, and I think that you may have missed the end of my typing...
What I went on to say is that more often than not, on the 02 4Runners, the Check and VSC lights in tandem look mainly after the emission system, and, since you stated no issues during the road test, I would guess that it is a fuel issue (too full/loose gas cap). But, if you can get the vehicle scanned, I will be very glad to provide you with more and better info if you provide me with the DTC codes. That would require your guy or an autozone hookup to a scan tool. I hope my clarification helps; and the graciouness of a FIxYa rating for this question would be greatly appreciated
SOURCE: #5 cylinder misfire
I have a corolla and had #4 cylinder misfire also diagnosed at autozone. After changing the spark plugs, problem persisted, along with the same error code, so they recommended changing the spark plug wires, and that is what fixed it. I would have changed the rotor cap too, but was low on dough. Glad that was not the problem.
SOURCE: 2005 kia sorento Fuel Gauge says empty with 1/2 tank of gas.
Fuel sensor is not working well. Just changed mine today for the same problem.
